    Results 1 to 3 of 3
    Thread: Dies on deceleration, sputters over 5 psi, help needed..
    1. Member kueckerdj09's Avatar
      Jun 1st, 2011
      Omaha, NE
      20th GTI
      02-15-2014 12:32 AM #1
      I have a unique problem with my GTI that I need some help figuring out. I'm going to check over my vacuum lines tomorrow and boost piping, but something just doesn't add up
      - It won't boost above 5psi without sputtering and backfiring
      - On deceleration it has a tendency to die, I've watched the vacuum drop close to -30 in Hg before it dies.
      The odd thing is this...
      - At idle. vacuum stays between -20 and -21 in Hg.
      - In 4th gear around 45-50, the car will build boost to 20 psi and hold. (on a few rare occasions, it will feel like its sputtering under load but no check engine light or misfire)
      I have the following
      EVAP/SAI Delete (only 3 real vacuum hoses... brake booster, FPR, and DV)
      F21 Frankenturbo
      550cc Injectors
      3" MAF
      Eurojet FMIC
      Eurodyne Software
      I have not touched the software except for the addition of the 2-step option to the base file for my car. Any help or guidance would be appreciated.
    2. Member DMehalko(DM)'s Avatar
      Nov 1st, 2004
      Colorado
      All sorts of VW's
      02-15-2014 04:28 PM #2
      Bad leak somewhere (boost or vacuum)
      Fouling spark plugs (or need a tighter gap)
      Dying coilpacks? (Would probably cause a CEL though)
      Clogged Cat?
      2003 Tornado Red Jetta AWP
      2009 Campanella White Jetta
      2001 GTI VRT (Sold )
    3. Member kueckerdj09's Avatar
      Jun 1st, 2011
      Omaha, NE
      20th GTI
      02-15-2014 09:07 PM #3
      Quote Originally Posted by DMehalko(DM) View Post
      Clogged Cat?
      Installed new plugs, gapped to .028"
      New coil packs installed
      Catless Downpipe
      No boost leaks, checked all the piping.
      I found a small leak on the N75 valve.
      It appears to be working right now at this time
