    Results 1 to 26 of 26
    Thread: Kettle Kruise 2014, who's interested?
    1. Member PrivateTucker's Avatar
      Jul 5th, 2006
      Wisconsin
      2015 GTI SE
      06-30-2014 01:55 PM #1
      It's a bit early in the year than usual for this, but I wanted to get a count for who would be interested so I can start planning now.
      For those who don't know me, my name is Jason, and I've led group 2 the past 2 years of the Kettle Kruise. With Jeff's (meanvw) blessing, he's resigned from planning and leading the event and has passed the torch onto me.
      If you're unaware with this event, the Kettle Kruise is a spirited drive that follows the Kettle Moraine Scenic Route rather closely with a stop in the middle for lunch at a local burger stand. The route starts near Menomonee Falls, WI, and ends near Road America in Elkhart Lake, WI. Typically, it lasts for 5 or so hours, so including your travel time afterwards, we ask that you plan on this being an all day event. The route does usually cross near the interstate and other major roads, so if you can only come for a short while, those will be your best chances to head out. The event is planned for October, focused around the seasonal color change on the trees. Great opportunity for photos/videos, so bring your go pros!
      From my experience in doing this, regardless of what group you're in, be prepared to throw your car around some turns. If you're not looking to push your car towards the higher end of the manufacturer specifications, or if you or any passengers easily get motion sick, this is not for you. We'll also do our best to avoid residential areas along the route, which Jeff has already minimized over time as the area became more inhabited.
      If you're still interested in this event without Jeff leading it, I'd like to hear from you. If you're a newcomer with questions, or a veteran, and you are looking to help, give suggestions on how to improve, or just "kruise" with other enthusiasts to close out the season, post here or PM me directly.
      Thank you!
      Jason
      "RACEKAR" - 2015 VW GTI SE Manual with Lighting - Reflex Silver
      Contact me if you're in S.E.WI and wanting vagcom tweaks done.
    2. 06-30-2014 03:51 PM #2
      I have 38 ideas to improve on this. Just kidding. This was the most fun drive I have ever had at a car event. "Spirited" is a good way to describe this bordering on a qualifying session. Now I just need to go trade myTiguan back in for the old GTI.
      2011 Tiguan 4 motion and 1999.5 MK3.5 Cabrio
    3. Member WillToBeWeird's Avatar
      Jul 22nd, 2012
      Oconomowoc, WI
      04 GLI VR6
      06-30-2014 08:13 PM #3
      I'm in for sure.
    4. Member meanvw's Avatar
      Dec 31st, 2004
      watertucky, wi
      Retired
      06-30-2014 08:24 PM #4
      In
    5. Junior Member
      Jun 23rd, 2011
      Kewaskum, WI
      11 UG Golf Tdi
      06-30-2014 08:33 PM #5
      In as well!
      Posted via Topify on Android
    6. Member duwem's Avatar
      Jul 14th, 2012
      WI
      2002 Golf GLS TDI 5 Speed, 258,000 miles
      06-30-2014 09:23 PM #6
      In for sure. Last years route was awesome.
      Going to try to get my buddies with 337 and R32 to come this year too.
      2002 Golf GLS TDI 5 Speed, 265,000 miles
      Panzer FMJ Skidplate, PP520 Injectors, GTI tails
      H&R 28mm Rear Swaybar, TT Short Shifter
      Eibach Pro Springs/ Koni Struts
      TT Front Spindles, Control Arms and Brakes
    7. Member LGDUBR's Avatar
      Mar 13th, 2007
      The Thrill
      04.5 Jetta GLI 1.8T, 02 Jetta GLS 2.Slo
      06-30-2014 09:48 PM #7
      Very interested!
      04.5 BMP GLI 1.8T
      "It's not what you drive, it's how you drive it" -Clarkson
    8. Junior Member Jdubbs01GTI's Avatar
      Jul 12th, 2008
      Waukesha, WI
      01 12v GTI [gone], 65 buggy project, 03 24v GLI
      07-05-2014 01:09 AM #8
      I'm interested as well!!
    9. Member passatv6AF's Avatar
      Nov 4th, 2011
      Chicago
      B5 5MT UNITRONIC TUNED, B7 6MT STAGE 1.5 TDI
      07-07-2014 06:39 PM #9
      Had a blast last year. I'm definitely in!
      Very disappointing we couldn't have something similar in the spring and summer
      40% tints, black vinyl wrap roof, Piaa hyper white DRL, black out signs, H&R front & rear sway bar (28mm front, 24mm rear), Adam's front slotted rotors, Stoptech Performance front pads. SOON: Adam's rotors, Stoptech pads in the rear, and H&R springs.
      Max mpg : 56.69mpg
    10. Member waabaah's Avatar
      Jun 24th, 2006
      Fairbanks, Alaska
      04 .:R32; 20th a.e.;87 rattled black Toyo;94 AWD caravan;97 Gti Vr6T;82 924 porsche
      07-12-2014 01:46 AM #10
      I would. I don't check this side often. I would need a date to plab
    11. Member WakingTh3Fall3n's Avatar
      Feb 19th, 2012
      MKE/RACINE, Wiscompton
      2014 GLI Autobahn 6spd Reflex Silver
      07-16-2014 11:54 PM #11
      I'm in jason
      2014 GLI 6 Speed | APR Stage 1 | CTS Turbo catless downpipe | APR RSC Catback | CTS Turbo intake | Neuspeed FMIC | Dogbone insert | Bagged
      Instagram : MKVI_JETTA
    12. Member Commocozy1's Avatar
      Oct 8th, 2008
      Kenosha WI
      2008 .:R32 UG
      07-17-2014 12:36 PM #12
      Very interested, missed the last two!
    13. 07-17-2014 09:30 PM #13
      I'm in. I've missed the last 2-3. I didn't know we were still doing this.
    14. 07-18-2014 07:57 AM #14
      When is this? Im always looking for a good cruise.
    15. Member PrivateTucker's Avatar
      Jul 5th, 2006
      Wisconsin
      2015 GTI SE
      07-18-2014 10:44 AM #15
      I'm happy to see the interest as high as what it is. Thanks for speaking up everyone!
      It's tentative for October, probably on on a Sunday the second or third week, but as that time comes closer, I'll for sure iron out a hard date for you all to plan on. There will also be an official thread posted for sign-ups when things are set. If you'd like a direct PM when the official thread is posted, PM me and I'll fire one back when I put the thread up.
      Jason
    16. Member Cr4shT3st's Avatar
      Jan 23rd, 2009
      WI
      Boxster, V70R
      07-21-2014 04:20 PM #16
      Sounds great, I'll join.
      I love driving in the fall colors.
      _______________________________________________
      http://fastwagon.blogspot.com/
      Quote Originally Posted by BRealistic
      "Bespoke" is just a nice way of saying "hand-built by local drunks"..
    17. Member Suprnva's Avatar
      Feb 18th, 2004
      Oshkosh, WI
      2001 VW Golf GLS
      07-21-2014 04:21 PM #17
      I'd be interested as long as the date works out.
    18. Member elicitvr6's Avatar
      Jan 10th, 2002
      Chicago
      '98 Widebody Jetta, '91 16VT Jetta Coupe, '04 Passat 4Motion Wagon
      07-28-2014 09:08 AM #18
      Definitely interested.
    19. Member Cr4shT3st's Avatar
      Jan 23rd, 2009
      WI
      Boxster, V70R
      07-29-2014 10:16 AM #19
      Any chance for Oct. 5? Just hoping.
    20. Member PrivateTucker's Avatar
      Jul 5th, 2006
      Wisconsin
      2015 GTI SE
      08-17-2014 09:39 PM #20
      Quote Originally Posted by Cr4shT3st View Post
      The more I look at it, October 5th seems like the day! It almost seems too perfect a day. No Packer game that afternoon, so there's no rush. We can get out there and enjoy the route.
      Hopefully the weather cooperates with that plan.
      I went out on a test run this morning with a few others. Right off the bat there was construction, and further along the route, a couple stretches of road were covered in gravel. I will be looking at alternative routes should those roads be in the same shape come October.
      Additionally, it looks like we may add 2-3 new/different paths. They're not through residential areas, and they should you a good twisty perspective on the scenery.
      This'll give you all a chance to verify if Oct 5th will work for you. Official thread and sign-up will follow soon!
      Jason
    21. 08-20-2014 12:27 AM #21
      I know this isn't "official" yet but the 5th would work for me too.
    22. Member Nostalgia's Avatar
      Sep 25th, 2003
      Sheboygan, WI
      Janky MK3
      08-20-2014 08:57 AM #22
      VW Only? Or can I bring the Miata?
    23. Member PrivateTucker's Avatar
      Jul 5th, 2006
      Wisconsin
      2015 GTI SE
      08-21-2014 10:03 AM #23
      Quote Originally Posted by Nostalgia View Post
      Trying to keep the main groups euro as per tradition. However, I wouldn't be against having another group for other makes. Anyone who remembers from 2 years ago, there was a group from Sheboygan who did a similar cruise as a dedication to someone (IIRC), and they had all kinds of Makes/models.
      I also gather that there is a car show in Milwaukee on Oct 4th. Not sure how people who might do the show, like me, would also feel about doing the cruise the morning after. I'll get a feel for what people think as it might alter the date.
      Lastly, I currently have 2 group leaders, including myself. I'd like to at least get a 3rd going, so if anyone is interested in being a group leader, get in touch with me either here or on FB.
      Jason
    24. Junior Member Jdubbs01GTI's Avatar
      Jul 12th, 2008
      Waukesha, WI
      08-22-2014 01:31 AM #24
      I can lead again this year if needed.
    25. Member Creepingdeath's Avatar
      Dec 6th, 2012
      Milwaukee, WI
      2013 Golf R DBPM
      09-15-2014 09:11 AM #25
      I'd be up for this!!
      Current: 2007 Dodge Grand Caravan SXT (DD), 2013 Golf R (WW), 1967 Cadillac Coupe DeVille (Summer)
      Lest We Forget: 2008 Ford Crown Victoria Police Interceptor, 2006 Cadillac DTS, 1997 Plymouth G. Voyager, 1999 Dodge Intrepid, 1996 Plymouth Breeze, 1988 Plymouth Horizon, 1984 Ford Escort Wagon, 1978 Chrysler LeBaron, 1984 Nissan Stanza
    26. Member PrivateTucker's Avatar
      Jul 5th, 2006
      Wisconsin
      2015 GTI SE
      09-17-2014 02:50 PM #26
      To anyone interested, the sign-up thread is here: http://forums.vwvortex.com/showthrea...ober-19th-2014
      Jason
