VWVortex.com - 99mm tdi 1.8t / 16v Timing drive gear
    Results 1 to 7 of 7
    Thread: 99mm tdi 1.8t / 16v Timing drive gear
    1. Member ens's Avatar
      Dec 14th, 2006
      Queens
      84GTi-944s-B7quattro-R1-solana
      09-09-2014 11:28 PM #1
      Im sure this was covered somewhere on here but I could not find a solid answer.
      I have a 20/20 running a 99mm crank.
      The 16v timing drive gear has a different seat than the tdi crank.
      Tdi gear seat
      16v gear seat
      I was thinking of taking it to a machine shop to weld and recut the gear.
      Is there any other solution, without machining or dowel pinning the crank?
      May 26th, 2007
      Britsh Columbia
      09-23-2014 10:53 AM #2
      always wanted to know what others are doing for this.
    3. Member thescirocco.com's Avatar
      May 15th, 2002
      Bear, Delaware 19701
      1984 Rabbit GTI
      09-23-2014 08:01 PM #3
      Can't you use the TDi gear? I've heard of the 16V key shearing off, and the diesel gear looks like a better design.
      Parts blow-out!
      Discount dealer - Peter call/text 3O2.8989.O5O and house phone 302.832.8989
      Facebook: Peter Leif Lindvall, and my back-up email is peterthescirocco@{that gmail.com email extension}.
    4. Member
      May 26th, 2007
      Britsh Columbia
      09-25-2014 11:02 AM #4
      No the 16 valve uses a different type timing belt then the tdi.
    5. Member MikkiJayne's Avatar
      Jan 1st, 2007
      UK
      A6 TDI Quattro wagon, A4 TDI Quattro racecar
      09-25-2014 12:29 PM #5
      They look the same profile from the two pictures in the first post. Are they different widths?
      Throw an Audi engineer down a hole with a ladder and he will fashion a shovel from it and tunnel his way out
      Quote Originally Posted by shwak23 View Post
      You could always call your insurance and say that some vandals tried to swap your car to rwd while you weren't looking.
    6. Member ens's Avatar
      Dec 14th, 2006
      Queens
      09-26-2014 12:24 AM #6
      the 16v gear is wider and has a different tooth profile than the tdi
      im thinking
      1. weld and machine timing drive +dowel pins
      2. weld and machine crank +dowel pins
      3. cut 16v timing drive tooth + add two 6mm dowel pins
      even though my machinist said its not a good idea, right now im going with option 3.
      he will drill and ream the 6mm on the timing drive, then i plan to bolt it up with an old bolt that i cut the head on, and drill right into the crank for the dowel pin.
    7. Member Issam Abed's Avatar
      Feb 12th, 2004
      EVERYWHERE
      91 Audi 80 2.0T
      10-19-2014 04:53 PM #7
      • Machine 99mm TDI crankshaft (I assume you modified a BRM unit to get that 99mm stroke?) snout to accept 16V Timing belt sprocket keyway
      • Dowel pin sprocket to crankshaft snout
      • Use ARP Bolt
