Page 2 of 7 FirstFirst 1 2 3 4 5 6 ... LastLast
Results 36 to 70 of 214
Thread: 24V VR6 oil change how to lots of photos
  1. Banned Integrale's Avatar
    Aug 1st, 1999
    05-21-2003 03:06 AM #36
    Anyone?
  2. Banned
    Aug 25th, 2002
    05-21-2003 03:14 AM #37
    Quote, originally posted by Integrale »
    My car is leased....is it worth changing my own oil? I was quite satisfied taking it to the dealership...found a great mechanic and it ended up leaving...close to home, only $28 dollars...too good to be true I guess.
    if it's leased then i wouldn't bother putting synthetic or any of the goodies in it. I would just pay the dealer to change the oil.
  3. 05-23-2003 12:27 PM #38
    Quote, originally posted by FLdude »
    yes.. same basic procedure.. I have never worked on a 12V.. other than the diffrent filter and possibly a diffrent oil quanitly it should be about the same.
    Yes, my (now former) '93 VR6 procedure was the same. Filter looks different, but all the other is the same. That engine took 6.1Qt for a full oil change and my '03 24V VR6 also takes 6.1Qt per the manual.
  4. 05-23-2003 02:16 PM #39
    Quote, originally posted by kamil »
    But what if you fall in love with it and wind up wanting to buy it?
    NAH! Not gonna happen when the R32 is sitting outside during lease end/ lease buyout negotiations
  5. Banned Integrale's Avatar
    Aug 1st, 1999
    05-29-2003 01:53 AM #40
    I just got the filter...but it's a 021 115 562A number...not a 071-115-562....at the filter corrigations are straight...not warped...they also charged me $19 for it...
    I'm taking it back.
  6. Banned Integrale's Avatar
    Aug 1st, 1999
    05-29-2003 05:14 PM #41
    Well...i found out that according to the dealership this new number I stated above is a newer part...replaces the older wavey style insert. Just an FYI.
  7. 06-02-2003 01:01 PM #42
    Read this post for the first time. Awesome job.
    Wish you would consider doing one for tire rotation with a floor jack + stands
    Questions: Is 5W-40 the same as synthetic? Can't find it anywhere. My car still has factory oil in it but says I can use 5W-30 (SJ) if available.
    What are your thoughts on this? Never used synthetic in the past and am unaware of true pros/cons of oil vs. synthetic.
    Thank you.
  8. 06-02-2003 03:06 PM #43
    Quote, originally posted by Miles267 »
    Thank you.
    In your climate NEVER use 5W-30 oil! It's too thin for the engine (according to the manual for warm weather) and could cause damage. Go to Autozone, or Pepboys (or what ever auto parts store is down there) and get 6 quarts of "Mobil 1 Synthetic, 0W-40", that is what your engine should have in it. It's approved for the VW standard mentioned in the manual (as well as most other German and Japanese cars). Just changed mine the other day and it runs wonderfully!
  9. 06-03-2003 09:44 AM #44
    Hrmph... When we went into the Parts dept to get a new filter, my bf asked the service guy, 'Whats VW using in the 24V VR6.. synthetic?' The service rep says in what car, we respond '03 GLI' and the rep says no, that application does notn call for synthetic....
    Was he crazy??
  10. 06-03-2003 10:23 AM #45
    Quote, originally posted by 03GLIgirl »
    Was he crazy??
    To my knowledge, no, it doesn't require synthetic, but should you use it? I know I do. It's better the engine, especially since the recommended drain interval is 10K miles after the first 2 changes.
  11. 06-03-2003 11:16 AM #46
    I can't find x-40 wt synthetic at any of my local retailers!
    ...........Autozone, Hires, Meijers, Walmart... zippo!
  12. 06-03-2003 11:20 AM #47
    Quote, originally posted by BadassVW »
    No Mobile 1 0W-40 Synthetic? Weird. You could ask Autozone to order it for you. Or just find an online place and order that or (if you want the really good stuff) Redline or Amsoil.
  13. Banned Integrale's Avatar
    Aug 1st, 1999
    06-03-2003 12:43 PM #48
    Can anyone confirm the above number is the correct part number now used?
  14. Banned Integrale's Avatar
    Aug 1st, 1999
    06-05-2003 03:26 AM #49
    Anyone ? Pretty please???
  15. Member melman8r's Avatar
    Mar 18th, 2002
    2011 2dr. GTI Autobahn 6 spd. CSG
    06-05-2003 08:31 PM #50
    Put both numbers in @ http://www.impexfap.com/home.c...47952. It doesn't look right??
  16. Banned Integrale's Avatar
    Aug 1st, 1999
    06-05-2003 10:37 PM #51
    Quote, originally posted by melman8r »
    I got the right one...FLDude's filter was correct.
    As far as oils go, I think anyone using a multiblend would be wise as it's cheaper than full synth and probably does almost as good of a job.
    You'll save ALOT of money..
  17. Banned Integrale's Avatar
    Aug 1st, 1999
    06-08-2003 08:53 PM #52
    FYI...the oil pan drain plug is impossible to take off...I gave up after 30 minutes of trying. Taking all the parts back and just have it serviced by the dealer.
  18. Member melman8r's Avatar
    Mar 18th, 2002
    06-08-2003 09:25 PM #53
    I had no trouble...first oil change 5k. Mobil 1.
  19. Banned Integrale's Avatar
    Aug 1st, 1999
    06-08-2003 10:10 PM #54
    I've ended up spending so much more for the oil, fiter, tools, time spent, I wonder if it's even worth it. And I still don't have a decent jack, stands, and things like that. If I got those I'd end up spending over $200 just for an oil change?
    Modified by Integrale at 7:11 PM 6-8-2003
  20. 06-09-2003 05:44 AM #55
    I've ended up spending so much more for the oil, fiter, tools, time spent, I wonder if it's even worth it. And I still don't have a decent jack, stands, and things like that. If I got those I'd end up spending over $200 just for an oil change?Modified by Integrale at 7:11 PM 6-8-2003
    Don't most people already have those? I think my Jack was $50 and my stands were about $15 for a pair. You'll save that after the first couple of do it yourself changes. Plus, then you know the chane ot done riht and some dealer didn't leave the old filter in because they were lazy or something!
  21. Banned Integrale's Avatar
    Aug 1st, 1999
    06-09-2003 02:09 PM #56
    Quote, originally posted by SLVR6 »
    That's true...at least you know you'd do it right! I'll have to look into getting a jack...living in an apartment with limited storage blows.
  22. 06-09-2003 02:13 PM #57
    I can relate. When I lived in an apartment I got lazy and took mine to the dealer normally. Most complex's don't take to kindly if they catch you out there with the car up on jack's, mine had rules against it!
  23. Banned Integrale's Avatar
    Aug 1st, 1999
    06-09-2003 02:41 PM #58
    I think I'd be okay with the rules but I'd need to be discrete...
    What do you think about getting car ramps rather than a jack? And a couple of wheel chocks? Would I still need a jack stand?
  24. 06-09-2003 02:46 PM #59
    Ramps work fine if you can get your car on them. Then you also don't have to worry as much about a flat surface. My old roommate found out the hard way the you NEVER jack a car up when there is a slope! He jacked his up, passenger side was on a slight slope, using his jack from the trunk, even though I told him it was a bad idea. Came back in the aparment with a collapsed scissor jack and a sore shoulder!
  25. Banned Integrale's Avatar
    Aug 1st, 1999
    06-09-2003 04:03 PM #60
    He's lucky he got away with only a sore shoulder...
    I was wondering about the easy or difficulty of getting the car onto ramps. I think sears has some nice low profile types that may work out okay.
  26. 06-09-2003 04:34 PM #61
    I've never actually used ramps, but they should be pretty easy to use. Just drive up them carefully, then chuck the wheels.
  27. 06-09-2003 04:45 PM #62
    Anything special needed to chock wheels or are a few pieces of 2x4 good enough? BTW, bought a set of those low-profile ramps from sears (yellow ones) and used them this weekend on my gf's Saturn, which is fairly low to the ground. They worked great as long as you go SLOW both on and off them - particularly when backing off of them.
  28. Member
    Oct 5th, 2002
    Burlington ON
    06-17-2003 04:23 PM #63
    I'm taking it back.
    That 021 115 562a number is for a 12v oil filter. I just bought one today, it matches the number perfectly on my bill. And in canada they charge 33.20 for the filter. The second number, 071-115-562 is most likely for a 24v engine.
  29. Member FLdude's Avatar
    Aug 22nd, 2002
    2009 Tiguan, previous had 2002 VR6 GTI
    06-17-2003 11:53 PM #64
    Quote, originally posted by mrcvr6 »
    yep.. 071-115-562 is for the 24V
  30. Banned Integrale's Avatar
    Aug 1st, 1999
    06-21-2003 08:18 PM #65
    Finally got around to changing the oil today. Everything went well but not sure if it was worth the effort...well...give everything a shot once I suppose.
    The two things I could not replace were the crush washer on the oil pan filter plug...which I think is a good thing actually. I don't think the dealer had change it either since the car was new. What came with the filter was a bronze coloured washer...the washer attached to the pan plug was the same colour as the plug itself...and slightly smaller than the new washer....indicating that the washer may perhaps need to stay in place.
    Second, I could not remove the filter drain plug...it would not budge and I was afraid I may damage the hex inside the plug. Needless to say, I did not change out the filter plug o ring. After thinking about it, I wasn't even sure why this would need to be removed. I didn't have to remove it to change the oil.
    Anyway, no leaks so far...I hand (tool) tightened all items to a point it was snug and wouldn't budge anymore.
    One other thing, I bought myself a set of ramps to raise the car. Boy are they a ----- to use...it's quite difficult to use them without causing much mayhem!
    Anyway, thought I'd give all an update.
  31. 07-08-2003 01:12 AM #66
    where can i buy the filters in bulk. i dont want to be paying 20 bucks a filter if i can get them cheaper buying 10 or so at a time. i plan to change my oil evey 3to 5,000 miles because im anal about things like that even tho some synthetics claim to last up wards of 10,000 miles.
  32. 07-08-2003 06:42 AM #67
    I would highly recommend Dave @ http://www.germanautoparts.com/
  33. 07-09-2003 01:29 PM #68
    Awesome post!!!! Is someone going to put this on a website as a DIY link? I would br glad to put it on mine, for it needs a VW enthusiast section. would you mind if I did?
  34. 07-09-2003 01:41 PM #69
    I take it you spoke to Dave? Surely you're not asking my permission? That's where I bought mine; picked up a case.
  35. Member Kowgod's Avatar
    Aug 27th, 2001
    Chicago, IL
    2008 Rabbit 2.5, 2002 Golf GTI 1.8T
    07-25-2003 05:51 PM #70
    How different is this writeup from an oil change on a 1.8T?
    I want to change my oil, but have yet to find anything even close to this writeup as far as information and detail goes, for the 1.8T.
