    Page 1 of 2 12 LastLast
    Results 1 to 35 of 47
    Thread: My coilover caps are sticking out to much
    1. 04-16-2014 08:57 PM #1
      Hi, I im new to this Euro Life... So I bought some coilover for my mk4 Jetta, and the two front coilover just don't seem write, they are sticking way to much from where they need to be at, and they are hitting my hood.. Please help!
    2. Member jaysleeves's Avatar
      Mar 23rd, 2010
      Canada
      04 Jetta GLS 1.8T, 2012 Tiguan 4Motion , 91 Nissan 240 SR20DET, 95 Toyota T100 EXT Cab 4x4
      04-16-2014 09:03 PM #2
      something has gone terribly wrong here wow!
      Quote Originally Posted by dangerkart View Post
      (Ricer: from the latin word Ricarius meaning to suck at everything you attempt)
      instagram: @jaysleeves
    3. Member Dave, Bro's Avatar
      Jun 2nd, 2012
      Rochester, NH
      2000 VW Jetta TDI (daily) 2000 VW GTI 1.8t (project)
      04-16-2014 09:06 PM #3
      Quote Originally Posted by jaysleeves View Post
      This.
      remove and reinstall?!?
      Instagram : @davexbro \ 1.8T \ TDI \ Lace Up \ BeastCoast \ Rochester NH GTG http://forums.vwvortex.com/showthrea...chester-NH-GTG
      Quote Originally Posted by REVoKED DuB View Post
      contact 03_Uni_b he's the one to ask questions about build threads
    4. Member nyyphi13's Avatar
      Aug 22nd, 2012
      Rochester, NY
      VR6 Girl Car
      04-16-2014 09:28 PM #4
      LOL
      Instagram: @acsteu
    5. 04-16-2014 09:34 PM #5
      I did already twice and still the same @Dave,Bro
    6. Member Dameon's Avatar
      Oct 5th, 2008
      Michigan
      2001 jetta, 1999 passat
      04-16-2014 09:36 PM #6
      Your either doing it wrong, have the wrong coil-overs or some really ****ed up bushings.
    7. Member jaysleeves's Avatar
      Mar 23rd, 2010
      Canada
      04-16-2014 09:43 PM #7
      Well right away I see that nut right up tight to the top hat, why is that there??
      top should look like this:
      then the top hat and the top nut.
    8. 04-16-2014 09:45 PM #8
      Quote Originally Posted by Dameon View Post
      Do I need to take off any other parts off the old suspension???
    9. Junior Member Sizzling_Bacon's Avatar
      Oct 10th, 2013
      2004 MKIV Jetta 2.0, 5 speed all leatha!
      04-16-2014 09:50 PM #9
      https://www.youtube.com/watch?v=yefvpgL7Dws
      I know you don't have raceland coil overs but this could be a big help. It looks like you might have missed some parts when putting the top together, because you aren't suppose to have any exposed smooth shaft above the top hat of the coil over the bearing catches on that machined surface at the end of the threads which allows you to tighten the bearing and bushing together with the nut. Then you install the coil over in the car and put all the jazz on top and tighten it down.
      MKIV Jetta GLS | 2.0 | 5 speed | BBS 2 pieces | Clean and Simple Daily
    10. Member jaysleeves's Avatar
      Mar 23rd, 2010
      Canada
      04-16-2014 09:51 PM #10
      I think just the nut that holds down the bushing and the top hat. I cant figure out why so much shaft is sticking out of the top of your coilover. what brand are those?
    11. 04-16-2014 10:27 PM #11
      Ima try to reinstall them or if the same ima have to take it to a shop...
    12. 04-16-2014 10:29 PM #12
      They are RSK street coilover I got them off eBay
    13. Member Skimmer0220's Avatar
      Oct 12th, 2009
      Delaware
      2000 Jetta VR6 12V
      04-16-2014 10:30 PM #13
      Looks like your missing the strut top mount bushing
      Sent from space through a satellite
      2000 Jetta VR6 BMW Chili Red
      VRSociety #322
      Instagram --> @Skimmer0220
    14. Member D1ESEL CHEM's Avatar
      Jul 29th, 2010
      RIP 95' Jetta GL. Daily 02' 337 GTI
      04-16-2014 10:32 PM #14
      The nut underneath the cap needs to come off. From the pics, it looks like you have the cap sandwiched between the top nut(which you have at the bottom) and the more flat style nut (which you most likely have on top, down inside the cap). Good luck
    15. 04-16-2014 10:41 PM #15
      Quote Originally Posted by D1ESEL CHEM View Post
      Oh okay! I should beat up the guy who did my coilover smh lol! That's what u get when u pay $40 for the installation smh!!
    16. Member D1ESEL CHEM's Avatar
      Jul 29th, 2010
      04-16-2014 10:45 PM #16
      The flat style nut should be holding down the bearing/ bushing directly to the coilover. Then the top hat goes on with the larger nut holding it all together.
    17. 04-16-2014 10:56 PM #17
      Do you have a pic o the cap in how it should look like ???
    18. Member jaysleeves's Avatar
      Mar 23rd, 2010
      Canada
      04-16-2014 10:58 PM #18
      check out this thread, shows it all:
      http://noahlh.com/car/coilover_howto/
    19. 04-16-2014 11:18 PM #19
      Thanks a lot that shows me where the issue might be! Cuz I have my old struts and they still have the aluminum spacer and the strut bearing. It's all bad! Smh lol
    20. Junior Member
      Feb 20th, 2014
      Victorville, CA
      2003 Volkswagen GTI VR6
      04-17-2014 12:22 AM #20
      Should've done it yourself and follow the procedures man! That's crazy!
    21. 04-17-2014 12:42 AM #21
      Quote Originally Posted by 24vFTW View Post
      Yeah I know, but I just didn't have the tools for the job
    22. Member Einkaufswagen's Avatar
      Oct 25th, 2009
      N Kingstown, RI
      1999.5 Jetta VR6 GLS, 2000 Jetta VR6 GLX, 2001 Jetta VR6 GLX, 2001 Jetta VR6 GLX
      04-17-2014 08:13 AM #22
      What the hell is that. I hope your not driveing it like that...
      My OEM+ build thread with a twist: Einkaufswagen's Build
      Buy my stuff ------------------> --==OEM+ Stuff For Sale==--
      Quote Originally Posted by LC6X View Post
      Your doing it right, just go deeper.
      Quote Originally Posted by WolfsburgNate View Post
      Shaving is for queers and ladies.
    23. Member dubluv2003's Avatar
      Oct 22nd, 2010
      Greenville SC
      JTI/Jolf/GTI whatever you wanna call it.
      04-17-2014 08:32 AM #23
      is the strut bushing upside down?
      Im not a ricer. Im lo mein.
    24. 04-17-2014 08:33 AM #24
      I have the same coils...but this never should happen you did something very wrong
      Instagram: @bpicher_mkiv
    25. Junior Member Sizzling_Bacon's Avatar
      Oct 10th, 2013
      04-17-2014 10:17 AM #25
      Dude just watch the raceland how to install video I posted above, you can't screw it up if you want it. They give you a step by step on the whole suspension. Goodluck with reinstall I hope you get it figured out!
    26. Member LC6X's Avatar
      Nov 2nd, 2006
      Portland, OR
      2001 Baltic Jetta, 2013 R-Line Beetle
      04-17-2014 10:51 AM #26
      Quote Originally Posted by Einkaufswagen View Post
      THIS!!!! Although looking at the damage to your hood I would say you already have. Get that corrected asap!
      VOTE HERE to add a seller feedback section to the classifieds
      Meet Crayola | IG: @mindy13vw | 8v Society #1
      Previous cars: 2012 TR GTI, 2013 TBM Jetta TDI, 2012 CW Beetle 2.0T, 2012 CW Jetta SE, 1989 Cabriolet
    27. Member 1.8tizzle's Avatar
      May 22nd, 2003
      VA
      BMW X5 4.8 Sport, Imola 20th
      04-17-2014 11:36 AM #27
      Those are assembled and installed incorrectly.
      That silver nut you see UNDER the strut cap should NOT be there.
      It should go coilover cap > OEM strut bearing > OEM strut mount > OEM strut mount retaining nut > strut cap > silver nut to hold the cap on.
    28. Member MechEngg's Avatar
      Jan 12th, 2009
      Calgary, AB
      04-17-2014 11:57 AM #28
      This is the order of the parts if you are more of a visual learner
    29. Member scirockalot8v's Avatar
      Sep 15th, 2006
      mk5 and cx-5 /ex mk4 owner
      04-17-2014 12:09 PM #29
      Made this up real quick. Should explain it pretty well.
    30. Member Fastvolks's Avatar
      Apr 30th, 2003
      Somewhere Banannnnnnnnnnnnnnnnnnnnnnnnnnnnnnnnnnnnnnnnnnnnnnnnnnnnnnnnnnnnnnnnnnnnnnnnnnnnnnnnnnas
      MK4 & MK6 GTI • 1986 Audi 4000CS Quattro
      04-17-2014 12:23 PM #30
      Oh my... If those last two pics don't help take it to a pros but don't drive it like that anymore!
    31. 04-17-2014 03:35 PM #31
      Maybe you have figured it out already but I'm pretty certain that the strut bearing is what's missing. When mounted properly the bearing presses against the top mount bushing and stops the shock from pushing up. Check the pictures above and you'll see where the bearing should be. You can use the ones from old struts but getting new ones won't set you back too much. They tend to wear out pretty quickly so you'll be changing them soon anyway.
      I wouldn't drive like that either but I don't think it would do any damage other than the hood which seems to be ruined already. The weight of the car is resting on the springs after all.
    32. Member MechEngg's Avatar
      Jan 12th, 2009
      Calgary, AB
      04-17-2014 03:37 PM #32
      Quote Originally Posted by Ptrlhead View Post
      Bingo.
      That is exactly what is missing. It is the thrust bearing that allows your strut to turn with ease with the full weight of the car on the strut
    33. 04-17-2014 10:01 PM #33
      Thanks bro that really helps a lot I had a filling that's the problem but hopefully I could do it this week and yeah I'm driving on them like that but only from work and back but I need to fix them ASAP
    34. 04-17-2014 10:02 PM #34
      Thanks to everybody! Thanks for all your help !!
    35. Member foundubbedriver's Avatar
      Jan 10th, 2006
      tempe, az.
      mkiv gti (killed) mkiv .:r32 (unicorn sh!tbox).
      04-18-2014 03:01 AM #35
      I almost sh!t myself looking at those pics, god damn.. sorry dude
      ig @j__cermak <-- (double underscore).
      shhh!! if you're quiet, i'll show you a dinosaur..
      exklusiv motorsports.
