1992 Mk2 Gti 2.0l 16v
Hey guys just testing the waters.
My 92 Gti 16v 1.8 head 2.0 block
Approximately 40,000 miles on fully rebuilt engine and transmission back in '09 with proof. 280,000 and still going. Original cluster. Recent Castrol Pro OE synthetic 5w-40 oil change. AC is deleted, power steering and sunroof.
New: '05 civic si seats, kenwood radio w/ usb, Polk speakers, Magnaflow muffler, halogen headlights, volt/oil pressure gauges, axles/boots, strut/shock mounts, battery, both knock sensors, vacuum hoses, distributor, radiator, water pump, timing belt, coolant hoses, NGK spark plugs, fuel injectors, valve cover gasket, belts, oe engine engine mounts, driver side seat belt, cold temperature sensor.
Bilstein hd on the rear and touring in the front. Eurosport short shifter and front strut bar.
$4000
http://www.vinaudit.com/report?id=638567950900
http://losangeles.craigslist.org/lgb/cto/4650148134.html
$4000
