VWVortex.com - 02 Audi TT Dyno
    Results 1 to 16 of 16
    Thread: 02 Audi TT Dyno
    1. Member BeasTToftheEast's Avatar
      Sep 20th, 2007
      New York, NY
      02' Audi TT Quattro stroked to 2008cc with a PTE6266 Twinscroll
      01-23-2014 12:01 AM #1
      * Chassis: MK1 Audi TT
      * Turbo: HTA 3076r .82 A/R
      * Displacement: 2008cc
      * Software: Eurodyne Maestro 7
      * Injectors: Injector Dynamics 1000cc
      * Exhaust Manifold: Custom Tubular Manifold
      * Intake Manifold: SEM
      * Cams: Cat Cams 3658
      * Purpose: Daily Driver on beast mode
      free screen capture
      free pic
    2. Member BeasTToftheEast's Avatar
      Sep 20th, 2007
      New York, NY
      01-23-2014 12:02 AM #2
      One thing I forgot to mention, the 514 AWHP was made on 26.5 psi and had only 4 degrees timing pull and no o2 correction
      Oct 10th, 2011
      Anywhere Uncle Sam Wants, USA
      2002 TT225Q GT3076r, 2006 A3 Sline VR6, 2012 S4
      01-24-2014 03:49 AM #3
      Awesome numbers. I hope to hit 450 on a .63 a/r. Is that a Small port head?
      Sent from my HTC One using Tapatalk
      GT3076r, .63/ar Tial Vband, Siemens Deka 870cc injectors, Bosh 044 Inline FP, FMIC, TiAL Q 50mm BOV, TiAL 44mm WG, Custom Catch Can, Wideband Conversion, Eurodyne Maestro 870cc Mafless Tune, VMaxx Coils, Gruven Parts Adj. CA top n bottom, VF Engineering All 3 Mounts, Southbend Stage 5 Clutch w/ DMF.
    4. Member BeasTToftheEast's Avatar
      Sep 20th, 2007
      New York, NY
      01-24-2014 09:25 PM #4
      Yes it's small port
    5. Member REPOMAN's Avatar
      May 3rd, 2001
      Portland OR
      1990 VW Corrado
      01-25-2014 05:29 PM #5
      That is fantastic.
      I've made 425whp with a 3076 .63 on my 16v. 034 waste spark
      You only pulled 4 deg of timing?
      I know the bore size and combustion chamber design determine the ignition curve
      I'd like to compare you map to where mine is.
      I have been conservative due to no DET detection on my setup.
      I have been studying the Maestro 7 software and I am planning on swapping in a AWW OBD2
      EFI into my ride. Super sequential and knock control w/ IAC is what I want.
      500HP 1990 Cowrado
      Have a great Orwellian Day
      https://www.youtube.com/user/RepomanPro
    6. Member BeasTToftheEast's Avatar
      Sep 20th, 2007
      New York, NY
      01-25-2014 06:22 PM #6
      Well I have to give all the credit to Marc at VAP Motorsports in Fort Myers. They are doing some great work over there.
      May 15th, 2010
      Bulgaria, EU
      01-26-2014 04:55 AM #7
      So, about 550hp at the FW!? At 26.5psi and 7300 rpm, ... pump gas !? High numbers are always a ... motivating factor. I'd try to back up these numbers on another brand dyno though. May be 70-80hp less would look more realistic imho.
    8. Member BeasTToftheEast's Avatar
      Sep 20th, 2007
      New York, NY
      01-26-2014 09:32 PM #8
      First of all awd cars lose about 25% through the drivetrain which would make around 640 to the crank. Second of all it wasn't just pump it also had direct port meth injection. Last Dynojet when setup properly are usually no more than a +-5% off actual hp output, but then again no company that produces dynomometers does enough R&D to be considered the industry standard. So it's really a moot point. The only purpose a dyno really has is tuning against yourself and constantly making progress.
      Sent from my SPH-L900 using Tapatalk
    9. Member BeasTToftheEast's Avatar
      Sep 20th, 2007
      New York, NY
      01-26-2014 09:33 PM #9
      R & D
    10. Member
      May 15th, 2010
      Bulgaria, EU
      01-27-2014 06:10 AM #10
      That's 100% correct. It is a moot point but if the difference is up to 30-40...50hp with the common sense. 640hp(even 550)@the crank at 26.5psi/2008cc/ 7300rpm - NO f'king way! WMI is not a +100hp miracle. Your 3076 can support 550hp. 25% AWD loses is plain BS (I'm sorry to say that). Whoever told you that, it is far away from the reality and only serves unfulfilled power goals.
    11. Member BeasTToftheEast's Avatar
      Sep 20th, 2007
      New York, NY
      01-27-2014 07:39 AM #11
      Maybe a GT3076r however apparently you aren't well versed with the HTA turbos. They produce 8lbs more flow per minute and spool considerably quicker. Also awd setups do lose anywhere from 20-25% sometimes more. Last wmi is not the save as race gas obviously, but it would effectively bring the octane up to almost 100 and aggressively lower intake temps especially with direct port jets. All of those details taken into consideration kind of throw your mentality out the window.
      May 15th, 2010
      Bulgaria, EU
      01-27-2014 04:09 PM #13
      Sure, your WMI lowers mostly the cyl temps but also takes part of the place for the incoming air. WMI doesn't burn neither add O2 to the mixture, and you do need much more O2/air than 59lb for 640hp. Just think about it. At 26.5 psi and 7300 rpm your engine just doesn't receive enough air for the stated power level.
      Look man, I'm not offensive. It is simple math behind that. It is not compulsory to accept my point. Everyone is free to believe whatever he/she wants.
      Cheers!
    13. Member BeasTToftheEast's Avatar
      Sep 20th, 2007
      New York, NY
      01-27-2014 04:27 PM #14
      http://www.dynojet.com/about_us/testimonials.aspx
      I'm sure all these reputable guys were paid to compliment Dynojet on their equipment lol.
    14. Member ray32's Avatar
      Apr 26th, 2008
      NNJ
      BMW HAMANN-X6 HPA\\\BORGWANER EFR: BUILT motor~MK4 R32
      01-28-2014 05:49 PM #15
    15. Member BeasTToftheEast's Avatar
      Sep 20th, 2007
      New York, NY
      04-01-2014 02:04 PM #16
      Thanks
