VWVortex.com - key fob "hangs up" when inserting and removing it
    Results 1 to 8 of 8
    Thread: key fob "hangs up" when inserting and removing it
      Sep 8th, 1999
      Upland CA
      2013 CC R-line in candy white
      10-16-2013 10:52 PM #1
      Lately when i go to start the car the key hangs up...like stops as I'm pushing it in for a second....then does the same thing when i go to remove it sometimes. One day it was particularly bad where i seriously thought i want going to be able to get it started cause it wouldn't go in to start.
      Anyone else have this happen?
      Nov 27th, 2009
      50 Miles South of Tucson AZ
      2015 Tiguan SEL and 2013 Genesis Coupe Track V6
      10-17-2013 02:55 AM #2
      Quote Originally Posted by Passatryde View Post
      If your car is still under warranty, take it to the dealership. Obviously, something is wrong with your ignition switch or key.
      Personally, I have never heard of or had this problem.
      2015 Tiguan SEL, White Gold.
      2013 Genesis Coupe Track Version, 3.8 V6, Red.
      Jan 13th, 2013
      So Cal
      '13 Camry hybrid
      10-17-2013 06:44 AM #3
      This has happened to me. Make sure that the junction between the metal and plastic part is smooth. I found both times when I experienced this that the metal part was shifted over a slight amount. You can slide it back and it will pop into place.
      2013 Camry hybrid
    4. 10-17-2013 10:03 AM #4
      this happened on my B6 passat as well.. which happened until one day the key went in and disappeared down into the dash! The round trim piece around the key opening is snapped into place and once removed I found that the actual key mechanism was missing the screw that attached it to the dash. I stole a screw from the trim under the dash and put everything back in place. No issues after that... almost makes me want to pop the trim off the key surround on my CC and see if they learned anything at the factory yet
      Sep 8th, 1999
      Upland CA
      10-18-2013 12:54 AM #5
      Thanks .... Yeah it only has ek miles on it so I'll take it to the dealer in a bit...its just weird...i looked the key over pretty thoroughly and i don't think that's the issue...I'll let u guys know what the dealer says it is
    6. 10-18-2013 11:19 AM #6
      I concur with CCDave. My suggestion is to look at your actual key FOB. Near the top you can slide it slightly to the right and this was causing mine to hang up as i was inserting it. Look at the two photos, I can slide it to the right with my finger...
      Sep 8th, 1999
      Upland CA
      10-18-2013 05:09 PM #7
      Quote Originally Posted by Mp3Supply View Post
      I'll be damned!! I can NOT believe i didn't notice that before...haven't gone out and tired to start it yet but sure as heck my key looked just like that...and come to think of it...it did start immediately after my 17 month old daughter dropped they key. When i looked at the key when it first started i noticed a little "dent" on one of the ridges (thinking it happened when she dropped them) ...so i have no idea how i missed that
      I bet that's what it was you all are awesome
    8. 10-18-2013 05:52 PM #8
      No prob. I forget how mine did it too because you have to press pretty hard on it to move it... It's the mechanism that lets you take off the sliver top part, why.. beats the hell out of me
