    Results 1 to 4 of 4
    Thread: Idle boost pressure 83 GTI Callaway
    1. Member ejackson_5's Avatar
      Jul 10th, 2006
      Portland, OR
      83 GTI
      02-25-2014 10:05 PM #1
      So I've been working on several things with my GTI and today started it for the first time in a while. Noticed that the gauge read like -20 pounds at idle. Is that normal? I don't have a ton of experience with this set up but know that it is an almost 100% original Stage 2 set up. Any help much appreciated. I like to get this thing on the road some day soon.
    2. Member marshn07's Avatar
      Nov 26th, 2012
      Danville PA
      Jetta 8vT
      02-26-2014 07:16 AM #2
      As far as I know almost all vw that are turbod read 20inHg. That 'negative' you are seeing is vacume and 20 inHg is normal for that.
      2000 Jetta 2.0l 8vT 16psi on stock AEG bottom end
      Buy my 2.0 AEG turbo kit!
      Or Just buy my entire car!
      Jun 7th, 2001
      Nor Cal
      Now: 84 Gti Callaway. Then: 79 Rabbit;83 Gti, 80 Scirocco S, 86 Gli, and many others.
      03-10-2014 12:26 AM #3
      I believe that is correct. Once you hit 3k RPM's you should see boost going positive.
    4. Member ejackson_5's Avatar
      Jul 10th, 2006
      Portland, OR
      83 GTI
      03-10-2014 12:45 AM #4
      Cool. Thanks. That seems to be about what I'm seeing boost at 3k. It's a blast to drive. Going to take it to a CIS/Turbo guru here in Portland this week just to make sure I've got most everything else sorted out correctly.
      Thanks!
