    Results 1 to 14 of 14
    Thread: aba drag car purpose build
      Sep 20th, 2004
      se pdx
      87abat drag gti, 95 jetta beater
      09-10-2014 01:07 AM #1
      Well bare with me here as all my photos are on my photobucket on my phone
      I'm in the process of building what I hope will set the bench Mark of aba power and performance, to start this car will be driven very little on the street maybe 10 times a year , being built specifically for drag racing
      Engine build is
      Obd1 aba from 93 golf
      Stock forged crank , oil squirters
      Scat h beam rods arp 2000 rod bolts
      Arp mains
      Calico coated race bearing mains and rods
      Wiseco coated side 8.5-1 forged pistons with arp rings
      Cylinder head ported and polished with flow bench numbers good for over 500 hp, 1mm over valves intake and exhaust, techtonics springs, titanium retainers and light weight lliftersand a 1 off techtonics 288 on 114 degree love center there magic turbo cam just bigger
      Turbo set up is as follows
      Jones performance threw the hood equal length tubular exhaust manifold with 50 mm wastegate
      Super hx40 hulset 60mm billet compressor, 10 blade 60mm turbine 16cm non gated housing, fully rebuilt and balanced (at the shop now)
      Nubworks custom long runner manifold set up with throttle body sitting in front of timing belt area all cnc flanges port matched to head, volocity stacks, and some sweet welds
      Will be (on order) lugtronics vems Ecu tuned by Kevin him self,Kevin's custom wiring harness with boost control and wide band and sd card logging
      Fuel system
      1600cc Bosch injectors
      2 044 Bosch pumps
      -8 supply lines -6 return
      Custom nubworks fuel rail
      5 gallon fuel cell
      Bosch motor sport coil
      8mm techtonics wires
      Bkr7e plugs
      Spec stage 4 clutch with billet flywheel
      02m six speed from Audi tt converted to front wheel drive
      Welded diff with arp bolts in rear gear
      Stock tt shift box and selector (slight short throw)
      Car is a 1987 coupe with every little thing cut out of it
      Rear floor and spare tire well cut out and replaced with 16 gauge aluminum
      Rhodes racing 10 point role cage, kirky race seat ,
      Now for pics
      This is the bold set up that was making right around 300 whp stock block and head with stacked gaskets c2 chip and t3t4 [URL=http://s232.photobucket.com/user/speedybunny2/media/IMG290.jpg.html][/URL
      Now [URL=http://s232.photobucket.com/user/speedybunny2/media/IMAG0317.jpg.html][/URL
      I will add more pictures
      This was this weekend at Pacific waterland
      Lots more to come
      Sep 20th, 2004
      se pdx
      09-10-2014 09:58 AM #3
      [URL=http://s232.photobucket.com/user/speedybunny2/media/Mobile%20Uploads/2014-09/IMAG0164.jpg.html][/URL
    3. Member G60 Carat's Avatar
      May 14th, 2004
      Regina, SK
      1982 BMW 320i, 1986 Jetta Carat Frankenturbo
      09-10-2014 05:27 PM #4
      Mk2 8v turbo content...ahh yaa!
      Subscribed
      | Rust | Zip-Ties | JB Weld | Bad Idle | Scrapes Ground | Rubs when Turning | Busted Ass Door handles |
    4. Member .T.o.n.y.'s Avatar
      Apr 3rd, 2003
      Hells heat AZ
      96' Jetta aba-t, 00' Audi A4, 01' Passat 30v
      Yesterday 10:42 AM #5
      In for fellow Holset 8v.
      I am a Vortex build addict, click the link below to check out my builds and join in on my addiction:
      http://forums.vwvortex.com/showthrea...0#post85285470
      Sep 20th, 2004
      se pdx
      Yesterday 04:58 PM #6
      Hopefully have role cage done this week
    6. Forum Sponsor Quintin@USRT's Avatar
      Oct 6th, 2009
      Melbourne, FL
      A founding Member of the 8v 350+whp Club, Now rocking a B7 S4 mmmmm V8!
      Yesterday 07:02 PM #7
      jeez louise lookit how high that sits!!
    7. Member G60 Carat's Avatar
      May 14th, 2004
      Regina, SK
      Yesterday 07:22 PM #8
      Ha that's great.
      Look I found your whole exhaust system..Just weld on a flange on there and good to go.
    8. Member G60 Carat's Avatar
      May 14th, 2004
      Regina, SK
      Yesterday 07:25 PM #9
      Speaking of big turbos. A local guy is running a PTE 6262 on a 2.0 DOHC. He was over getting some jets from me on the weekend, and told me the car currently runs 30psi of boost. And that it won't fully spool in either 1st or 2nd gear. 1st is like 12psi at 6500rpm or something,
      But still I want to do my own BT build.
    9. Forum Sponsor Quintin@USRT's Avatar
      Oct 6th, 2009
      Melbourne, FL
      Yesterday 08:44 PM #10
      Quote Originally Posted by G60 Carat View Post
      that sounds about right but in 3rd he should still be around low to mid 4k for 20psi.
    10. Member G60 Carat's Avatar
      May 14th, 2004
      Regina, SK
      Yesterday 11:16 PM #11
      I'm starting to think big turbo's are just traction control for FWD cars.
    11. Member
      Sep 20th, 2004
      se pdx
      Today 04:47 AM #12
      Ya g60 that's the whole exhaust will exit threw fender on passanger side
      Turbo sits high but see pics with hood on it sits just like I imagined, nice cool air out of the hood
      Sep 20th, 2004
      se pdx
      Today 04:57 AM #13
      Guess I did not put any pictures with the hood on, here you go
    13. Member BR_337's Avatar
      Sep 3rd, 2011
      ATL ,GA
      91 Mk2 TRACKCAR GTI /337 engine/6 spd
      Today 09:30 AM #14
      haha awesome!
      91 Mk2 GTI[/B]---->[B] 1.8T (Awp) /" 6 speed (O2M)" / Holset HX27w Turbo / Stainless Log manifold / Tial 38mm WG / TurboSmart MBC / Simens 630cc / Aeromotive FPR / 034 fuel rail / TurboSmart BOV /Sigma 6 SPD Billet Shifter/ Wavetrac LSD/ CM fx400 /USP steel shift forks / 3''turboBack / Kirk Rollcage /ST Coilovers /Halk Blue Race Pads/ S.S brakelLines/ Toyo r888 /Tuned BY REY (elRey )
