    Results 1 to 21 of 21
    Thread: Fastest stock block supercharged VR?
      Jul 9th, 2009
      Dirty jerz
      97 jetta GLX
      10-11-2014 08:41 PM #1
      Curious if theres anyway to lookup or anyone who knows what the fastest 1/4 mile is for a stock bottom end supercharged 12v is? Talking stock rods/pistons/crank.. I do have arp rod bolts does that make me not stock bottom end? If so whats the quickest 12v supercharged?
      "You see, i'm from Jersey."
      That'll cover about anything.
      VRalliance #6
    2. Member R32Smoker's Avatar
      Oct 21st, 2010
      Dahlonega, Ga
      01 Jetta VRT
      10-12-2014 03:11 PM #2
      No idea, but dragtimes.com is a pretty cool website that is a database for 1/4 mile times and what mods were done to get that time, check it out. I'm gonna guess mid to low 12's in street trim, could be quicker in a gutted car or mk1/2?
      Jul 9th, 2009
      Dirty jerz
      97 jetta GLX
      10-12-2014 06:37 PM #3
      Well ive already cut a 12.7 spinning first at a moddest 11psi of boost in my full interior mk2 . The cars capable of low 12s but id like to set a "goal" it would be awesome to say i have the fastest supercharged 12v on record haha
      VRalliance #6
    4. Member SUPERCHARGED-JETTA's Avatar
      Aug 7th, 2001
      Orlando, FL
      92' Slc 93' Drag car
      10-12-2014 10:05 PM #4
      I ran 11.97 supercharged long time ago...
      1993 Corrado drag car 10.60@138
      Wiseco - Eurospec - Arp Hardware - Dsr 256 - Pte 6765 - Precision 46mm wastegate - Afi turbo manifold - Microtech Lt10s engine management - Aptuning Gear set - Clutch masters twin disc - Driveshaftshop - Bogart racing wheels - M&H 26" Tires - E85
    5. Member vw1320's Avatar
      Jul 11th, 2000
      Can't catch gone
      All Motor 12v
      10-12-2014 10:20 PM #5
      I went 11.65 with a stock block/head/clutch and on pump gas. I did have small cams but no valve springs. That was on 22x8x15" MT and the car weighed somewhere in the 2500-2600lb range with me in it.
      s/c vr6 running 11.65: http://youtu.be/VaowK5_faaU
      It was long enough ago I don't remember many of the details. Towards the end I was coming to the limit of a bunch of components. As it was still a street car and I didn't want to put a bar in it anyway and not knowing how much was left I ended up taking the charger off and going all motor. For comparison sake the same car went 11.8 @2200 lbs all motor, still a stock block/head. I am confident that if I tried a supercharger again I could go quicker than 11.6 but I am not sure how low.
      Would love to see someone take a shot at the record.
      11.82@113 First and only All Motor 12v Street Car in the 11' s
    6. Member
      Jul 9th, 2009
      Dirty jerz
      97 jetta GLX
      10-13-2014 07:07 AM #6
      Do you remember what boost pressure that was at? Sounds like my goal is an 11.50 . My car weighs a bit more then that i believe but ive yet to weigh it, and ill be on the same slicks. That pass looked awesome any chance you remember your mph? and ill also be doing my passes at atco
      VRalliance #6
    7. Member vw1320's Avatar
      Jul 11th, 2000
      Can't catch gone
      All Motor 12v
      10-13-2014 10:17 AM #7
      Unfortunately I don't remember many of the details as that was a while ago. I went 11.7@117 at some point before that. I would imagine mph on the 11.6 pass was in the 117-118 range as I don't remember breaking 120. I was likely running a 2.87" pulley as that is what I ran most of the time. When I first ran 11s the car was around 2700lbs with driver. I am not sure of the weight or boost in the video. At some point towards the end of messing with the sc I took some weight off I just don't know if it was before or after that video.
      I remember going 12.39 on a 205/50/15" BFG drag radial, a 3.12" pulley, and a stock trans without a diff and thinking an 11 second pass wouldn't be that hard. I was so very wrong. Given what I know now I am not sure how difficult it really is either but that is hindsight. I believe to this date I am the only one who has multiple 11 second timeslips though. Would be great to see someone else join the club. Focus on maximizing what you have before you worry about making changes. The record is very beatable but it will likely take dedication and perseverance as that is what it took to set it.
      Jul 9th, 2009
      Dirty jerz
      97 jetta GLX
      10-13-2014 11:50 AM #8
      Im on a 2.87 pulley and 22x8x15 slicks with a diff, the car is only trapping 111-110 though , ill have to try and maximize what i have and tweak some things
      VRalliance #6
    9. Member vw1320's Avatar
      Jul 11th, 2000
      Can't catch gone
      All Motor 12v
      10-13-2014 02:33 PM #9
      110-111 mph is enough to go 12.2-12.3 pretty easily. Just keep going to the track and trying different things . Post a skip if you have one.
    10. Member
      Jul 9th, 2009
      Dirty jerz
      97 jetta GLX
      10-13-2014 03:54 PM #10
      Heres my best pass, 16psi in the slicks, spun first, didnt get enough passes to play with pressure
      https://m.flickr.com/photos/76190185@N05/14908505473/
      VRalliance #6
    11. Member vw1320's Avatar
      Jul 11th, 2000
      Can't catch gone
      All Motor 12v
      10-13-2014 07:18 PM #11
      Get yourself a decent low pressure tire gauge and start at 10psi and work your way down. 16psi is way too high. If I remember correctly somewhere around 8.5 psi but gauges and setups vary. Don't be afraid to get them hot either. You might lose a mph or two but the car should hook much better.
      Jul 9th, 2009
      Dirty jerz
      97 jetta GLX
      10-15-2014 03:15 AM #12
      Hit the track again, dropped tire pressure to 14psi when hot, car hooked like crazy, multiple 1.7 60' passes , last pass of the night was perfect , ran a 12.0 at 113
      http://flic.kr/p/pD6EhG
      VRalliance #6
    13. Member vw1320's Avatar
      Jul 11th, 2000
      Can't catch gone
      All Motor 12v
      10-15-2014 01:02 PM #13
      Congrats that is quite the improvement.
    14. Member
      Jul 9th, 2009
      Dirty jerz
      97 jetta GLX
      10-15-2014 01:44 PM #14
      Im still blown away that you got an all motor vr into the 11s!
      VRalliance #6
    15. Member vw1320's Avatar
      Jul 11th, 2000
      Can't catch gone
      All Motor 12v
      10-15-2014 02:32 PM #15
      Thanks. And to think it all started with a supercharger like yours lol.
      Keep going to the track and chipping away at it. There is more left in the 60ft at the very least.
    16. Member
      Jul 9th, 2009
      Dirty jerz
      97 jetta GLX
      10-15-2014 09:42 PM #16
      Not on this clutch haah , that 1.7 60' tested the limits of it , any harder of a launch and it slipped
      VRalliance #6
    17. Member Dolsson's Avatar
      Jul 23rd, 2008
      1990 Golf VRT, 2007 Rabbit
      10-16-2014 12:23 PM #17
      what kind of power are you guys making? high 11's and low 12's are very impressive!
      Double J Motorwerks
    18. Member
      Jul 9th, 2009
      Dirty jerz
      97 jetta GLX
      10-16-2014 11:11 PM #18
      My car dynoed 307hp a couple weeks ago but since the temps dropped the car feels quicker
      VRalliance #6
    19. Member SUPERCHARGED-JETTA's Avatar
      Aug 7th, 2001
      Orlando, FL
      10-17-2014 07:24 AM #19
      My car made 305 on a mustang dyno. 11.9@117 More fun now that I have gone turbo!
    20. Member vw1320's Avatar
      Jul 11th, 2000
      Can't catch gone
      All Motor 12v
      10-17-2014 12:36 PM #20
      Atco has an open test and tune tonight after the private rental during the day. Usually some of the best track conditions you will see.
    21. Member
      Jul 9th, 2009
      Dirty jerz
      97 jetta GLX
      10-18-2014 09:27 AM #21
      I really need meth , the heat in my manifold is absolutely killing the car. I loose 3-4mph between a run when the cars just getting to temp and a run after it heat soaks. I was at atco last night, it was terrible , tuesday is really the only day to get good runs in on test and tune, on friday everyone and their mother comes , i only got 2 passes and i was there 4.5 hours
      VRalliance #6
