VWVortex.com - DIY - How to Change Transmission Fluid - with pics
    Page 1 of 5 12345 LastLast
    Results 1 to 25 of 124
    Thread: DIY - How to Change Transmission Fluid - with pics
    1. 01-11-2003 02:18 PM #1
      My 00 GTI GLS hit 30,000 miles this week. I finally got around to changing transmission fluid. Should have done it sooner. It is not difficult. Here is how I did it:
      Parts Required
      Redline MT-90 or similar, 3 quarts
      StaLube fluid pump, about $6 from Pep Boys, etc.
      17mm allen wrench or socket
      Torx driver to remove lower engine aero cladding
      Teflon tape (optional)
      I drove the front of my car up onto ramps. Then I jacked up the rear of the car and put jackstands under it. This makes the car approximately level. Remove lower engine aero cladding (4 torx screws) as you would for an oil change. Remove the fill plug first. There is no sense in draining the oil unless you can get the fill plug off the car. The plugs are remarkably similar to the ones BMW uses.
      Mine were not torqued very much. If I had to guess, I would say less than 50Nm.
      After the fill plug is removed, clean it and set it aside. Now remove the drain plug and catch the fluid. My fluid came out pretty dark gray. Clean the drain plug. I wrapped each of my plugs with 2 wrappings of teflon tape. This is probably totally unnecessary, but I did it anyway. My drain plug appeared to be leaking a little fluid (see black areas in pic above) so it was either undertorqued or something is not machined correctly. Replace drain plug. Torque to 50Nm = about 39 ft-lbs. or whatever you like.
      Use the StaLube pump to pump the new fluid in.
      I pumped directly from each of the redline bottles. It's messy but cheaper and easier than buying an empty bottle to pump from. Capacity is about 2.1L right on the nose. Once fluid starts to run out of the fill port, stop and replace the fill plug. Again 50 Nm or thereabouts. Clean and degrease all surfaces. I went for a 10 minute test drive and then checked for leaks before replacing the aero cowling. I'll check for leaks one more time in about a week.
      My car shifted really well before Redline, and it still does now. I don't feel any difference other than piece of mind that the fluid is new.
      Mongrel
      00 GTI GLS 1.8T Cosmic/Beige
      01 M Coupe Imola/Walnut/Extended
    2. 01-11-2003 02:42 PM #2
      I changed to Redline about a 2 months ago when my car hit 30K. I can feel a difference in the smoothness of the shifting. I didnt feel it in the first few weeks but after a while I bagan to feel the difference. I changed to redline and had a short shifter put in within about a week of each other, and thankfully I havent had my gear grind since. I sure it hasnt solved the gear grind for good, but it certainly helped. Redline is definately a good upgrade when it comes to changing the tranny fluid [IMG]http://*****************.com/smile/emthup.gif[/IMG]
    3. 01-11-2003 04:35 PM #3
      Thanks for the nice instructions! Great pictures, very detail.
    4. 01-11-2003 06:17 PM #4
      yeah... vw uses synthetic transmission oil already...
      Jul 10th, 2000
      Chicoutimi, Québec, Canada
      '06 BMW X3
      12-23-2003 08:40 PM #5
      Anybody knows what is the difference between GL 4 and GL 5 for tranny fluid?
    6. Member 03GTI4Me's Avatar
      Feb 24th, 2003
      NorCal
      '14 Jetta GLI, '17 GMC Acadia Denali, '04 Kawasaki ZRX1200R
      12-23-2003 08:43 PM #6
      Bookmarked. Thanks for the DIY. WIll need in about 20k
      -Says the VW owner
      VCDS HEX-CAN Available in Sacramento, CA.
    7. Member Red Pocket Rocket's Avatar
      Oct 17th, 2002
      Miami, FL
      15 Wrangler Unlimited
      12-23-2003 09:31 PM #7
      do you have to do this at 30k?
      O|||||||O
    8. 12-23-2003 09:33 PM #8
      How often should you change the tranny fluid? I'm going in for my 20k service in two weeks and i was planning on having the dealership change my tranny fluid along with whatever else they do during that service.
    9. 12-24-2003 12:09 AM #9
      Nice write up! [IMG]http://*****************.com/smile/emthup.gif[/IMG]
      -T99inFL-
      1999 Jetta VR6...GIAC...gone...
      2003 Jetta 1.8T...GIAC...gone...
      2006 Jetta TDI, Package2, Malone Stage 2
      2010 Audi A4 Quattro, Premium Plus
    10. Member Zuber Speed's Avatar
      Oct 7th, 2001
      Ontario
      b7 A4
      12-24-2003 12:31 AM #10
      i changed mine to the exact same stuff at 50,000km and i also changed the the linkage to the TT short shifter. It was a huge difference!. So much smoother, but that could be from the linkage?
    11. 04-14-2004 06:16 PM #11
      This the same for a 02M transmission on a 337?
    12. Member 3WheelGTi's Avatar
      Aug 29th, 2001
      Huntington Woods, MI occasionally
      2009 BMW 335i, 2016 Chevrolet Traverse, 1982 VW Rabbit
      04-14-2004 06:21 PM #12
      Did VW make a switch from tranny fluid being a lifetime item? It always was in the past....are the MKIV cars exceptions?
    13. 04-15-2004 02:27 PM #13
      Quote, originally posted by 3WheelGTi »
      It's no different from the MKIV, however, we know that no tranny fluid (manual or AT) is ever a "lifetime" item, so we tend to ignore VW's advice on this sort of thing. Same goes with the fuel filter.
    14. 04-15-2004 02:41 PM #14
      bump for a nice thread - is this in the FAQ yet?
    15. 04-15-2004 03:08 PM #15
      Quote, originally posted by Bux »
      At 20K your tranny fluid is just broken in. I am planning on changing mine at 100K.
    16. Global Moderator EPilot's Avatar
      Jul 27th, 1999
      NJ
      Present: 16 GTI SE Past: 12 GTI, 99.5 GTI GLX, 95 Golf Sport, 78 Bus…
      04-15-2004 03:08 PM #16
      Quote, originally posted by BananaCo »
      Is now
    17. 06-30-2004 12:30 PM #17
      Quote, originally posted by snarbles »
      ??? yea is it?
    18. 06-30-2004 01:36 PM #18
      whats the capacity for 99.5 vr6 tranny?
    19. Member
      Dec 4th, 2001
      88 BMW M3/2001 BMW 325/ 2003 BMW 330
      06-30-2004 02:12 PM #19
      Does this DIY apply to Automatic transmissions too?
    20. 06-30-2004 02:45 PM #20
      anyone have a DIY for the manual VR6....nothing in the FAQ's...
    21. 07-06-2004 06:34 PM #21
      ANY IDEAS FOR THE JETTA VR6 AUTO TRANNY -NOBODY SEEMS TO KNOW
    22. Member chaosparvus's Avatar
      Dec 5th, 2000
      Washington DC
      2001 VW Jetta
      07-06-2004 10:17 PM #22
      Quote, originally posted by skeller »
      have a look a the auto tranny forum , is under technical.
    23. 07-28-2004 05:32 AM #23
      no filter change?
    24. Member
      Nov 24th, 2002
      CA Bay Area
      66'KG, 69' KG, 94' Miata, 06' Exige
      09-10-2004 03:34 AM #24
      Quote, originally posted by sntx »
      But it's not a bad idea for people the grind a lot. There is no filter for the tranny to filter out any metal shavings.
    25. Member Hi TeK's Avatar
      Jul 26th, 2002
      Bedford NH
      09-10-2004 11:23 AM #25
      I just hit 30,000k on my car was thinking about doing it.. but ill do it just before h2o so next weekend @ some point
