VWVortex.com - gearbox swap question
    Results 1 to 13 of 13
    Thread: gearbox swap question
    1. Member vwlennon67's Avatar
      Oct 3rd, 2009
      LITTLE ROCK
      too many
      11-27-2013 11:43 PM #1
      hi lads, i have a mk1 tt quattro 180hp with a 5spd. I'm wanting to convert to 6spd, my question is has anyone done it and what all will i need? i tried to find a poss build thread but no luck...
      thanks
      volkswagens,metal,pbr and the mighty glasgow celtic
      oharaautomotivelittlerock.com
      Oct 26th, 2010
      Little ol UK
      Snailed Vee
      11-28-2013 07:54 AM #2
      Why do you want the 6 speed?
      Your car will be slower as you have to make more gear changers..
      Steve
    3. Junior Member
      May 25th, 2013
      jax Fl
      mk4 gls
      11-30-2013 11:34 PM #3
      Quote Originally Posted by sTT eV6 View Post
      Steve
      sounds like somebody is double clutching granny shifting
      rip paul walker
    4. Member lite1979's Avatar
      Sep 8th, 2005
      North Buffalo
      2001 Audi TT 225 QC
      12-01-2013 02:19 PM #4
      If your current transmission is not broken, drive it until it is, then worry about this swap. There's a lot of info on the TDI forums concerning swapping O2M transmissions, but unless your current transmission is hosed, I wouldn't bother. The only thing you should need is the 6-spd gearbox. Everything else should be identical. Oh, and a shift knob that has the six speeds on it. The shift linkage may need a little adjusting, but you shouldn't have to replace it.
      Oh, and RIP Paul Walker x2.
      Sep 17th, 2009
      2001 Audi TT; 2012 BMW X5 35d; 2001 Dodge Ram 2500 Cummins 24v
      12-05-2013 10:07 PM #5
      Yes, I did it. I kept gears 1-2 from my five speed, and got 3-6 from a DBQ donor from Jeff Bipes. The work was done expertly by Scotty DeWitt at Advanced Automotion in Texas. Sixth gear is basically an overdrive, since the fifth gear ratio was the same in both transmissions.
      I also replaced all shift forks with welds, rather than rivets. I then had all the gears cryo-treated and WPC-treated.
    6. Member
      May 7th, 2009
      A car plant somewhere in Aladamnbama
      01 TT225(daily) 01 TT225(project) 03 GTI 20AE (daily) Occasionally a new model Acura/Honda lol
      12-06-2013 07:37 AM #6
      Quote Originally Posted by lite1979 View Post
      That's true, for a 180Q, then all he would need is the transmission itself. However if it's an FWD TT, he'll need the starter, slave TO bearing combo, clutch/FW/PP, axles, motor mount bridge, and the linkage on top of the transmissions. You don't have to change the slave line like a lot of people say you do. Depending on which linkage he gets, he may need new cable ends (ball and socket vs pin and clip style). The in car shifter works fine, and you don't have to change the knob from 5 to 6 unless you want.
      Jun 23rd, 2007
      Central NH/Southern ME
      '04 225 TTQ Roadster
      12-06-2013 09:43 AM #7
      Quote Originally Posted by vwlennon67 View Post
      Quote Originally Posted by 20v master View Post
      Is your car a 180 FWD or 180Q?
      mk1 tt quattro 180hp 5sp seems to read like a quattro to me...
      Jun 23rd, 2007
      12-06-2013 12:08 PM #8
      unless his car is a 180Q, then all he would need is the transmission itself.
      So he'll need more than just the transmission itself.
      See, now there you go confusing me again. Which is it? Just transmission, or transmission and more?? ;-)
      May 7th, 2009
      12-06-2013 12:15 PM #9
      Quote Originally Posted by quattrosNrabbits View Post
      Man, I'm 0 for 2 in this thread. I deleted the other post, if he's a 180Q, all he needs is the trans.
    10. Member
      Sep 17th, 2009
      12-06-2013 01:41 PM #10
      When I did it on my Quattro, all that was needed was the transmission & donor. My DieselGeek Sigma 6 short shift kit swapped over from the 5-spd to the 6-spd without any modification. No different or new cables or linkages were required. See below images for parts list and gear ratios (note that the later receipt is because Imola had to have Scotty rebuild the transmission a second time, because they forgot to torque the drain plug).
    11. Member vwlennon67's Avatar
      Oct 3rd, 2009
      LITTLE ROCK
      too many
      12-06-2013 07:01 PM #11
      thanks lads. there is nothing wrong with my 5spd gearbox, i have a built motor and big turbo setup we are going to install... my issue was i was looking for a lsd for the 5spd and couldn't find one anywhere... i had a look and the 5 and 6 spd box look very similar i just wasn't sure if there was any differences with the axles,starter and such... not really sure what I'm gonna do just yet, i have been through and rebuilt plenty of o2m and o2q boxes so i know them well enough.
      May 7th, 2009
      12-06-2013 08:10 PM #12
      You should be able to put the six speed 02M LSD in the five speed 02M, Q trans = Q trans as long as it's not R32 = VR6 bellhousing.
    13. Member vwlennon67's Avatar
      Oct 3rd, 2009
      LITTLE ROCK
      too many
      12-06-2013 10:32 PM #13
      Cool... I wondered because the case looks very alike. I may pull the trigger and get one and see if it works
