    Results 1 to 2 of 2
    Thread: New Integrated Engineering adjustable camber plates! (MK5/MK6/TT/A3)
    1. 11-11-2013 05:10 PM #1
      NOW AVAILABLE FROM INTEGRATED ENGINEERING
      Our new camber plates are designed with the best performance and reliability in mind to ensure your tire's contact patch is flat on the pavement under hard cornering and acceleration. We spent months refining our camber plate design with countless hours of track, road race, and street driving resulting in the highest quality pieces available on the market.
      Higher grip levels cause further body roll and suspension deflection, to solving this problem requires more camber (leaning the tire in). During aggressive cornering it is absolutely essential to maximizing grip levels by dialing in the required amount of negative camber for your specific tire and suspension combination. Integrated Engineering camber plates allow maximum adjustability of camber.
      IE billet camber plates also provide a strong and stable foundation for your front suspension by replacing the rubber OEM mounts with a steel bearing, this also eliminates unwanted movement under heavy loads.
      Our engineering team spent considerable time to guarantee optimum performance while offering a long reliable life. Care was also taken to achieve these gains without any detrimental effects to daily drivability. To combat failure issues commonly found when using camber plates, our unique design features a heavy duty US sourced Aurora spherical bearing that controls the top of the shock absorber. It is secured in a high strength heat treated alloy steel cup, which has been designed to provide a life time of reliable service.
      INTEGRATED ENGINEERING FES TECHNOLOGY
      In order to combat the spring popping and binding issues so common with many camber plates, our design incorporates a heavy duty thrust needle bearing as well. This has been taken to another level by our Full Environmental Seal technology (FES), completely sealing this bearing from the elements, which keeps your suspension operating smoothly and quietly for far longer than any other solution on the market.
      Maximize your chassis grip levels with your own set of Integrated Engineering camber plates today!
      Fitment guide:
      VW Golf & Jetta MK5 & MK6 2006-2013
      Audi A3 8P 2006 - 2013
      Audi TT 8J 2006 - 2013
      High Performance Automotive Components
      Forged Internals - Valve Train - Race Engines - Intake Manifolds - Billet Accessories - Suspension - Brakes - Fueling
      WWW.PERFORMANCEBYIE.COM / IE FACEBOOK
    2. 02-28-2014 06:40 PM #2
      Rod, an Integrated Engineering local NASA instructor and owner of a 2010 Volkswagen Mk 6 DSG GTI has been daily driving and track racing on a set of Integrated Engineering adjustable camber plates for over 6000 miles now. He has just submitted another review after driving on them for an extend period, click here to read his 6000 mile review on the IE blog.
