22 ft lbs
#143
does the 20k service require to change the filter cap plug? ?
because i had my 20k service done at 25k miles, now im near 30k and i was about to change my oil when i saw the SAME filter cap plug i had on, but completely imposible to take out. the allen key does not hold and slips, even tryied bigger sizes, and nothing.
would the dealer take care of that?
#145
This sucks! who designed this......VR6 Ramsen?![]()
#146
great "how to"! just did the first oil change while in my possesion. Someone stripped the drain plug on the filter housing and that s.o.b. does not want to come out!!!!! now I need to order a new $cover$ for the filter housing. Greeaaaat!!!
#147
Quote, originally posted by acdelco » great "how to"! just did the first oil change while in my possesion. Someone stripped the drain plug on the filter housing and that s.o.b. does not want to come out!!!!! now I need to order a new $cover$ for the filter housing. Greeaaaat!!!
That happens to everyone
-James
04 GTI Silverstone 24vT :: GT35r - TT 264/260 - Unitronic 630cc - Bosch 044 - Area51 SRI - Full 3" TB :: More in progress
>> http://zingledot.myminicity.com/ | http://sourceforge.net/projects/imagizer2 <<
#148
Great write-up! I used this to change my oil for the first time yesterday. Although I forgot the adapter for the 32mm socket, so I had to ride my bike up to the auto parts store since no one was around. The car didn't fall on me so I live to see another day!One thing that pissed me off is how these oil change places don't know how to change out oil. It isn't that hard...all they have to do is stock the right products and have the right tools, which is something they should do ANYWAY. AND I hate the fact that I paid $81.87 to the dealer to get it changed one time, and $72.39 to Express Oil Change! 3rd time's the charm I guess. Oh well, that was my rant.
#149
A 6mm hex socket is worth it's weight in gold. It's very cheap!
It works much better than a plain key,![]()
#150
021 115 562A
071-115-562Which one is it for our engine again? I think i got the wrong one. It doesn't have the long neck like the one pictured here.
#151
You need the filter with the neck as pictured.
#152
Quote, originally posted by Astralplane » You need the filter with the neck as pictured.
I know this!!
#153
Quote, originally posted by Matt@EuroJerks »
I know this!!
Then your question is?
Correct part # is in first post as indicated by the author and backed up by several others throughout.
#154
Quote, originally posted by Astralplane » Then your question is?
yeah thanks....
#155
yeah thanks....
I took that part number and got a filter that has straight side fins and no neck.
I think its the "a" version we need.![]()
EDIT...looking at that box top next to the filter...it does say 071-115-562
now I am REALLY confused
Modified by Matt@EuroJerks at 4:35 PM 11-13-2006
#156
good DIY.
it helped a lot, thanks man.
#157
thankyou just did my first oil change and it went well thanks for the great advice
#158
don't strip the soft threads on your aluminum oil pans while attempting this, just thought i'd caution anyone trying this without a torque wrench
#159
Great Job on a common but interesting topic. Great pics also. One question remains: if you only have Heinieken, can you proceed, or should you go get true German beer first?
#161
i want to change my own oil but anything different for the supercharger? 24v vr6
#162
i heard you should put a little less oil.
but thats what i heard.
dont know for sure.
i put usually 6'ish (measuring always _ dont pass middle of dipstick range)
#163
Can someone coach me through this. I noticed I just had the same problem - first oil change since getting the car and doing them myself by a 6mm Allen won't take that damned oil filter drain plug out!Does that filter drain plug need to come out before using the 36mm to remove the filter drain cover or can I just remove the cover without removing the drain plug as long as i'm over an oil drain pan?
Please help fellas!
mogwai
#164
You don't have to take out the filter drain plug, you can just take out the whole filter + filter cover, it'll just be a bit more messy.![]()
#165
i dont know about "a bit"more messy
be sure to have sand or something to clean up..
#166
FOR THE RECORD, SCREW THE STUPID OIL FILTER DRAIN PLUG.If you have a good set of bits then go for it but just a cheap allen key will strip it. The drain plug is there to reduce the mess of unscrewing the filter housing while it is still full. I find that just unscrewing the filter housing and spilling a little oil is okay. Its usually not enough to even run past my elbow...
Just make sure you keep the filter housing level until you get it down to the drain pan. Worst case scenario, you spill an oz of old dirty oil. Most people can handle this.
#167
Yeah mine has been stripped for a long time now. Just keep a rag handy when you pop it off, and as said above keep it level until you can pour it into the waste oil container. Then wipe everything off before you put it together, and you're golden.
-James
#168
Thanks fellas - well it turns out that I need to replace the whole unit. While unscrewing the oil cover, that damn plastic bolt head cracked...needless to say it drained the filer, but will also drip new oil as well.I posted an "emergency part request" in the classifieds forum as I'm supposed to drive from SA to Dallas on Thursday.
mog
#169
hey is this the process for manual or automatic transmission? and will it work for my jetta 2000 vr6? and where is the splash guard located>? i really appreciate it.. thanks
#170
When changing the oil for the first time, here is the worst case scenario, AVOID at all costs:I broke (cracked) the filter housing w/ the threads still stuck in the bellhousing. It took me 2 nights to gradually chip away at the remaining plastic thread still stuck on the bellhousing.
Sometimes, my dumbass has to learn the hard-way.
For my oil filter housing, only the 36mm is needed to remove the filter inside (the messier option). I use the STP filter, so I only change the large ring. Don't forget to coat it first and install on the right thread, otherwise, oil will drip.
Modified by pOrKcHoP bOy at 12:27 AM 1-16-2008
#171
The first time I changed my oil I cracked the plastic cap for the oil filter - whoever changed to oil before me had it on so tight I destroyed it when I took it off. Local dealer wanted $120 for it!!!!!! I got it from ECStuning for $25 and faster than the dealer said they would get it... I don't order any parts from that dealer anymore.
2008 VW R32 #587
Gone: 2002.5 VW GTI 24v VR6 - 180k+ miles
*My other car is a 1985 Chevy C10* 305 Bowtie Overdrives 700r4 3.08 - Ssslllooowww but sexy!
#172
Regarding part number question:On the box: 071 115 562 A
Right on the filter: 045 115 466 AFinally manned up and bought me the 36mm socket.
Also have a case of Royal Purple 10w-40 ready to go in! Gonna change it tomorrow so I have nice fresh oil for my road trip this weekend to moab for the April Action car show
-James
#174
These instructions are awesome. I just did my first oil change this past weekend. As others have experienced, the 6mm hole on the filter drain plug was all stripped out, so I removed the whole filter cap with minimal mess. Not a big deal. Also, I'd found out that one of the T20 screws and associated nut clip was missing from the shield and another was rusted to the point of being seized up. Reassembly went without issue. Thanks again for the great post.
#175
Quote, originally posted by jda487 » ![]()
my new background
The Elite 24v VR6 Club: Founder
Want to be a horsepower baller? Buy my car
http://forums.vwvortex.com/showthrea...whp-street-car
