Results 36 to 70 of 99
Thread: FAQ Thread for Sciroccos
  1. Member RoccoRacer's Avatar
    Oct 22nd, 2001
    Logan, UT
    88 Scirocco 16v
    11-08-2007 10:19 AM #36
    Ben
    '88 Scirocco 16v
    (][__][_]===W===[_][__][)
  2. Member JonnyPhenomenon's Avatar
    Jan 27th, 2005
    Lewiston, Maine (USA)
    88 Scirocco, 78 bus, 91 Vanagon
    11-10-2007 10:08 PM #37
    How to fix the stupid reverse gear lockout dissapearance issue
    http://forums.vwvortex.com/zerothread?id=3536691
    Modified by JonnyPhenomenon at 11:53 PM 2-3-2009
    www.rikerstardresser.com - I'm a donor, are you? - www.marrow.org
  3. Member TheTimob's Avatar
    Sep 13th, 2003
    Glenside, PA
    84 Scirocco on Megasquirt
    12-31-2007 01:41 PM #38
    I just posted this in Scirocco Manifesto's cheap performance thread. It may be useful to somebody...
    Remember, 90% of these intake mods only increace throttle response, not horsepower.
    This goes for all throttle bodies, weber, mk2, audi, neuspeed, all that. Sure, they'll flow slightly more, but that doesn't matter because the engine can't use that extra air till you do other mods.... The Weber throttle body has INSANELY quick throttle response - it makes the gas pedal seem on/off - so there's no control anymore- makes the car very hard to drive. Our cars have two plate throttle bodies for a reason - to give them a more civilized ride and even throttle response.
    Best cheap performance - change the exhaust manifold from the toilet bowl to a dual downpipe from an older car. A header is better, but it's also louder and more prone to crack.
    Next? Exhaust. A Catback from TT is nice and cheap. You can get it with a resonator to make the car quiet as stock while being free-flowing. A Dynomax muffler is loud, and will fail quickly. A borla sounds great, restrained, and will last your lifetime.
    Ignition is where some real power is. first step is to get a knock sensing igniton from a newer car and retrofit it in your car. at the same time, get a new cap and rotor, and new plug wires.
    Pistons!! Nobody seems to know about this one - the JH naturally has very low compression. It's like 8.3:1 - which is great for a turbo car, or just running regular gas. Get pistons from an A2 8v GTI like the RD engine code. They are the same piston with smaller combustion chambers to give you 10:1 compression. You can often get a whole 8v engine for dirt, take the pistons, hone your cylinders real quick and swap em in with new bearings in a day with a headgasket change. This one is scarier for new people because it involves tearing the engine in half.
    A Cam is next. Cams can be had new for $100. You can get a g-grind for some euro-performance that's drivable on the street. You can get even more extreme than that too - but the more cam you have, the crappier the idle will be, and the cam might even open the valves enough to hit the pistons in the event of timing belt failure. (8vs are non-interference engines, unless you have a cam with high lift)
    Now, go ahead and do the intake, use a Fox maniflold - it has longer and larger runners, and can fit the larger throttle body. In fact, use the fox's existing throttle body - it's just as big as the Audi 5000 or Neuspeed one, and it comes with the correct linkage already on it. I'm not sure an ABD intake tube will benefit you much, but a new lower airbox will. The largest restriction will still be the CIS airflow meter, and there's not much you can do about that with CIS.
    No replacement for displacment. Get a 2.0. You can get an Audi 3A from a late 80s Audi, 9A 16v block from a Mk2 or Passat, or an ABA from a Mk3. You can bolt the JH head right onto these, or keep the crossflow head from the Mk3. The ABA block is 15mm taller, so you need a different downpipe. The Audi 3A uses a slightly different head design with the injectors in the manifold instead of the head. It flows much better, but there was only an EFI version sold in europe. So the 3A head should be considered CIS-only (unless you are Mtl-Marc)
    Next up? You've done everything cheap now. Time for Fueling. Digifant swap. Digifant however, is not very reliable, and since you now have cams, exhausts, and all that - it's not gonna do much. Megasquirt. You use all Digifant parts - the fuel rail, filter, lines, spark distributor (or use a knock sensor distributor if ya have that - it's the same one) and you can use the sensors. GM sensors for coolant and intake temp are more reliable than VW sensors - that's what I use. Contrary to popular belief, you do NOT need a TPS throttle body for megasquirt. Megasquirt can use manifold pressure readings to do accelration enrichment (adds more gas when you hit the pedal to give a better response)
    What's next? Well, if you have 10:1 pistons, then the next step is ITBs (individual throttle bodies). This is easier with a crossflow head from a Mk3, and it just bolts right on. This is pretty much the pinnacle of naturally asperated 8v performance. Add NOS or alcohol or whatever, but that's it.
    If you have the 8:1 pistons, time to go turbo - there's manifolds out there for the 8v. One meant for a mk3 fits a mk1 fine. I don't know how much boost an 8v can take, somebody else can chime in. Or, you can supercharge it like a G60 - that engine was a 1.8L and it had 160hp stock! Just don't use a G60 charger because they were extremly unreliable and expensive to fix. Eaton makes a good charger, and there are also those turbo-compressor style ones. This will require custom brackets to be made.
    Quote, originally posted by Beakersloco »
    Great post so can you post what applies to the 16V engines.
    Here's the 16v version.... (bearing in mind that I've never owned a 16v)
    A 16v already has the largest sized throttle body one can get, buying a Neuspeed on an audi one is actually a downgrade from here. Remember, a Weber will fit with an adapter, but it's a BAD idea if you drive your car every day.
    Best cheap performance - change the downpipe to a high flow TT unit. A header is better yet, but it's also louder and more prone to crack.
    Next? Exhaust. A Catback from TT is nice and cheap. You can get it with a resonator to make the car quiet as stock while being free-flowing. A Dynomax muffler is loud, and will fail quickly. A borla sounds great, restrained, and will last your lifetime. Make sure you get stainless - 16vs come with a 2" stainless with a resonator STOCK, don't downgrade!
    You may be seeing ads on ebay for a 50mm intake manifold. This sounds cool because the runners are bigger - but bewere. They were on european 16vs from the factory, then VW RECALLED them in europe to replace them with the normal 16v manifold. The larger manifold caused torque loss, and pushed the power band higher up in revs.
    Thinking about an autotech power module or something like that? forget it. It's a waste of money, and it introduces a MASSIVE failure point in the car's running. The way this works is to fake the ECU into making the mixture richer by providing a false input from the coolant temperature sensor.
    16vs already have knock sensing ignition. Make sure everything is in working order, that the knock sensor is working, new cap and rotor, and get some new plug wires. 16v wire sets are rather expensive, so buy one that'll last.
    16vs come stock with high compression 10:1 pistons. Keep them for Naturally aspirated power.
    Cams are next. Cams can be had new for $300. You can get a european set for performance that's drivable on the street. You can get even more extreme than that too - but the more cam you have, the crappier the idle will be. ALL 16v engines are interference engines. When you change the cam, change the belt. And then change it every single year. If you have a large cam, consider a racing timing belt.
    No replacement for displacment. Get a 2.0. 9A 16v block from a Mk2 16v or Passat. You can even make an ABF-like motor out of an ABA from a Mk3. You can bolt the 16v head right onto these. The ABA block is 15mm taller, so you need a different downpipe.
    Next up? You've done everything cheap now. Time for Fueling. Megasquirt. You can use all DigifantIII parts - the fuel rail, filter and fuel pressure regulator - these come from a europe-only ABF mk3 motor. You can also use a custom machined fuel rail from Bahn Brenner, or Ross Machine Racing, or USRT. GM sensors for coolant and intake temp are more reliable than VW sensors - that's what I use. Contrary to popular belief, you do NOT need a TPS throttle body for megasquirt. In fact, I use a 16v throttle body on my 8v. Megasquirt can use manifold pressure readings to do accelration enrichment (adds more gas when you hit the pedal to give a better response)
    A port and polish of the cylinder head can be good for a modded car. a 1.8L head is aparantly better for this because of the way the ports were cast. This is a machine shop service costing usually $1k or so.
    What's next? Well, since you have 10:1 pistons, then the next step is ITBs (individual throttle bodies). This is pretty much the pinnacle of naturally asperated 16v performance. Add NOS or alcohol or whatever, but that's it. You can stroke and bore the motor past 2.0L for something really crazy.
    You can buy low compression pistons, or stack metal headgaskets to go turbo - there's turbo manifolds out there for the 16v. Or, you can supercharge with a turbo-compressor type of super charger, like mr lee has on his 16v, or get a eaton kit from Bahn Brenner. An upgrade for a forced induction car is a short-ram intake manifold to replace the stock one. Turbo cars need power at the top end, short and fat runners help this out. The bigger the intercooler, the better you will be.
    A fully fueled, bored, stroked, ported, polished, camed, blueprinted, tuned and worked up turbo 16v can have more than 500whp.
    Remember, I'm only posting about POWER upgrades. There are more upgrades to be done, such as suspension, brakes, lighting, instrumentation, controls, drivtrain and transmission, and MOST importantly of all TIRES
    Modified by timbo2132 at 9:33 PM 12-31-2007
    Vintage Watercooled Technotes:
    http://www.vintagewatercooleds.com/tech/
  4. Member G-rocco's Avatar
    Sep 10th, 2004
    270 & 495, Maryland.
    Scirocco, Scirocco Passat
    01-02-2008 08:52 AM #39
    Ginsters A2recaros into an A1 thread:
    http://forums.vwvortex.com/zerothread?id=2753265
    Another thread talkin' 'bout recaros and a link to where you can buy brackets to drop the seats in .
    http://forums.vwvortex.com/zerothread?id=3613015
    Covering up sweaty athletic gear smell with fake apple scent is just going to smell like an apple pie wearing a jock strap.
  5. Member TheTimob's Avatar
    Sep 13th, 2003
    Glenside, PA
    01-13-2008 05:14 PM #40
    How to wire Foglights, Including how to make them only able to be on when the lowbeams are on...
    http://forums.vwvortex.com/zerothread?id=3632146
  6. Member badpenny's Avatar
    Jan 13th, 2007
    Hurst, Tx
    82 scirocco, 86 scirocco
    01-24-2008 07:23 PM #41
    Quote, originally posted by timbo2132 »
    This is for an 84.
    The relay numbered 24 according to the Bentley Manual is "Cold start enrichment(July 87 to 89 except 16v)"
    and on the opposite side with the Green and tan circle is "Coolant low-level warning control unit / Idle boost control unit (July 87 - 89 except 16v)"
    And the FUSE position 17 shown with a 10 amp fuse is OPEN, it is for the "knock sensor control unit (16v only)"
    The entire tool selection at Sears or the contents of a Snap-On truck will do you no good if you do not know how to use them.
    Apr 2nd, 2003
    Richmond IN
    02-05-2008 09:59 PM #42
    mkII euro high beam info. 3 different lenses!
    http://forums.vwvortex.com/zerothread?id=1916472
    so we have 3 different lenses
    the 4 adjuster lens 34459R8
    and two 3 adjuster lenses. sounds like the difference between the 3 adjuster 8367R19 and 8368R19 is the addition of a reflector over the front of the bulb. which looks like can be removed.
    and they are definitly left and right specific.
    Modified by weeblebiker at 12:51 PM 2-6-2008
    '87 rocco ,ABA16VitbT, 9a pistons, dual exhaust cams, megasquirt v2.2 2-extra, E85,
    volvo TD0-14T turbo, celica intercooler, corolla manifold, gsxr itbs, water injection, staged injection.
    exhaust cam mod info: http://forums.vwvortex.com/showthread.php?2508013
  8. Member JonnyPhenomenon's Avatar
    Jan 27th, 2005
    07-21-2008 03:24 PM #43
    just thought I would add this to the faq since it wasnt here already. theres another sensor on the head that is missing from this pic..
  9. Member TheTimob's Avatar
    Sep 13th, 2003
    Glenside, PA
    08-18-2008 08:14 PM #44
    This is one of the most common oil leaks: the oil pressure switches. They leak from the spade, a very very tiny hole.
  10. Member TheTimob's Avatar
    Sep 13th, 2003
    Glenside, PA
    08-18-2008 08:23 PM #45
    8v non-A/C alternator brackets (the old stock brackets in my car)
    If you have an 84.5 or later, the lower bracket should be present, but the compressor bracket will be bolted to it.
    Pulley for the waterpump is different. It can be gotten from any fox - even a fox with A/C. It can also be found on some Audi cars.
    Upper bracket
  11. Member scirocco*joe's Avatar
    Feb 23rd, 2002
    Roughly
    things broken
    09-05-2008 01:18 PM #46
    "How to tell if a Mk1 Scirocco is an S, in two parts"
    by sciroccohal and Sciroccojim
    Quote, originally posted by sciroccohal »
    Emblem
    Red bumper stripes
    Red VW
    Front ducted spoiler.
    Specific seat pattern
    Black inst cluster
    Golf ball shifter
    Rear fenderwell carpeting.
    Black out ALUMINUM window trim
    Quote, originally posted by sciroccojim »
    5 Speed trans is standard
    Door cards with speaker holders are standard
    No silver stripes on top edge of tailights/around grille
    Black antenna
    Black drip channel trim
    Black-painted lower rockers
    Black lower rocker trim strips
    Side molding has a red insert instead of silver
    Special stripes on body
    Black metal door handles instead of plastic - no inserts
    Remote side view mirrors standard on both sides
    can someone archive this....so we don't have to repeat it every three weeks?
    There! Happy now, Hal?
    Quote Originally Posted by sin bar View Post
    i don't even understand everything that's going on. i'm simply impressed.
    Philadelphia, PA
    1981 Scirocco
    2010 Sportwagen TDI
  12. Member veetarded's Avatar
    Jul 28th, 2004
    [OO==w==OO]
    09-06-2008 11:28 PM #47
    What's even funnier is that Hal is wrong about the golfball; I'll show you the 100% original *non* golfball knob that was in mine from the factory.
    ...carry on.
    Red Leader - Team Infidel
    The Price of 7reedom is the Willingness 2 do Sudden Battle Anywhere, Anytime an6 With Utter Recklessness
    -Heinlein
  13. Member TheTimob's Avatar
    Sep 13th, 2003
    Glenside, PA
    10-02-2008 07:39 PM #48
    Here is Carl's replace the shiftrod bushing thread:
    http://forums.vwvortex.com/zerothread?id=2465998
  14. Member scirocco*joe's Avatar
    Feb 23rd, 2002
    Roughly
    things broken
    10-06-2008 03:20 PM #49
    Quote, originally posted by TheTimob »
    But the real question is, how do you fix that?
    Philadelphia, PA
    1981 Scirocco
    2010 Sportwagen TDI
  15. Member JonnyPhenomenon's Avatar
    Jan 27th, 2005
    10-06-2008 04:43 PM #50
    thats easy. just replace it. they cost under 10$.
    if you squease the little boot covering it and ti goes squish, then you need to replace it.
    to replace them, they just screw in like a plug. easy to get to, easy to replace. easy peasy.
    Modified by JonnyPhenomenon at 8:16 AM 10-9-2008
  16. Member scirocco*joe's Avatar
    Feb 23rd, 2002
    Roughly
    things broken
    10-09-2008 12:03 AM #51
    Honestly, I had no idea it was so easy. Here's a link to those two pressure switches:
    http://www.germanautoparts.com...150/3
    Philadelphia, PA
    1981 Scirocco
    2010 Sportwagen TDI
  17. Member JonnyPhenomenon's Avatar
    Jan 27th, 2005
    02-01-2009 10:31 AM #52
    I'm trying to compile a list of all the HowTos and DIYs I have done, here is a few of them:
    Phenoms Howtos
    http://forums.vwvortex.com/zerothread?id=4716229 mk2 scirocco shortening na bumpers
    http://forums.vwvortex.com/zerothread?id=4232112 scirocco sunroof power crank conversion
    http://forums.vwvortex.com/zerothread?id=4227385 scirocco window regulators
    http://forums.vwvortex.com/zerothread?id=3536766 16v distributor seal rebuild
    http://forums.vwvortex.com/zerothread?id=3536691 shift finger lockout
    http://forums.vwvortex.com/zerothread?id=4737208 shift linkage troubleshooting
    http://forums.vwvortex.com/zerothread?id=3522111 scirocco dashboard lightbulb repairs
    http://forums.vwvortex.com/zerothread?id=3969521 Scirocco Seat release and bolster repair
    http://forums.vwvortex.com/zerothread?id=4227493 MK2 Jetta, Golf, and Scirocco Sunroof seal
    http://forums.vwvortex.com/zerothread?id=3388674 rocco ac box leak
    http://forums.vwvortex.com/zerothread?id=3348566 polished tails
    http://forums.vwvortex.com/zerothread?id=3841263 Scirocco Boot pad/trunk floor and deck lid.
    http://forums.vwvortex.com/zerothread?id=4574353 Gas hood struts/lifters install
    http://forums.vwvortex.com/showthread.php?5904287 CHEAP Scirocco hatch struts replacement aka gas springs lifts lifters
    http://forums.vwvortex.com/zerothread?id=3762874 mk3 ABS (off topic, I know, but...
    coming Eventually.. maybe
    washer fluid bottle relocation. (using a two way pump and the rear bottle only)
    rocco hood insulation
    speedo removal and odometer rebuild
    Frankenstein transmission
  18. Member JonnyPhenomenon's Avatar
    Jan 27th, 2005
    03-09-2009 12:17 PM #53
    Sloppy shifter?
    probably need to replace the main shift rod bushing, but since these are basically no longer available, you can get an after market replacement part that is about a million times better from here.
    http://www.4crawler.com/Diesel...aring
    there is also a guy who sells a hybrid bushing on ebay that is made from a mk3 bushing with a delrin insert inside of it. thats what I have and it rules.
    http://motors.shop.ebay.com/me...rdc=1
  19. Member 85roccoZ400's Avatar
    Jan 27th, 2002
    Litchfield County, CT
    85 Scirocco 8VT; 2002 VR6 Jetta; 2005 C230 Sport
    03-30-2009 12:10 PM #54
    I looked through this whole thread and didn't see this!
    Figured it be a good link to help those who are in need of fixing a pedal assembly
    http://www.garageprosoftware.c...l.htm
    "Everything is possible to the man who does not have to do it for himself"
  20. 09-26-2009 08:37 PM #55
    just wondering if outer sills are still available from anywhere??just bought a 78 and the sills are missing, haha,
    and i cant find anything about stripping a vw gearbox?
    have boxes from a mk2 rocco and mk2 golf i need to get shifting nice again...
    if anyone could point me the right direction id appreciate it.
    cheers
  21. Member JonnyPhenomenon's Avatar
    Jan 27th, 2005
    09-26-2009 11:49 PM #56
    everything you ever wanted to know about transmissions can be found here. http://www.brokevw.com
    and if you are looking for replacement parts, set up an account at http://www.vagcat.com where you can get exploded diagrams and part numbers of everything VW.
    (or just login with my account, vwvortex/vwvortex )
    then take those part numbers to http://www.worldimpex.com where you can get prices and availability of them.
    but for really old stuff, your best bet might be the salvage yards..
    Modified by JonnyPhenomenon at 4:57 PM 4-20-2010
  22. 09-27-2009 06:54 AM #57
    very handy.
    thanks a million
  23. Member twardnw's Avatar
    Sep 25th, 2006
    Vancouver, WA
    '96 Volvo 850 Tubor, '79 Hilux, '76 Scirocco
    10-14-2009 05:41 PM #58
    You can also check the part numbers for stock at http://www.busdepot.com I have found they will have some really random stuff that is NLA
  24. Member scirockinit's Avatar
    Oct 16th, 2008
    Fred
    82 Scirocco
    10-17-2009 05:26 PM #59
    Can we get the first half fixed please kind of important... None of the links work
    Quick to the SLOW!!
    Fastest you can go 50!
    Wish i had a scirocco..(A. Einstein)
  25. Member JonnyPhenomenon's Avatar
    Jan 27th, 2005
    10-18-2009 01:04 AM #60
    which links dont work?
  26. Member Rannoch's Avatar
    Mar 19th, 2008
    Corvallis, OR
    1992 Subaru SVX, 1983 Wolfsburg Scirocco [Luna], 1976 Mustang Cobra II, 1970 GMC Pickup
    10-18-2009 01:29 AM #61
    Quote, originally posted by scirockinit »
    Those 1-23 items were never links. afaik
  27. Member woody16v's Avatar
    Sep 21st, 2009
    the basement
    87 scirocco16v, 93 festiva (mpg king)
    11-10-2009 12:28 PM #62
    ^ but it would be so very helpful if they were...
    for instance 1, 2, and 3. esp 2 and 3.
    what are the most likely maintenance problems? ive already gatheres there are struggles with the fuel pump, im told 16vs tend to run hot, the hatches leak and stuff like that.
    first upgrades? - there are a few performance faqs but what are a few key weaknesses that are quickly and easily adressed to yeild an efficiently running slightly more powerful, better handling car? say first three upgrades and what to avoid specifically (heard mixed reviews about power modules)
    Modified by woody16v at 10:56 AM 11-12-2009
    ...but then again, i do drive a festiva
    Quote Originally Posted by Eistreiber View Post
    Slow down. Get the Book. Learn.
    Quote Originally Posted by polov8 View Post
    I get a chilly willy when I forget to do my fly up......
  28. Member
    Sep 3rd, 2009
    Orangevale, CA
    '03 Passat V6 Wagon, a 914 and another 914
    12-27-2009 12:52 AM #63
    i agree, make them links or delete them... pointless as text you cant do anything about.
  29. Member JonnyPhenomenon's Avatar
    Jan 27th, 2005
    01-26-2010 01:36 AM #64
    I believe the topics listed that are not links were included in the list to prompt others to provide information on those subjects wherever they could.
    And so: I have written another DIY to help troubleshoot shifting issues.
    Phenoms Howtos : Shift linkage troubleshooting guide
  30. Member TheTimob's Avatar
    Sep 13th, 2003
    Glenside, PA
    02-23-2010 11:39 AM #65
  31. Member fredybender's Avatar
    Nov 17th, 2008
    Montreal Canada
    81 Rocco,80 Rocco track, 81 Rocco Haldex twin charge Berg cup project, 84 Mk1 Jetta coupe
    04-27-2010 10:44 PM #66
    Electrical cheat sheet:
    I have to give the credit to Cabok (a user in a local VW french forum, for taking the time to do this)
    Fixed:
    http://www.angrymods.com/projects/sc...sebox_v0.3.pdf
  32. Member JonnyPhenomenon's Avatar
    Jan 27th, 2005
    05-04-2010 04:12 PM #67
    just thought I would add a couple pictures I took of my rocco cluster the other day. the plastic circuit board on the back of the cluster has some print on it around the plugs that you cant really see unless you take them off.
    this is bound to be useful for Someone... (it was for me)
  33. 07-16-2010 09:26 PM #68
    Yeha,it-is back!! Many thanks,got a speed-o -cable.Pressing -on-
  34. Member RoccoRacer's Avatar
    Oct 22nd, 2001
    Logan, UT
    88 Scirocco 16v
    08-04-2010 01:50 PM #69
    This seems to come up often...so here is how I removed the Power Steering from my 16v.
    http://forums.vwvortex.com/showthrea...power-steering
    Enjoy
  35. Member vwbobby's Avatar
    Apr 5th, 2009
    Central MS
    several mk-1's
    08-24-2010 11:05 PM #70
    so, where do you order those little RED POLYURETHANE pieces used in the front end and elsewhere?
    mk1 Sciroccos forsale vwbobby@hotmail.com
