VWVortex.com - APR Presents V2.0 of the APR Oil Protection System!
    Results 1 to 3 of 3
    Thread: APR Presents V2.0 of the APR Oil Protection System!
    1. Forum Sponsor Arin@APR's Avatar
      Jul 29th, 2008
      Auburn, Al
      S4 3.0 TFSI 6MT & GTI 2.0T FSI DSG
      04-02-2014 05:39 PM #1
      Many of you are already familiar with this product but we've recently updated it to include a new universal APR Auxiliary ECU Controller that will be used on other upcoming products.
      Product Page: http://www.goapr.com/products/oil_pr...tem_20tsi.html
      APR is pleased to present the Oil Protection System (OPS) for the 2.0 TSI EA888 Gen 1 engine. The OPS is designed to protect the engine from oil starvation, which can cause immediate, and comprehensive, engine failure.
      The APR OPS is a racing inspired product backed by years of testing in the Grand-AM Continental Tire Sports Car Challenge. APR Motorsport’s 2.0 TSI racing program quickly exposed issues related to the engine’s design, leading to rapid engine failure during high lateral G loads. These situations are easily producible on the street during spirited runs on a twisty road, or taking highway onramps at high speeds. However, they are exacerbated on the track with race compound tires.
      The TSI’s oil starvation problems are caused by the engine’s inability to circulate oil back to the oil pan and pickup point quickly enough during the driving situations described above. The oil level in the pan falls below the pickup point and oil pressure drops. With oil no longer providing a protective barrier between critical components, metal on metal contact occurs, wearing parts rapidly. With enough wear, massive engine failure can occur.
      APR Motorsport spent a considerable amount of time researching the TSI’s oiling system to investigate traditional methods of addressing the problem. Baffling the oil pan, modifying the PCV system and enlarging the drain back ports from the cylinder head proved ineffective. Once the problem was fully understood the APR Oil Protection System (OPS) was created.
      The OPS is a pressurized external oil accumulator designed to instantly add oil into the system the moment oil pressure dips below a predefined level. The OPS slowly presses oil into the system over a period of time until pressure equalizes, and starvation is no longer an issue. The included APR auxiliary ECU interacts with the ECU on the CAN bus allowing APR’s engineers to calibrate the system to only activate when necessary. At a specific RPM, the system automatically arms. This prevents the OPS from over filling the engine while idling in the pits at the track or while stopped on the street.
      APR Aux ECU Controller
      • Ties into the factory CAN network and communicates with attached devices based on information from the ECU
      • Allows for future expandability with other upcoming APR products
      • Doesn't require any modification to the vehicle's ECU
      • Ignition off – Press Button – Button illuminates and OPS solenoid activates pushing oil out of the reservoir and into the engine (necessary to drain oil during an oil change)
      • Engine running below 1,500rpm – Button blinks once every 3 seconds indicating the controller is online
      • Engine running above 1,500rpm – Button blinks twice per second indicating OPS criteria is met (OPS will not activate until the mechanical pressure switch is also triggered)
      • Engine running – Press Button – Does nothing and does not affect other criteria
      Video
      To better understand a generic overview of the problems solved by the APR OPS, please take a moment to view this informative video.
      Oil Pressure Data
      The data below shows slightly more than one lap around the Mid-Ohio Sports Car Course in an APR Motorsport GTI. The green area represents the VAG acceptable operating range for oil pressure. The white line represents oil pressure with the APR OPS deactivated. Oil pressure dipped to dangerously low levels and caused irreversible damage to the engine. The red line represents oil pressure with the APR OPS activated. Under demanding situations, the OPS automatically provided pressurized oil to the system to prevent damage.
      Please note, the APR OPS system does not fit with the factory intake system installed. The APR Carbonio intake system is required for proper fitment.
      Application Guides
      Audi A3 (MK2)
      Volkswagen Beetle
      Volkswagen CC
      Volkswagen Eos
      Volkswagen Golf / GTI (MK5 / MK6)
      Volkswagen Jetta / GLI / Bora / Vento / Sigitar (MK5 / MK6)
      Volkswagen Passat / Magaton (B6)
      Volkswagen Scirocco
      Seat Altea
      Seat Leon (MK2)
      Seat Toledo (MK2)
      Skoda Octavia / VRS (MK2)
      Skoda Superb (B6)
      CAWA/B, CBFA, CCTA/B, CCZA/B/C/D 2.0T EA888 Gen 1
      DSG, Stronic and 6MT
      FWD and AWD
      Part number
      MS100048
      Price
      $1,299.99
      GoAPR.com | Facebook | YouTube | Twitter | Instagram
      Phone: (800) 680-7921 Local Phone: +1 (334) 502-5181 Fax: +1 (334) 502-5180
      Address: APR LLC, 4800 US HWY 280 West, Opelika, AL 36801
    2. Member Aguilar's Avatar
      Jan 28th, 2006
      VA
      2.7tt F150, Mk7 GTI
      04-03-2014 05:43 PM #2
      Nice. Definitely a must if I were to ever consider making the GTI a track toy.
    3. Forum Sponsor Arin@APR's Avatar
      Jul 29th, 2008
      Auburn, Al
      04-07-2014 04:39 PM #3
      The system went on sale today. Get em while they're hot!
