Page 4 of 7 FirstFirst 1 2 3 4 5 6 7 LastLast
Results 106 to 140 of 214
Thread: 24V VR6 oil change how to lots of photos
  1. 08-09-2004 04:24 PM #106
    i found mine at autozone.
  2. Member FLdude's Avatar
    Aug 22nd, 2002
    2009 Tiguan, previous had 2002 VR6 GTI
    08-09-2004 10:40 PM #107
    Got mine at sears..
    amazing this thread is still going.. may become the worlds longest oil change DIY post..
    As for the splash shield.. you could leave it on.. I took mine off.. the four screws were not a major time issue. Trimming the shield does sound like a good idea if you drive allot and need to service it frequently.
    Thanks again for all the positive comments! With the training posted here you too could work at jiffy lube!
  3. Member '97Trek2.0's Avatar
    Jun 21st, 2001
    Denver, CO
    2004 VW GTI VR6
    08-10-2004 01:47 PM #108
    I wonder how many vr6's they get at Jiffy Lube? My buddy took his '97 Jetta VR6 there and after he pulled it in they said they couldn't change it for him.
  4. Moderator askibum02's Avatar
    May 10th, 2002
    Fayettenam, NC
    Fahrenheit GLI #638, MKVI Jetta TDI
    08-20-2004 01:28 PM #109
    FWIW- The cheapest I have found the filter is 10.45 at ECS.
    Brett
    FS: MKIII Perforated leather e-brake boot
    I can think of 726 reasons why I like vBulletin
    Noli Me Tangere
  5. 08-20-2004 03:39 PM #110
    dam thats cheap, cheapest i've seen them was like $12-14
  6. Member FigureFive's Avatar
    Dec 21st, 2003
    Nashville, TN
    MkIV R32
    08-21-2004 07:25 PM #111
    Quote, originally posted by askibum02 »
    Last one I bought was on July 21 - VW Santa Monica, $9.94 + tax=$10.76
  7. Member graeme86's Avatar
    Jun 27th, 2003
    Brisbane Qld
    2004 DBP R32; 1971 Superbug
    08-31-2004 03:09 AM #112
    FYI ... I just bought a filter for my .:R and the part I was supplied is 071 115 562 A, but it looks identical to the one in the picture at the start of this thread.
    PM if you are looking for: New Beetle RSI shift light; Euro Headlight switches; RHD folding Stubbies.
    OEM+ freaks click here: Graeme's Webspace - Latest Updates: Audi Brushed Alloy Mirror Switch; Camshaft Hall Sensors; Bulb Check System; W8 Light with Autodim Mirror Defeat Function
  8. 05-19-2005 08:50 PM #113
    whats the best type of oil to use in a stock 2001 vr6 auto w/ about 50,000miles?
  9. 05-19-2005 10:00 PM #114
    Quote, originally posted by maka »
    check the 12v vr6 forum cause thats what u have.
  10. 05-20-2005 01:35 PM #115
    Synthetic and go 5,000 miles, dino if you go 3,000 mile iterval oil changes. Weight would be depended on your locations weather.
  11. Member D03GLIR's Avatar
    Oct 20th, 2004
    Billerica MA
    03 24V VR6 GLI, 65 Corvair Corsa
    06-16-2005 01:28 PM #116
    Just back checking parts sources and stumbled on this question. complete plug/ washers are cheap enough but washers are cheaper.
    I bought a spare plug and just cut the washer off the old one w/ a sharp pair of dikes (the tool for you gutter brains!). The new one will just thread on. It only gets locked after being crushed. I suggest a new one each time, esp w/ copper since it work hardens and won't seal well a second time. Bonus puzzler- how do you anneal copper??? (good to know for other more expensive gaskets).
    I'll tell if someone tells me how to drop emoticons into messages.....
    03 24V VR6, VF Stg II SC, TT Brakes & SS Lines, Clutchnet Stg II, Peloquin LSD, Raxles, VF Dogbone, Fikse FM 10 Wheels w/ Yoko Sdrive summer tires, H&R Sport springs, Koni Yellows, Neuspeed 28mm rear sway bar, replacement Kenwood head unit and a Grateful Dead sticker.
  12. 06-17-2005 12:27 PM #117
    If by messages you mean Vortex IM's it's the icon button. If not, ignore me.
    BTW, don't you get scared just getting into your Corvair? Driving it must be absolutely terrifying. I mean after all it is Unsafe At Any Speed
    How many times have you heard that one?
  13. Senior Member abydielsgli's Avatar
    May 7th, 2003
    san diego
    06-17-2005 11:36 PM #118
    i love these threads.
  14. Member
    Dec 28th, 2003
    Clarksville, TN.
    06-19-2005 12:04 PM #119
    Was told by a Local VW Master Tech, that the little O-Ring on the filter is supposed to stay on the filter. It seals the top of the filter in an Anitdrain back valve or some stuff like that. He said that when the engine first came out, they had some engineers come in and give a couple of classes on the differences of the 12V and 24V engines, and they also covered oil change procedures as well. It was stated that the Little Oring Stays on the filter. All the local VW service Departments around me (about 5 of them) agree with the statement.
  15. Semi-n00b
    Aug 28th, 2005
    Long Island
    10-20-2005 05:23 PM #120
    I left the small O-Ring on my filter as well, Poor of VW not to include a small hint about that in the filter box from the dealer!! I hope all is well, does anyone have any imput to this??
    Thanks
  16. Member FLdude's Avatar
    Aug 22nd, 2002
    10-20-2005 08:43 PM #121
    Interesting info on the O-ring.. I'll ask my dealer as well.. when I took the filter off my car the 1st oil change there was no little o-ring on the filter.. belive me.. I looked everywhere for it.. thought it was stuck somwhere, fell in the drain pan etc. When I could not find it and found the little o-ring on the plug was the same size.. figured it went there..
    Anyone work for VW? Do Offical VW insturctions exist for this??
  17. 10-21-2005 09:38 AM #122
    If you look up in the engine where the filter tip goes there is nothing for it to touch. The whole plastic tip is unneccessary for that matter.
    As stated before, this filter is not specific to only this engine, but fits many engine types.
    So I suspect the o-ring and serves a function one of these other engines.
  18. Member proshot's Avatar
    Apr 22nd, 2004
    Texas
    MK4 R
    10-21-2005 02:54 PM #123
    i took mine off and put it on the drain plug....
  19. 11-10-2005 12:05 PM #124
  20. 01-13-2006 04:13 PM #125
    I want to service my own car,this info will help out alot. Do you have to reset a service reminder or anything like that on the B6 too????
    If so how do you do it???
  21. Member PhReE's Avatar
    Sep 16th, 2004
    Taylorsville, UT
    2004 Turbo VR6
    01-17-2006 09:22 PM #126
    Quote, originally posted by ecorrea »
    What are you talkin about buddy? B6? Thats a passat, passats have never had this motor in them. Your sig says you have a 2.0T -- the oil change procedure will be different on that car - its an entirely different platform and engine ...
    On THIS motor (24v 2.8L VR) there is no service light however.
    -James
    04 GTI Silverstone 24vT :: GT35r - TT 264/260 - Unitronic 630cc - Bosch 044 - Area51 SRI - Full 3" TB :: More in progress
    >> http://zingledot.myminicity.com/ | http://sourceforge.net/projects/imagizer2 <<
  22. Banned MingChow's Avatar
    Dec 23rd, 2005
    01-18-2006 09:49 AM #127
    wow
  23. Member ShadyGTi's Avatar
    Nov 6th, 2003
    Columbus, OH
    1983 Rabbit GTi, 2003 Jetta GLI
    02-12-2006 10:01 AM #128
    Awesome thread.. I know it is 2 years later but nice job.. my only question is what is the best kind of oil to use my owners manual is missing a few pages and the dealership gave me some some weird oil # Castrol L505 something. I can't find it anywhere. Can someone help me out? Plus I live in Ohio and it is cold here.
    Modified by ShadyGTi at 8:25 AM 2-21-2006
  24. Member vwcakenpie's Avatar
    Dec 12th, 2004
    Bedford, PA
    2001/Vdub/Jetta VR
    02-20-2006 11:18 PM #129
    Bump, I would like to know which oil to put in. I live in PA.
  25. Banned MingChow's Avatar
    Dec 23rd, 2005
    02-21-2006 02:08 PM #130
    5w-40 mobile 1 or 10w-30 mobile 1 or whatever brand you like.
  26. Member cameagain's Avatar
    Nov 26th, 2004
    fort shizzle
    audi a4 3.0 quattro
    02-23-2006 02:04 PM #131
    a friend of mine just order some euprean oil for my 24v it's called amsoil (sp) 5w-40. anyone heard of it. ?
  27. Banned MingChow's Avatar
    Dec 23rd, 2005
    02-23-2006 02:10 PM #132
    amsoil, yup, what is your friend paying for it?
  28. Member cameagain's Avatar
    Nov 26th, 2004
    fort shizzle
    audi a4 3.0 quattro
    02-23-2006 02:11 PM #133
    i'm getting a case which is 12qt. for 50$
  29. Banned MingChow's Avatar
    Dec 23rd, 2005
    02-23-2006 02:13 PM #134
    sounds about right what i paid for mine. i used it once when i first got the car.
    i'm one of those people who think as long as its synthetic, oil is oil. providing you use the correct weight for the area you live in.
    Modified by MingChow at 11:15 AM 2-23-2006
  30. Member cameagain's Avatar
    Nov 26th, 2004
    fort shizzle
    audi a4 3.0 quattro
    02-23-2006 02:15 PM #135
    did you like or what didn't you like about since i'm guessing you don't use it anymore
  31. Banned MingChow's Avatar
    Dec 23rd, 2005
    02-23-2006 02:15 PM #136
    let us know what you think of it when you do your next oil change.
  32. Banned MingChow's Avatar
    Dec 23rd, 2005
    02-23-2006 02:16 PM #137
    i edited my post before your last one.
  33. Banned MingChow's Avatar
    Dec 23rd, 2005
    02-23-2006 02:19 PM #138
    i overkill on oil. since i bought the car new, i've changed oil every 3000 miles. with such small intervals, at least to me, oil is oil. plus i garage her every winter so i don't have many miles on her.
    as far as oil quality, i think its a great oil. if you go long between changes i would use it.
    Modified by MingChow at 11:24 AM 2-23-2006
  34. Banned MingChow's Avatar
    Dec 23rd, 2005
    02-23-2006 02:21 PM #139
    Modified by MingChow at 11:23 AM 2-23-2006
  35. Member cameagain's Avatar
    Nov 26th, 2004
    fort shizzle
    audi a4 3.0 quattro
    02-23-2006 02:24 PM #140
    thanks for the info.
