    Page 1 of 5 12345 LastLast
    Results 1 to 35 of 143
    Thread: Mint golf 1.8t almost done "overview of the build"
    1. 06-15-2014 08:38 PM #1
      So being almost ready to start. I figure I would post the build.
      The start. I couldn't find a car in ct. So I drove to New Hampshire to pick it up
      Starting a mild bay shaving ( left heat and air intake. I wanted this car to be driven )
      Sent from my iPhone using Tapatalk -
      Coming soon. A new fab shop Im me for info
      Meriden Fire IAFF local 1148
    2. 06-15-2014 08:45 PM #2
      The rear arches were rusted out but I wanted a little different look so this is putting front lips on the rear.
    3. 06-15-2014 08:50 PM #3
      Body work. And poly
    4. 06-15-2014 08:52 PM #4
      Ride hight whit rear lips
    5. 06-15-2014 09:27 PM #5
      Panting the jambs. Trans and motor.
    6. 06-15-2014 10:07 PM #6
      After blocking the polysurfacer spraying 2k primer
    7. 06-15-2014 10:32 PM #7
      Painted with a custom mix color. Wanda base coat. Ppg clear coat. Sprayed with a sata jet 4000. For video while the car was being sprayed check at bopper_newdirecttionperformance on Instagram.
    8. 06-15-2014 11:57 PM #8
      Color matched small port 1.8t. With a gt28rs.
    9. Member wolfsburgfanatic's Avatar
      May 27th, 2002
      Frederick, MD
      2014 JSW TDI + 1988 GLI 16V
      06-15-2014 11:58 PM #9
      Been following this on IG and can't wait to see the final result! Great work
    10. Member jaysvw's Avatar
      Oct 15th, 2001
      Avondale, AZ
      01 GLS / 08 Rabbit / 89 Coupe
      06-16-2014 12:05 AM #10
      Quote Originally Posted by wolfsburgfanatic View Post
      What is IG?
      Awesome build!
    11. 06-16-2014 12:06 AM #11
      Using a mock up car to make my "roll bar air cage" out of 2 7/16 aluminum tube. after polishing. #hiddenairride #aircage
    12. 06-16-2014 12:10 AM #12
      Quote Originally Posted by jaysvw View Post
      What is IG?
      Awesome build!
      Insagram
    13. Member simon_C's Avatar
      Oct 4th, 2006
      SFBAY 95110
      1991 Golf GL
      06-16-2014 04:56 AM #13
      Ooooooh I like this.
      That color is pure shamrock shake right there., and those wheels are SWEET.
      In for more.
      How does a rotary work? This one's easy: the magic triangle spins in the peanut and then apex seals come out.
    14. 06-16-2014 11:30 AM #14
      all red hella tails.
      So I took every wiring harness apart and deleted every wire that wasn't going to be used to clean up under the dash.
      I'm going with a golf dash with a votex center counsel to keep it Clean
    15. 06-16-2014 11:43 AM #15
      So these are my seats. Before I sent them to love's trim shop.
      Before sealer
      Sealed
      Mixing the color.
      Painted
      AL. "After loves" lol
      1/2 way done
      Done.
      Black with mint stitching. Yum. I would never go to another interior shop after seeing his work. And kip is a super nice dude.
    16. Member simon_C's Avatar
      Oct 4th, 2006
      SFBAY 95110
      1991 Golf GL
      06-16-2014 11:51 AM #16
      You have impeccable taste sir
    17. Member
      May 4th, 2010
      Dallas, TX
      1996 GTI
      06-16-2014 05:11 PM #17
      I love budget build. Hold cash batman. That looks fun!!
      Sent from my iPad using Tapatalk
    18. 06-16-2014 05:31 PM #18
      Quote Originally Posted by MK3.OT View Post
      It's not that bad of a budget when you do everything your self. (Bodywork. Paint. Fabrication. Wiring. And everything ) pretty much by your self.
    19. Member somebodynowhere's Avatar
      Feb 10th, 2010
      203 CT
      3.0 Vr Corrado, 8v mk3, 8v mk2
      06-16-2014 06:25 PM #19
      Oh hey nice build man
      Sincerely your pal bbrroocoollii
    20. 06-16-2014 07:40 PM #20
      Quote Originally Posted by somebodynowhere View Post
      And a big thank you Brian hall. Aka somebodynowhere. Aka bbrrocoollii. For one of the only people to help me on this car and helping me get this car straight. Big ups bro. ;-)
    21. 06-16-2014 08:42 PM #21
      The westy mod.
      Cut
      Plastic welded and heat pins
      It took me forever to find a broken grill to do this.
    22. 06-16-2014 08:46 PM #22
      I see you have the aem gauges. I do also. What gauge holders are those and where can I get some? Thank you
      Just say NO to tinted tails.
    23. Member wolfsburgfanatic's Avatar
      May 27th, 2002
      Frederick, MD
      06-16-2014 08:58 PM #23
      Quote Originally Posted by bopper
      Wait, so you're using your rollcage as an air tank for your airride set-up? That's crazy! Very creative
    24. 06-16-2014 09:07 PM #24
      Quote Originally Posted by omega_supreme View Post
      I got it in early 2000 from swg. They don't make it any more. I had it in my stash ;-) lol
    25. 06-16-2014 09:11 PM #25
      Ya it's just about 4 gallons of air. This is my controller and valves set up ( hidden )
      This is my amp and compresser. (Hidden)
    26. 06-16-2014 11:24 PM #26
      Its freakin awesome spot and really well done only thing... Is poor amp i mean the head of the compressor gets really hot your amp wont have much air what do u think?
      Tht spot for the batt tho👌
      Sent from my tapatalk
    27. Member jaysvw's Avatar
      Oct 15th, 2001
      Avondale, AZ
      06-16-2014 11:33 PM #27
      Ridiculous. In the best way possible.
    28. 06-16-2014 11:41 PM #28
      Quote Originally Posted by Mk3mk3mk3 View Post
      That amp is just for door speakers. Their is no radio in the car just a direct iphone hook up for long drives. And actual you have the hole rear quarter for air space and with vents by the tail light. It's perfect for what I want :-)
    29. 06-16-2014 11:57 PM #29
      Valve cover mod.
      So I did the euro na 20v vale cover but didn't like how the oil cap / breathe looked. So I cut it off lol. And added a baffled breather on the side
      Cut and welded
      Painted to match.
      I put it on and I didn't like how the coil packs looked.
      Made a cover.
      Polished.
    30. 06-17-2014 12:02 AM #30
      Thank you. I'm trying to show that you can do something radical. But with attention to detail and with style
    31. 06-17-2014 12:41 AM #31
      Car is a amazing build! Loved watching it being built on IG!
      I'm the hero of this story
      I don't need to be saved
    32. 06-17-2014 03:10 AM #32
      Ohhhh my Gawwwwwd
      This
      Is
      Insane
      The stealth for amp and air system...😳
      Heading to IG to perv some
    33. 06-17-2014 03:12 AM #33
      Hat off you you sir , ridiculous skills and foresight
    34. Member gti250hp's Avatar
      Sep 12th, 2002
      Wichita, Kansas
      '87 GTI 2.0L ABA 16vT, 2014 Ford Raptor
      06-17-2014 09:44 AM #34
      Outstanding... But why such an obnoxious color of green (joking for those of you who don't know the colors I've run).
      Definitely subscribed!!
    35. Member CodeMan's Avatar
      May 12th, 2006
      Denverish
      Scirocco 16v, E34 540i
      06-17-2014 09:59 AM #35
      Holy ****, did this come out of nowhere or what? Great work.
      The blues ain't nothin' but a good man feelin' bad.
      Tschüß Gilda
      Hallo Birgit
