VWVortex.com - 2000 Jetta TDI-Strange front end noise
    Results 1 to 9 of 9
    Thread: 2000 Jetta TDI-Strange front end noise
    1. 01-21-2003 07:06 PM #1
      I have had a weird noise in my front end for along time. It is when the car is cornering especially on bumps (like pulling in my parking garage). The noise sounds like springs or the suspension flexing. I replaced my suspension with the Eibach Pro-System with dampeners and springs, the noise is still there. We also replaced the upper strut bearings and bushings. Any other ideas because we have to take apart the front end to replace the bumpstops anyway.
      [Modified by WolfsBurg Man, 12:09 AM 1-22-2003]
    2. 01-22-2003 05:16 PM #2
      Is it a creaking noise ? My 99 TDI Golf was doing that brand new. The dealer said couldn't hear a thing. Then I drove a Jetta 4 loaner with 2K on the clock and it was doing the same. The noise disappeared after a while.
      Unless you hear a clunking noise, i wouldn't bother. If it clunks check the threaded caps on the struts for tightness.
    3. 01-22-2003 06:38 PM #3
      Yeah, it's a creaking noise. I also brought it to the dealership and they said it was because of my aftermarket TSW wheels (not). Anyway I replaced my struts and springs and it still does it. I started thinking maybe it was the ABS but it does it even when the brakes aren't engaged. Also, replaced the front factory sway bar and that didn't solve it either. Oh well I guess it's nothing.
    4. 01-23-2003 07:57 AM #4
      swaybar bushings? Did you replace those? My 01 golf had similar problem and thats what it was
    5. Member RISC601's Avatar
      Jul 11th, 2002
      Atlanta, GA
      2009 Audi A5 3.2 6MT
      01-23-2003 01:00 PM #5
      I heard it on my 2002 Jetta when it was brand new. It has 9,000 on it now and the noise is gone.
      2009 Audi A5 3.2 quattro - Ibis White/Linen Beige, 6MT, Premium Pkg, Tech Pkg, Navi w/backup camera, B&O Stereo
    6. 01-23-2003 09:00 PM #6
      i just startedd hearing the same thing from my car and its a 2.0 from 99.5 wierd that i just happen to see this uh!
    7. Member TDItwist's Avatar
      Oct 20th, 2002
      Bothell, WA
      01-23-2003 09:38 PM #7
      I had the same problem on our 2000 Jetta TDI. It started as a creaking and then became a clunk over bumps. It was the anti-sway bar links on the hub/carriers. Just gad to tighten them up. Got 63K on the clock.
    8. 01-26-2003 09:38 AM #8
      On MK4 usually it's one of two things that make noise in the front end.
      The strut mounts or the sway bar links.
      The strut mounts usually do a loud " clacking " noise over bumps.
      The links will groan, squeak and make a funny " tac " noise.
    9. 01-27-2003 09:29 AM #9
      yep, mine does it too, it's a 2000, i'm doing the suspension so i'll start from scratch all over again.. but these noises are annoying anyway..
      ttt
      WTB jetta or golf auto or trade 96 eldorado
      FS 16V Sachs clutch disc brand new part number 112-42078
      WTB aircooled, cheapo
    « Back
