    Results 1 to 4 of 4
    Thread: Yellow Paint on Idle Control Valve
    1. Member keganater's Avatar
      Apr 29th, 2008
      Henderson, NV
      95 Jetta 2.0, 92 Cabriolet 1.8, 05 CRF450R Supermoto,
      07-14-2014 12:38 PM #1
      I have noticed that the paint on the end of my idle control valve has broken away and now there is a hole where the paint was. What is the purpose of the yellow paint? Is it some type of sealant that should be replaced?
      Pic for reference:
    2. Member Seax_Smith's Avatar
      Jun 1st, 2007
      Not Present.
      Newest, 92 GTi half-swap plus
      07-14-2014 04:08 PM #2
      If you poke around in there you should find a tiny little hex screw. DO NOT move it unless you have a spare ISV. The yellow stuff is/was an anti-tamper measure. That screw adjusts the valve in the ISV. NO YELLOW = NO WARRANTY (as if that matters today).
      [Want to watch a VW tech at the stealership cringe.... bring you car in and tell it is a mixture or fuel delivery issue and your pumps and relay test to be functioning correctly.]
      I'm currently out of my mind, but feel free to leave a message.
    3. Member keganater's Avatar
      Apr 29th, 2008
      Henderson, NV
      08-22-2014 02:29 PM #3
      Thanks for the info. I figured that was what it was but wanted to confirm.
    4. Member
      Aug 15th, 2007
      Virginia
      G60 on CIS-E and a bunch of other VW's
      08-22-2014 04:43 PM #4
      Nice info to now know.
      I have a few spare ISV's. Maybe I will fiddle with one of them when I try and get my OBD-I VR T/B working with the lack of an idle air screw.
