VWVortex.com - FS - 2012 Golf R Black 2 Door Base, custom turbo, Brembos, coilovers, 19s yada yada yada
    Page 1 of 2 12 LastLast
    Results 1 to 25 of 32
    Thread: FS - 2012 Golf R Black 2 Door Base, custom turbo, Brembos, coilovers, 19s yada yada yada
    1. Member Atl-Atl's Avatar
      Jun 6th, 2006
      Denver
      2008 Ram 2500
      12-21-2013 05:22 AM #1
      SOLD
      A lot has gone into this car; blood, sweat, tears and lots of coin. All of those things being mine. If you haven't read the build thread, do it. You'll realize I did all the work myself except for the custom turbo setup. I know this car inside out, its runs like an absolute beast but still has 100% stock like drivability. Thanks be to Jeff and Matt at United Motorsport for that!
      The basics. On 91 octane at 5000 feet above sea level it put down 380 wheel horse and 390 wheel torks. The fastest I've gone in the 1/4 mile at this elevation is 13.4@108ish on 91 octane with heavy as F 19" VMRs. That doesn't sound fast but everything goes insanely slow up here. On race gas I'm sure it will put down well over 400 of each and it will go deep into the 11s in the 1/4 mile at sea level. You might be shopping for a bottom end then. It's fast, its loud, it looks cool/turns heads/gets thumbs ups on a daily basis. It gets over 30mpg on the highway. The car is not perfect, I drive it a lot and I drive it hard. It was built to reliably handle the power and aggressive driving that I do. It just passed 35,000 miles and the price I'm listing it for reflects this. Technically it still has a warranty but, you know, just look at it. They laugh when I pull into the dealership for warranty work. Its black so if you need the paint to be perfect move along. It still manages to win awards at shows. It has been the subject of a few professional photo shoots, some of which I still haven't seen the pics from yet! I will gladly re-spray the front bumper which I plan to do anyway this spring when I fill the license plate holes. Yes, it has front license plate holes, sorry. The custom turbo setup is based around an APR stage 3 GT2871R and an APR manifold but the rest was built by Gabe at Bluewater Performance in Denver. The car was custom tuned on a 4wd dyno at my elevation by Jeff and Matt at United Motorsport. I will gladly help you get the car retuned for your elevation. The car has only seen snow a few times and has spent the vast majority of its life in a heated parking garage. It is currently registered in Wisconsin where it does not have to pass emissions so the car does not have a catalytic converter. If you need to pass emissions a cat can be installed and the tune can be tweaked so it passes. I am not trying to hide anything. The car is far from perfect. I purchased the car new in March of 2012, it was one of the first Golf R's in the US, it has a December 2011 build date.
      Misc.
      • NewSouth boost gauge mounted on the steering column.
      • Minor vagcom tweaks like keyfob window roll up.
      • Chopped shifter stalk.
      • The front fenders have been rolled and pulled and the liners slightly trimmed.
      • The rear crash beam has a custom hitch welded onto it that I was going to use to hold a bike rack. I never used it but the receiver is there. Its hidden behind the license plate, nobody knows its there. I will gladly put a new stock crash beam on it.
      • The car is featured on VMR's website.
      • The underside of the front bumper cover has a decent scrape in it from pulling into my old parking garage. You cant see it, its on the underside and now its covered by a Home Depot lip spoiler that actually looks kinda ok.
      • If I think of other things Ill add them.
      Exterior
      • De-badge rear R emblem
      • Black VW emblems front and rear
      • Factory black textured mirror caps
      • Plasti-dipped rear valence, grille and front bumper inserts
      • Tinted windows, Llumar 35% all around with 5% windshield strip.
      • Paint matched side markers
      • Replica LED tail lights, I have the stocks if you want them.
      • Opti-Coat done by Lui at AutomobileDaySpa
      Drivetrain
      • BSH torque mount insert
      • TyrolSport rigid subframe collars. Have, but not installed, you can have them.
      • Diesel Geek Sigma Six short shifter
      • K-Sport Kontrol Pro coilovers, I have the complete stock suspension if you want it.
      • 19" VMR V709s with 235-35-19 BFG KDW's
      • Brembo 18Z big brake kit
      • 80mm Stud conversion
      Engine
      • United Motorsport custom big turbo tune with all the fixins like Launch Control, No Lift Shift, adjustable boost etc.
      • BSH Catch can
      • HEP aluminum coolant expansion tank
      • Custom MAF housing/intake w/evoms airbox
      • Custom downpipe
      • APR exhaust manifold
      • gt2871r
      • 42 Draft Designs catback with gloss black tips
      • Autotech HPFP internals
      • Godspeed Intercooler
      • CTS throttle body pipe
      • R8 red top coilpacks and red wiring harness cover
      • Spec Stage 3 clutch
      $35,000. Try me, I'd love to call your bluff.
    2. Member Siliconrane's Avatar
      May 19th, 2009
      Aguadilla, PR
      2017 Golf R - Lapiz
      12-21-2013 11:25 PM #2
      Give to me your stock suspension . . . My car has almost 60K miles on it . . . about time to change out the Gas Tubes.
      2017 Golf R DSG w/ DCC / NAV / DAP (Unitronic Stage 2 ECU / TCU) Unitronic MQB Intercooler, Unitronic MQB AWD Downpipe. -->Build Thread<-- Project Sleepy R (Ultimate OEM+)
    3. Member Atl-Atl's Avatar
      Jun 6th, 2006
      Denver
      2008 Ram 2500
      12-22-2013 12:59 AM #3
      Quote Originally Posted by Siliconrane View Post
      If you are serious you can absolutely have it for the cost to ship.
    4. Member Atl-Atl's Avatar
      Jun 6th, 2006
      Denver
      2008 Ram 2500
      12-23-2013 09:59 PM #5
      Cant believe I forgot to put this in the thread. Its bump-subject worthy.
      91 octane...yes 91 octane, no meth, 5000 feet above sea level, GT2871R. Thanks go to Gabe and Hollywood at Bluewater Performance and Jeff at United Motorsport.
    5. Member Atl-Atl's Avatar
      Jun 6th, 2006
      Denver
      2008 Ram 2500
      12-29-2013 10:41 AM #7
      I have found my next project and I'm prepared to make a stupid deal. If you are on the fence, contact me.
    6. Member Atl-Atl's Avatar
      Jun 6th, 2006
      Denver
      2008 Ram 2500
      12-31-2013 03:19 PM #8
      Bumpity because the car is starting to generate some interest and I'm starting to get scared.
    7. Member lorge1989's Avatar
      Sep 3rd, 2008
      Buffalo, New York
      '88 Audi 90 20V(handofgod) MS3X | '94 Audi 90 V8
      01-02-2014 01:19 PM #9
      Seriously awesome car. Not in the market, just wanted to say GLWS.
    8. 01-03-2014 12:30 AM #10
      looks awesome, just got my pic-fix-bump
    9. Member jamerican1's Avatar
      Dec 8th, 2005
      VA
      2008 A4 S-Line Titanium QTM, 2000 A4 QTM, 1993 Audi 90S (sold), 1992 Toyota Corolla
      01-03-2014 01:07 PM #11
      GLWS! Wish I was in the market
      Unf*ckwithable
    10. Member mikegilbert's Avatar
      Nov 29th, 2006
      Los Angeles
      328D / TDI / LWB
      01-06-2014 03:23 AM #13
      Damn that looks good! GLWS
      PM Travy℠ |flickr | mikegilbertphotography.com | Everything you need to know | » | Scratch-It™ | Vimeo
      Great, a Chevy Lumina thread. Now I'm going to have an erection lasting more than four hours.
      #FREEPATRICKMAN
    11. Member
      Nov 19th, 2006
      Houston
      '03 GTI 1.8T
      01-08-2014 04:05 PM #15
      Thats nice. I like that you didn't go overboard on anything and kept the looks low key.
      I'm not in the market right now but I like yours alot.
    12. Member Atl-Atl's Avatar
      Jun 6th, 2006
      Denver
      2008 Ram 2500
      01-09-2014 12:50 AM #16
      Quote Originally Posted by Lythandra View Post
      Thanks!
      Also bump because some jerk decided to flag my craigslist ad!?! WTF
    13. Member BoostedCC-R's Avatar
      Jul 8th, 2010
      Cleveland, OH
      B7 RS4
      01-15-2014 06:17 PM #18
      what are you in the market for?
      2007 Audi RS4 - Milltek Full Non-Res | JHM tune | JHM phenolic spacers | JHM shift kit | Bilstein PSS9 | 20x10.5 BBS CH-Rs
    14. Member Atl-Atl's Avatar
      Jun 6th, 2006
      Denver
      2008 Ram 2500
      01-15-2014 08:29 PM #19
      Quote Originally Posted by BoostedCC-R View Post
      I'm open to pretty much any vehicle with 2 or 4 wheels that's motorized and cool/weird/fun/interesting. There are a few things locally I am hoping are still around once I have the cash in hand.
    15. Member -RocknRoll-'s Avatar
      Jan 5th, 2012
      North Texas
      2001 S4(Sold), 2012 RB Golf .:R
      01-17-2014 12:31 PM #20
      One of my favorites
      Good luck on your next project!
      2012 RB Golf R APR Stage2+
      19" OEM peelers
      //H&R coils//VWR sway bars//RSC TBE//Haldex race cont.
      Southbend clutch
      //RNS-510//OEM led tails//APR Intercooler//F-R Piano black emblems
      //R8 coils//NGK plugs
    16. Member Atl-Atl's Avatar
      Jun 6th, 2006
      Denver
      2008 Ram 2500
      01-17-2014 11:28 PM #21
      Quote Originally Posted by -RocknRoll- View Post
      One of my favorites
      Thanks!
      Bored at work on a Friday night bump.
    17. Member mfbmike's Avatar
      Feb 5th, 2011
      Miami, FL
      996 911 Turbo, E46 325i Sedan
      01-18-2014 03:50 AM #22
      GLWS
      Current: 996 911 Turbo, E46 325i, MK7 GTI
      Past: E30 325i, B6 A4, NA Miata, FR-S, MK5 R32, MK1 Rabbit
    18. Member Atl-Atl's Avatar
      Jun 6th, 2006
      Denver
      2008 Ram 2500
      01-18-2014 04:17 AM #23
      Quote Originally Posted by mfbmike View Post
      GLWS
      Thanks
      Aaand for the second time someone has flagged my craigslist ad for removal. This is getting annoying.
    19. Member speeedfrk's Avatar
      Nov 9th, 2004
      miltown, wi
      12 Golf R, 13 Jetta, 67 Lincoln Continental
      01-21-2014 04:48 PM #25
      So did this go down today?
      Sent from my Nexus 5 using Tapatalk
