Group Buy Status: OPEN
We've received quite a few inquiries about these, so we're having another Group Buy on our B6/B7 Audi A4/S4/RS4 Solid Rear Sway Bar and B6/B7 Audi A4/S4/RS4 Motorsport Rear Sway Bar End Links! [up]
034Motorsport B6/B7 Audi A4/S4/RS4 Quattro Solid Rear Sway Bar
Retail: $195 + Shipping
Group Buy:
1-14 Orders: $185 + Shipping
15+ Orders: $170 + Shipping
Use Promo Code: B6-B7-RSB-GB
034Motorsport B6/B7 Audi A4/S4/RS4 Quattro Motorsport Rear Sway Bar End Links
Retail: $175 + Shipping
Group Buy:
All Orders: $150 + Shipping
Buyers:
  • 1.
  • 2.
  • 3.
  • 4.
  • 5.
  • 6.
  • 7.
  • 8.
  • 9.
  • 10.
A deposit of $170 for the Rear Sway Bar and/or $150 for the Rear Sway Bar End Links are required to get on the Group Buy list. Use the promo code B6-B7-RSB-GB after adding the item(s) to your shopping cart to receive Group Buy pricing. The Group Buy will run until 09/14/2014 and final pricing will be determined by the number of buyers on the list. To get on the list, just add the item to your cart and complete checkout. Feel free to leave your forum username in the "Comments" section so that I can add you to the list! I will mark off who has paid on a regular basis.
The first ten buyers will have their parts shipped immediately! The remaining orders will ship after the Group Buy closes on 09/14/2014.
034Motorsport is proud to offer the ultimate rear sway bar upgrade for the B6/B7 Audi A4/S4/RS4 Quattro! The 034Motorsport Adjustable Solid Rear Sway Bar is made from high-quality spring steel for maximum rigidity, and is designed to combat understeer while reducing body roll under hard cornering.
This product was tested thoroughly on the street and track on our shop B7 Audi A4 2.0T FSI Quattro before release. The 034Motorsport Adjustable Solid Rear Sway Bar substantially reduces understeer and body roll on B6/B7 Audi A4/S4/RS4 Quattro vehicles without compromising comfort on the street.
In addition, the 034Motorsport B6/B7 Audi A4/S4/RS4 Rear Sway Bar is engineered to be used effectively with the stock front sway bar. No upgrade in the front is needed or required. The addition of a stiffer front bar introduces even more push, requiring an even bigger bar in the back. With the stock front sway bar and upgraded 034Motorsport Solid Rear Sway Bar, body roll is virtually eliminated while turn in and off throttle oversteer are greatly improved.
Features:
  • 100% - 125% Increased Sway Bar Rate (Over Stock RS4 Rear Sway Bar)
  • 25.4mm Diameter
  • Solid Spring Steel Construction
  • 2-Way Adjustable
  • Designed to be used in conjunction with the stock front sway bar.
What's Included:
  • 034Motorsport B6/B7 Audi A4/S4/RS4 Adjustable Solid Rear Sway Bar
  • Graphite-Impregnated Urethane Bushings
  • High-Strength Billet Aluminum Sway Bar Brackets
Fitment:
  • 2002 - 2005 Audi A4 (B6)
  • 2003 - 2005 Audi S4 (B6)
  • 2005.5 - 2008 A4 (B7)
  • 2005.5 - 2008 Audi S4 (B7)
  • 2006 - 2008 Audi RS4 (B7)
Replace your flimsy, sloppy OEM sway bar end links with these performance engineered adjustable spherical endlinks from 034Motorsport!
034Motorsport's Adjustable Rear Sway Bar End Links allow for uncompromised transfer of suspension movement to the sway bar, and are adjustable in length.
Features:
  • CNC Machined Steel Adapter Hardware (Zinc Plated for Durability)
  • CNC Machined 6061-T6 Aluminum Spacers (Anodized Black for Durability)
  • Motorsport Quality Aurora Spherical Bearings
  • Includes New High-Grade Installation Hardware
Functions:
  • Remove Sway Bar Preload - Essential When Corner Balancing
  • Improved Sway Bar Reaction Time & Accuracy
  • Hang Around Your Neck to Attract the Honeys When Out at the Club
Fitment:
Compatible with all stock and aftermarket sway bars.
Click here to order!
Feel free to contact me via email or PM if you have any questions! []
