VWVortex.com - Suspicious camshaft sensor wiring
    Page 1 of 2 12 LastLast
    Results 1 to 25 of 48
    Thread: Suspicious camshaft sensor wiring
      Jan 27th, 2014
      Hayward, California
      2000/VW/Jetta 2.0L
      02-18-2014 02:29 PM #1
      Hi! I just bought a 1999.5 Jetta MK4 2.0L AEG with 160k miles.
      I opened up the engine yesterday to work on the camshaft sensor as it was throwing code P0341.
      I removed the old one and I am waiting to day to receive a new sensor. In any case, I noticed the wiring that goes to the sensor:
      I noticed the connector on the left has three wires. On the right, the wires run to the ECM but you can notice the violet/yellow (it's hard to properly see colors, sorry) seem to have been cut and connected to a black one. Is this what I should expect? Or somebody made a mess trying to fix things before? What would you advice - if somebody has a AEG and could check the wiring/take a picture of it...
      The connector is located not too far from the spark plug of cylinder 1:
      Mar 6th, 2002
      Morris Plains, NJ
      1998 GTI 2.0T
      02-19-2014 11:18 AM #2
      Why are you replacing the cam sensor to begin with? Did you diagnose it or just have a code and assume a bad sensor?
      Verify that there is continuity between the cam sensor connector and the appropriate pins on the ECU. If there is, the wiring is good. That splicing method is questionable though.
      2012 Corolla
      1998 GTI 2.0T
      World Automotive
      Jan 27th, 2014
      Hayward, California
      2000/VW/Jetta 2.0L
      02-19-2014 12:40 PM #3
      Hi Anony00GT.
      I am replacing the sensor as I got a P0341 code. I can clean the code, drive a bit - I do not get the code again - but next time I start the engine the code comes back. After some research on the forums, it seems that some people fixed the issue just by replacing the sensor.
      I have found the page on the "Bentley" manual that shows the electric connections. Last night I have followed that spliced black wire and it goes all the way close to the wipers motor, just under the windshield. I'll have to open that part to check for continuity. Thanks for the advice!
      As you say that splicing is questionable, assuming it was done because the original wiring was damaged, what kind of technique would you have used to repair it properly?
      Thanks!!!
    4. Member
      Mar 6th, 2002
      Morris Plains, NJ
      1998 GTI 2.0T
      02-20-2014 08:27 AM #4
      W-crimps are the best way. Soldering is good as well, provided you know how to solder. A bad soldering job can be just as bad as a broken wire. Either way it should be covered up with heat shrink. Butt connectors are a big no-no (looks like that's what was done to yours). But then again, if it works, leave well enough alone I guess.
      You shouldn't have to physically follow the wires. Disconnect the cam sensor and ECU connector, use wiring diagrams and an ohmmeter at both ends to check wire integrity.
      Your symptoms (P0341 returning on the second start every time) is actually indicative of the timing belt being off a tooth moreso than a bad sensor. Either way it should be fixed now when you get it all back together
      2012 Corolla
      1998 GTI 2.0T
      World Automotive
      Jan 27th, 2014
      Hayward, California
      2000/VW/Jetta 2.0L
      02-20-2014 12:48 PM #5
      Yes... I know how to solder I will fix that connection and apply proper insulation.
      My point about following the wire is that it goes in an area under the windshield where I can see other wires and connectors. I will have to open it up to check continuity.
      About the timing belt being off one tooth: how can I check that? Of course I have placed my own marks on the timing belt/sprocket but how can I know if the previous owner - that told me he's changed the timing belt himself - skipped a tooth?
    6. Member
      Mar 6th, 2002
      Morris Plains, NJ
      1998 GTI 2.0T
      02-20-2014 01:43 PM #6
      Just unplug the ECU connector, no need to open up the wiring harness more than that if you've got a service manual with diagrams.
      Now that the timing belt is off, you can't tell. But you should be using the factory marks, not marks you made, to line it back up. There's a mark on the flywheel and a mark on the cam gear.
      2012 Corolla
      1998 GTI 2.0T
      World Automotive
      Jan 27th, 2014
      Hayward, California
      2000/VW/Jetta 2.0L
      02-20-2014 02:59 PM #7
      OK, I will have to find the ECU - I do not know its position now.
      As per the timing belt: I will reinstall it with my marks on the camshaft sprocket (I made it sure it could not slip on the crankshaft), then align the marks to see if they are off. Most guides and DIY on the forums use the nailpolish mark technique instead of using the factory marks... I'm learning!
      Mar 6th, 2002
      Morris Plains, NJ
      1998 GTI 2.0T
      02-20-2014 04:17 PM #8
      That's the problem with reading DIY's on the internet vs the proper procedure in the service manual. People in the know wrote the manual. People working under an oak tree while drinking beer wrote the internet DIY's
      I'd recommend you just bring #1 to TDC and start over, disregard your marks. You can turn the crankshaft all you want with the cam removed.
      2012 Corolla
      1998 GTI 2.0T
      World Automotive
      Jan 27th, 2014
      Hayward, California
      2000/VW/Jetta 2.0L
      02-20-2014 04:27 PM #9
      Oh true, the valves will stay closed without the camshaft installed. Scary!
    10. Member
      Jan 27th, 2014
      Hayward, California
      2000/VW/Jetta 2.0L
      02-21-2014 12:39 PM #10
      So just to make sure... I will likely perform the procedure tomorrow. I rotate the crankshaft so cylinder 1 is on TDC by checking the mark on the flywheel. At the point, I will carefully reinstall the camshaft so it has the notch aligned to the mark on the engine. Once it is in, I will reinstall the timing belt; the nailpolish marks I have made should match or be off one tooth maximum. If they do not, something is wrong...
    11. Member
      Mar 6th, 2002
      Morris Plains, NJ
      1998 GTI 2.0T
      02-21-2014 01:46 PM #11
      Well, was the engine at TDC when you made the marks? If not, your marks will never line up.
      You are correct. Bring #1 to TDC, then install the cam so the valves on cylinders 1 and 4 are not open. Then re-install the valve cover and line up the mark for the cam.
      If you're paranoid, rotate the crankshaft backward 45* before installing the cam, that'll bring all the pistons off TDC so nothing will hit and you can turn the cam as necessary to align it once installed.
      2012 Corolla
      1998 GTI 2.0T
      World Automotive
      Jan 27th, 2014
      Hayward, California
      2000/VW/Jetta 2.0L
      02-21-2014 02:07 PM #12
      I cannot assume #1 was at TDC when I made the marks, but I made sure the belt has not slipped from the crankshaft, so I expect to turn the crankshaft and then install the camshaft in a position that won't be too far off the original markings I made...
      Good idea to carefully rotate the cylinders away when installing the camshaft, I'll see if that makes it easier.
    13. Member
      Jan 27th, 2014
      Hayward, California
      2000/VW/Jetta 2.0L
      02-23-2014 12:11 PM #13
      So... it happens that I cannot find where the inspection hole is on the manual transmission to see the notch on the flywheel. What do I have to take apart to access it?
    14. Member
      Jan 27th, 2014
      Hayward, California
      2000/VW/Jetta 2.0L
      02-23-2014 01:34 PM #14
      OK nevermind I removed the air filter box and now I can see it... let's see if I can find the mark now...
    15. Member
      Jan 27th, 2014
      Hayward, California
      2000/VW/Jetta 2.0L
      02-23-2014 03:25 PM #15
      OK I think I have aligned it... I'll check through the spark plug hole too, but do you think this is correct?
    16. Member
      Mar 6th, 2002
      Morris Plains, NJ
      1998 GTI 2.0T
      02-24-2014 08:28 AM #16
      Looks right. Some flywheels have a "-0" though. Verify through the spark plug hole that #1 is at TDC.
      2012 Corolla
      1998 GTI 2.0T
      World Automotive
    17. Member
      Jan 27th, 2014
      Hayward, California
      2000/VW/Jetta 2.0L
      02-25-2014 01:41 AM #17
      I verified through the spark plug hole and I am at TDC indeed. So I started trying to put the camshaft back on but I've probably been careless... and I broke the new camshaft sensor. It's made of plastic and I have applied the wrong leverage with the sprocket and I broke it.
      Now, I'm looking for advice; first of all, it would be much easier if I could install the camshaft without the sprocket, but I do not have the tool to hold the sprocket and prevent it to rotate when applying the substantial torque required for its bolt. How should I proceed?
      Second, should I rush order a new camshaft sensor or is there a way to test the original one, that maybe is not broken, and the code P0341 came up because the timing was wrong?
      By the way, I have tested the electric continuity for that wire that was repaired, camshaft sensor connector to ECU connector, and it's good.
      Thanks
    18. Member
      Mar 6th, 2002
      Morris Plains, NJ
      1998 GTI 2.0T
      02-25-2014 09:04 AM #18
      I've never removed the entire camshaft to service the sensor, always just removed the gear from the cam, I've never even touched an intake of valvecover to do it. Don't know what to tell you there, except be more careful, and if you're going to do a job, you need the correct tools to do it.
      Why not try the old sensor, since you're in a bind anyway? Worst case scenario is you have to order a new sensor and pull the gear off again, it's not that hard to do.
      2012 Corolla
      1998 GTI 2.0T
      World Automotive
    19. Member
      Jan 27th, 2014
      Hayward, California
      2000/VW/Jetta 2.0L
      02-25-2014 11:09 AM #19
      OK but which tool do you use to hold the gear while working on the bolt? Do you have the special VW tool?
    20. Member
      Mar 6th, 2002
      Morris Plains, NJ
      1998 GTI 2.0T
      02-25-2014 01:14 PM #20
      I have an air gun and swivel socket
      2012 Corolla
      1998 GTI 2.0T
      World Automotive
    21. Member
      Jan 27th, 2014
      Hayward, California
      2000/VW/Jetta 2.0L
      02-25-2014 01:27 PM #21
      Oh in that case you do not need to hold on to the sprocket? Won't an air gun make the sprocket rotate anyway?
    22. Member
      Mar 6th, 2002
      Morris Plains, NJ
      1998 GTI 2.0T
      02-25-2014 04:34 PM #22
      No. An impact gun won't make anything rotate except the bolt.
      2012 Corolla
      1998 GTI 2.0T
      World Automotive
    23. Member
      Jan 27th, 2014
      Hayward, California
      2000/VW/Jetta 2.0L
      03-01-2014 10:28 PM #23
      So I got a new sensor, installed it, and installed the camshaft too. I build a tool to hold the sprocket and tighten its bolt to 74ft*lbs. All has been very smooth. I installed the new valve cover gasket with the required sealant. I used three different torque wrenches to tighten all bolts correctly. Very nice.
      I then moved the crankshaft to TDC (as you suggested, I moved it away a little when installing the camshaft) and mounted the timing belt on the sprocket. I had to remove it and move it forward a tooth as the camshaft alignment was slightly off. Am I correct to say that when the timing belt tensioner is set it "pulls" the camshaft sprocket a little counterclockwise, so when I put the timing belt on I have to keep the mark about one tooth to the right? In other words, what matters is the alignment of the sprocket when the timing belt is tensioned, not before?
      This said, I am having a very hard time to fully set the tensioner. I can tension it about half way through but more than that the tensioner itself rotates !?!? So far I tried with a 45deg long reach pliers and a small tool I've built myself with two pins about 16 mm apart. Advice?
    24. Member
      Jan 27th, 2014
      Hayward, California
      2000/VW/Jetta 2.0L
      03-03-2014 02:40 AM #24
      So I removed the engine mount to have better access to the tensioner. It's now much easier to work on it... can I set it and make sure the timing belt is OK (rotating several times the cranckshaft) without the engine mounts and then close everything? I am still not 100% sure this tensioner is perfectly good, maybe I should replace it, but I'd rather do that without the engine mounts if possible...
    25. Member
      Mar 6th, 2002
      Morris Plains, NJ
      1998 GTI 2.0T
      03-03-2014 08:08 AM #25
      The engine mount has nothing to do with the timing. Yes you have to remove it to change the belt, but that's as far as the relationship goes.
      2012 Corolla
      1998 GTI 2.0T
      World Automotive
