    Results 1 to 18 of 18
    Thread: Thoughts on what turbo to get next. VRT
    1. Junior Member
      Feb 18th, 2014
      Michigan
      2003 Passat Gls 1.8t, 2000 VW GTI 12v VRT
      10-08-2014 02:22 PM #1
      My Garrett t04 has some major shaft play and the compressor is smacking the housing.
      My next turbo would probably be a Borg Warner S300 s366. .91 a/r turbine. Does anyone think its too large for a vr6?
      it is a 66mm inducer turbo and the .91 a/r turbine is the second smallest option available.
    2. Member .therealvrt's Avatar
      Mar 29th, 2006
      Ottawa,Ontario,Canada eh!
      97 gti 2l turbo
      10-08-2014 03:16 PM #2
      66mm is good if you want 700-800hp.
      No need to go that big unless you are looking for single digit 1/4 mile times and even then its not necessary.
      Find at 58-62mm inducer and a wheel thats relatively new technology and enjoy.
      Rockin' a mk3 since '94.
    3. 10-08-2014 03:20 PM #3
      .91 ar seems pretty big. I've got a .83 and that seems big to me. I see positive boost at 3600. I do agree with real, 62mm would be a great turbo if you get a good hot/cold combo.
      Sent from my iPhone 5 3/4 using Tapatalk
      Quote Originally Posted by theprf View Post
      There is no such thing as an inexpensive Corrado....
    4. Member dub nutz's Avatar
      Dec 30th, 2010
      vernon, CT
      golf lll vrT, b6 a4 avant
      10-09-2014 10:04 AM #4
      i have 6266 .81 ar. seems laggy but full boost at 4200rpm, 10psi at 3800rpm. its like traction control for lower gears.
      Quote Originally Posted by X37 View Post
      Buy antifreeze or give handjobs for meth, your choice.
      Aug 11th, 2010
      NEOhio
      MK3 Jetta VRT
      10-09-2014 05:28 PM #5
      Quote Originally Posted by dub nutz View Post
      Can you give a little more info on your setup please.
    6. Member dub nutz's Avatar
      Dec 30th, 2010
      vernon, CT
      10-09-2014 08:31 PM #6
      Obd2 um 42lb software
      6266 .81 ar t4
      3" full exhaust no cat
      Stock cams
      8.5:1 head spacer
      Tial 38mm wastegate
      Forge super dv
      2.5" intercooler piping
      Stock intake
      Walboro 255 (soon to be bosch 044)
      4bar fpr
      A/F is 11:1 at 10psi and 12:1 15psi and up
      Never been dyno'd
    7. 10-09-2014 08:53 PM #7
      I'm at 11.7-12.5 at 16 psi and basically have the same setup as you and I made 330 wheel and 300 torque with a leaking throttle body coupler.
    8. Member dub nutz's Avatar
      Dec 30th, 2010
      vernon, CT
      10-10-2014 09:24 AM #8
      those seem like decent numbers, kind of hoping for 350hp, 330tq but havent found any dyno days. cant tune anything here so dyno runs are for numbers. i can think of better ways to spend my money. I have start building the trans, sucks when you cant launch or put any thing down through 2nd
    9. 10-10-2014 01:27 PM #9
      I don't have that problem. I don't build boost in first gear. I've got the short ratio trans in my Corrado. Second- third has no traction.
      And I would've made over 330 but my coupler keeps blowing out and leaking.
    10. Member Norwegian-VR6's Avatar
      Feb 6th, 2002
      Norway
      96 Golf VRT, 12 Skoda Superb 2,0 TDI
      10-11-2014 07:59 AM #10
      Obd2 Pro-Maf setup with a billet GT35R T3 1.06 Full boost @ 3700 rpm. Stock head and 3" dp/exhaust.
      To me, its a perfect 450++whp turbo.
      2012 Skoda Superb 2.0 TDI avant: Daily family car
      1996 Golf MK3 12V 02M Turbo.
    11. Member .therealvrt's Avatar
      Mar 29th, 2006
      97 gti 2l turbo
      10-11-2014 06:16 PM #11
      Quote Originally Posted by Norwegian-VR6 View Post
      I agree. I ran the same turbo but with the .8x ar. I wish i had tried the bigger t3 hotside.
    12. Member Jckl's Avatar
      Aug 29th, 2004
      IA
      99 GLX 3.0T, 90 Jetta GL VR, 94 Jetta GL AWD R32TT
      10-14-2014 07:23 PM #12
      I am running a gtx3582r .82Tial housing and boost 20psi at half pedal by 3600rpm. Traction is a problem in 1-4
      My AWD MK3 Build:
      - Semi build thread
      CTS Turbo
    13. 10-14-2014 08:10 PM #13
      Which trans are you running? ^
    14. Member Jckl's Avatar
      Aug 29th, 2004
      IA
      10-14-2014 09:31 PM #14
      Quote Originally Posted by Dimmu View Post
      Stock waiting for exploding hence my half pedal. Trying to decide between APTuning gears or spend the cash on either SQS or Par engineering. I would like AP Tuning as they are ~$1500 cheaper and not straight cut so they won't be as loud. The concern I have is what kind of power can they take. I am rather happy that my stock trans has stayed in 1 unit thus far.
      What is everyone else running.
      My AWD MK3 Build:
      - Semi build thread
      CTS Turbo
    15. Member zwogti's Avatar
      Jan 11th, 2004
      Deerfied Beach, Florida
      2000 vr6 gti, 2001 vr6 jetta, 96 gti vr6-T Haldex
      10-19-2014 04:08 PM #15
      if you're not going over 500hp a 62MM turbo will be fine with a T4 .69 or .81 depending how much power and how fast you want boost to come in, just keep it in mind that as faster the boost comes in less traction you'll have, a good idea would be a dual stage boost controller, low boost in first/second gear and high boost in 3rd and up.
      2000 VR6 GTI, 2001 VR6 Jetta, 96 GTI VR6-T Haldex
    16. Member zwogti's Avatar
      Jan 11th, 2004
      10-19-2014 09:12 PM #16
      Quote Originally Posted by Jckl View Post
      what tranny are you using and how much power to the wheels are you planning to have in the future?
    17. Member Jckl's Avatar
      Aug 29th, 2004
      IA
      Yesterday 02:12 PM #17
      Quote Originally Posted by zwogti View Post
      I thought about an O2M swap in this car but decided I will probably stay O2A. I would like to see 500+
      My AWD MK3 Build:
      - Semi build thread
      CTS Turbo
    18. Member zwogti's Avatar
      Jan 11th, 2004
      Yesterday 10:36 PM #18
      How heavy is the car?
      500+ to the wheel or crank HP?
      Is the car front wheel drive?
      Are you getting stronger after market axles?
