    Results 1 to 2 of 2
    Thread: Bad PCV or? vacuum leak
    1. Junior Member justAverage's Avatar
      Nov 9th, 2012
      San Diego, CA
      2007 scion tC
      06-12-2014 02:42 AM #1
      2009 MKV GTI 2.0t TSI 95k miles. few days ago car starts getting irregular idle and cuts in boost/acceleration. CEL had come on because of it so i took it to my dealer since they offer free diagnostics. they run it and tell me my PCV is going bad along with my DV (older diaphragm revision) so i buy the newest revision PCV and a rev-d DV thinking problems will be solved. come home and install only to find the leak still exists. try the oil cap test while engine is running and its hard to remove and engine wants to stall out right away once its off. same with the dipstick. next check i try the MAF thinking it may be a culprit. unplug the MAF while engine is running and the idle smooths out and sounds great. plug it back in and goes back to irregular idle. so i take the MAF out and clean it and try again, nothing. try a new MAF and still same issue. checked all my vacuum hoses and fittings made sure they are all connected and sealed up and it all checks out. is there anything else im not thinking of? only thing that comes to mind is maybe i somehow bought a faulty PCV? or? need some advice please!
      justAverage
    2. Junior Member justAverage's Avatar
      Nov 9th, 2012
      San Diego, CA
      2007 scion tC
      06-13-2014 04:15 PM #2
      Bump
      I am getting this error code, P2279 - Leak in Air Intake System.
      Any recommendations?
      Here is what Ross-Tech says about it:
      18711/P2279/008825 - Leak in Air Intake System
      Possible Symptoms
      -Malfunction Indicator Lamp (MIL) active
      Possible Causes
      -Vacuum Leak
      -Intake Manifold Runner Position out of Specification
      -Faulty Positive Crankcase Ventilation (PCV) System or Heating Element (N79)
      Possible Solutions
      -Check Intake System for Leaks
      -Check Intake Manifold Runner
      -Check (PCV) System and / or Heating Element if applicable
      Special Notes
      -When found in the NAR 2.0T (BPY) check RVUTB: 01-09-03 or 2018919 for updated Crankcase Breather Valve
      -If the breather valve is faulty, full engine vacuum is typically found when removing the oil cap at idle.
      http://wiki.ross-tech.com/wiki/index...1/P2279/008825
      IG: @justAverageMKV
      justAverage
