    Results 1 to 5 of 5
    Thread: Cold Start Misfire on cylinder
    1. Semi-n00b
      Jul 16th, 2014
      Northern NJ
      2006/Jetta/2.0T
      07-17-2014 05:17 PM #1
      I have 2006 Jetta 2.0T. I had my spark plug and coils replace year ago. Now I am get CEL light on start up (sometimes flashing). I found out it is fine if I rev the engine for about 5 second after starting. I pulled the codes and it was alway misfire on cylinder 4. I read lot of forum about this. Most say bad plug or coil, eventhou I just got them replace. I am going to try to switch plug and coil 4 with 1. Another thing i hear is a bad injector. Is they a test I can do to check this.. if it is bad how hard is it to replace.
      OR it could be a carbon buildup. I do have 140k miles on it.. but why only on one cylinder?
    2. 07-19-2014 10:23 PM #2
      A few years ago, I had cold start misfire problem on my Audi A3 2.0T. I eventually tracked it down to a vacuum leak in the vacuum line to the brake booster. I did some data logging and the misfires would continue to count until the O2 sensor went closed loop and provided correction for the leak - a minute or so after start. In my case, the leak was in cracked plastic fitting that's behind the driver side of the cylinder head. Once I fixed the leak, the cold start misfire disappeared. Search for vacuum leaks downstream of the throttle body.
    3. Semi-n00b
      Jul 16th, 2014
      Northern NJ
      2006/Jetta/2.0T
      07-22-2014 01:36 PM #3
      Quote Originally Posted by releger View Post
      Thanks for the help.. Did your misfire stay only one cylinder? Mine anyways is on cylinder 4.
    4. 07-25-2014 09:21 AM #4
      Initially, the codes I got were for cylinder 4 and for multiple cylinder misfires. This went on for a number of months until the leak got worse and I started getting codes for all cylinders.
    5. Semi-n00b
      Jul 16th, 2014
      Northern NJ
      2006/Jetta/2.0T
      08-12-2014 04:16 PM #5
      thanks... I look into it.
