    Page 1 of 4 1234 LastLast
    Results 1 to 35 of 106
    Thread: Nate's AWD Build Thread
    1. Member WolfsburgNate's Avatar
      Jun 6th, 2006
      Milwaukee
      2001 Wolfsburg Jetta 1.8T, 2005 Jetta TDI
      10-22-2014 10:36 PM #1
      This is where I will be posting and keeping track of all my progress/plans/work on my Jetta. It's a 2001 Uni-Black Wolfsburg Edition that I have had for about 8 years now. My dad was the previous owner so it's been in the family its entire life.
      There will be no bags or stance or any of that stupid **** in this thread so if that's what you're into, well I don't really care.
      The car
      Engine
      - AWW 1.8T
      - APR stage 1
      - Forge DV
      - Forge TIP
      - 034 PCV hoses
      - Probably some other little things I forgot that don't really matter, it's pretty much stock
      Suspension/Steering
      - KW V1 coilovers
      - R32/TT control arms, spindles, front sway bar
      - R32 steering rack
      - Solid Steering rack bushing
      Transmission
      - 5 speed 02J
      - TT short shifter
      - VR6 clutch and ECS lighter flywheel
      Interior
      - Beige cloth interior
      - Full GLI brushed aluminum trim
      - TT pedals with Beetle S dead pedal
      - Newer style center console with more cupholders
      Exterior
      - GLI front lip and side skirts
      - I have a GLI rear lip sitting in the shop that will be a key component in the AWD conversion
      - Hella GLI tailights
      - Kamei front grille
      - Hood notch filled
      - OEM HID's (replicas ) with glass lenses
      - OEM Australian market headlights covers
      - OEM GLI BBS RC's
      Electrical Stuff
      - CCM upgraded from earlier 1J0 to newer 1C0
      - Full FIS UK sport cluster
      - Power folding mirrors
      - Homelink Visor
      - Pioneer AVIC-X940BT head unit
      - Rockford Fosgate 4 channel amp and door speakers (don't remember what these are it was done soooo long ago)
      - mk6 steering wheel (I think its from a Scirocco) retrofitted to work with the Pioneer radio
      - Climatronic swapped
      - Functioning OEM headlight/tailight/brake light monitoring system on the cluster
      - Headlight leveling motors
      After dreaming about doing an AWD swap for years, I literally had all of the hard to find R32 parts fall into my lap (thanks to Brian, JettaGetUpAndGo and Andy, milwaukeeandy) and decided I had to do it, there was no other option. All the .:R parts came out of Andy's old car that unfortunately got totaled but it will live on! The front .:R suspension parts I have are also out of his old car (spindles, control arms, swaybar and whatnot). I had no interest in using an R32 or any other V6 engine so I obviously had to find an AWD TT transmission. Not long after purchasing the R32 rear components I found a low mileage AWD 6 speed 02M TT transmission for sale over in Michigan. After about 6 hours of driving and 3 hours of sitting in traffic in the middle of nowhere in Indiana, I finally had everything I needed to start with the swap. My best friend's dad was nice enough to rent me out a HUGE space to work on it too which is awesome. Its pretty much turned into our man cave.
      R32 rear differential, haldex controller, subframe, control arms, trailing arms, fuel tank, and AWD TT transmission.
      R32 prop shaft and new front axles. I was able to find AWD axles that fit with the older 02J hubs that use an axle nut instead of the bolt that is usually used with the 02M transmissions. Those hubs that use the axle bolt are expensive as **** so I'm really glad I was able to find these axles. I think they came off of the less common 5 speed AWD TT.
      I picked up a 2005 TDI Jetta to drive around in the meantime while I was working on the other car. Before starting I changed the timing belt on it, fixed the ebrake cables, threw on the roof rack, and obviously had to install an MFA screen; because how am I supposed to drive a TDI without knowing how many MPG's I'm getting?. Plus, once you have and FIS screen, it really sucks not having one haha.
      The new Daily
      List of things to accomplish:
      1) Finish installing the floor pan
      2) Fabricate a floor extension in the trunk since the Jetta pan is longer
      3) Seam seal and paint everything once installed
      4) Install new 6 speed AWD transmission and new Southbend clutch (this is where things get more fun/less terrifying )
      5) Refresh front axles with new boots and grease
      6) ESP swap
      7) DWA siren
      8) Interior monitoring
      9) Clean up old wiring behind dash
      10) Wire Haldex controller
      11) Run wiring and vacuum line for exhaust flapper solenoid
      12) Reroute amp power wire and boost gauge line
      13) Add terminals in connectors in rain tray for all wiring into the bay then plug the firewall hole
      a) Temperature sensor
      b) Climatronic
      c) Headlight leveling
      d) ESP sensor
      e) DWA siren
      14) Fix driver's side heated seat
      15) Finish mk6 steering wheel retrofit to get the right side steering wheel buttons to function
      16) Wiring for rear view mirror
      17) Footwell lights
      18) Rewire side mirror defrost to be controlled off of the rear defroster switch
      19) Install backup camera in the trunk lid
      20) Run wire to driver's side door for trunk release switch
      21) Get some body work done
      The plan is to get the Haldex working 100% stock like and get the Haldex flash from United Motorsports (I think that's the one that has the flash). I did some reading on it the other day and it sounds awesome .
      Time to get to work
    2. Member im_lower's Avatar
      Feb 25th, 2011
      Destin, FL
      2003 Jetta 1.8T, 2013 Mustang GT 5.0, 08 Volvo S40
      10-22-2014 11:11 PM #2
      How old would you be, if you didn't know how old you were?
      Alaskan Green build thread.
    3. Junior Member
      Jun 1st, 2011
      Wisconsin, US
      02 VW Jetta GLS 1.8t
      10-22-2014 11:18 PM #3
      Sweet! Then i can come over and you can do mine! I would offer a set of hands if you need but I can also supervise and just stay out of way(also in milwaukee area). Can't wait to see the build
      I refuse to drop it.
    4. Member rand0mher0's Avatar
      Mar 2nd, 2010
      NJ 07840
      05 rs jetta 8v; 03 rs jetta 20v
      10-22-2014 11:20 PM #4
      05 reflex silver jetta 2.0 5psd - r.i.p. :'(
      03 reflex silver jetta 1.8t 5spd - gonzo stage 2
      Instagram: rand0mher0
      The thread where my car gets modified
      Parting out my old jetta
    5. Member WolfsburgNate's Avatar
      Jun 6th, 2006
      Milwaukee
      10-23-2014 10:27 AM #5
      Quote Originally Posted by vwoutlaw View Post
      Haha you can just stand there and drink my beer and watch like my buddy does .
      Progress will be slow at first because since I started renting this space my friend thinks it means I can spend all my time working on his stupid BMW. Only one car fits in there easily so gotta get that out of the way first.... I hate that ****ing car haha .
    6. Moderator 03_uni-B's Avatar
      Sep 6th, 2005
      WV & KY
      Bagged 03 24v GLI RIP, 65 Mustang Fastback Sold, '12 RB R
      10-23-2014 10:36 AM #6
      New favorite build thread
    7. Member Charles Devine's Avatar
      Aug 21st, 2007
      Florida
      13 Jetta Sedan TDI DSG | 02 GLI 24V
      10-23-2014 11:20 AM #7
      Quote Originally Posted by 03_uni-B View Post
      on a serious note, I can't wait to see this thing started
      -Charles
    8. Member Einkaufswagen's Avatar
      Oct 25th, 2009
      Rhode Island
      2001 Baltic Green Jetta GLX, 2003 W8 Passat Wagon 6speed, 1982 Mk1 Caddy ABA
      10-23-2014 11:42 AM #8
      Ohh I see how it is. Don't think I'm gona update my page 1 to reflect your "New" build thread location :p
      My OEM+ Builds & Timelines: Einkaufswagen's MK4 Build, Einkaufswagen's W8 Timeline, Einkaufswagen's Mk1 Caddy Rebuild
      Cars Owned: 1999.5 Jetta VR6 GLS, 2000 Jetta VR6 GLX, 2001 Jetta VR6 GLX, 2001 Jetta VR6 GLX, 2004 Jetta GLI 1.8T, 2000 GTI 1.8T, 2004 Jetta GLI 1.8T, 2003 Passat Wagon W8 6Speed 1982 Rabbit Caddy ABA
    9. Member TheTynosaur's Avatar
      Jul 26th, 2012
      Hoschton, GA
      2001 Jetta 2.0
      10-23-2014 12:13 PM #9
      in
      Quote Originally Posted by AKrett View Post
      A vortex superstar in the mk4 forum is prob equivalent to winning gold in the special Olympics.
      Quote Originally Posted by screwloose45 View Post
      Welcome to vwvortex, where you spend years and all of your money trying to be the epitome of what everyone thinks is cool...only to be **** on, all over, as you miss the mark by inches
    10. Member 03gli401k's Avatar
      Jul 8th, 2006
      Rhode Island
      Bagged GT35R 24V GLI
      10-23-2014 01:07 PM #10
      In for this, seams like a lot of people are doing this now. I want to be one of them too
      do you have the floor pan from a tt or .:R
    11. Junior Member
      Jun 1st, 2011
      Wisconsin, US
      10-23-2014 01:23 PM #11
      Quote Originally Posted by WolfsburgNate View Post
      I can bring beer to share. I'm not a leech lol (And the extra hand offer is legit if needed. Been a while since getting my hands dirty.)
      That car has a neutral, push that B out of there and get working!
    12. Member WolfsburgNate's Avatar
      Jun 6th, 2006
      Milwaukee
      10-23-2014 01:31 PM #12
      Quote Originally Posted by 03gli401k View Post
      All the parts are from milwaukeeandy's totaled R32, with the exception of the transmission and front axles which are from a TT. The plan is to make it work 100% stock like with the stock Haldex controller and wiring.
      Yeah I might just start disassembling the interior first since I don't have to have the car up in the air for that.
    13. Member Fastvolks's Avatar
      Apr 30th, 2003
      Somewhere Bananas
      MK4 & MK6 GTI • 1986 Audi 4000CS Quattro
      10-23-2014 01:33 PM #13
    14. Member Einkaufswagen's Avatar
      Oct 25th, 2009
      Rhode Island
      10-23-2014 01:52 PM #14
      Gona do the ESP swap at the same time?
      Everything your doing as usual is relevant to my interests
    15. Member Dave, Bro's Avatar
      Jun 2nd, 2012
      Rochester, NH
      2000 VW Jetta TDI (daily) 2000 VW GTI 1.8t (lawn ornament)
      10-23-2014 01:58 PM #15
      Good stuff.
      Instagram : @davexbro \ 1.8T \ TDI \ Lace Up \ BeastCoast \ Rochester NH GTG http://forums.vwvortex.com/showthrea...chester-NH-GTG
      Quote Originally Posted by 87vr6 View Post
      Sucks having a 6 speed, but not really.
    16. Member WolfsburgNate's Avatar
      Jun 6th, 2006
      Milwaukee
      10-23-2014 02:03 PM #16
      Quote Originally Posted by Einkaufswagen View Post
      ESP is required for AWD duh Josh
    17. Member Einkaufswagen's Avatar
      Oct 25th, 2009
      Rhode Island
      10-23-2014 04:12 PM #17
      I was going to put the "ORLY" or "YA DONT SAY" **** in here but i actually totally forgot about that and you are right haha.
    18. Member
      Nov 23rd, 2012
      Dallas, TX
      96 Jetta GL
      10-23-2014 06:28 PM #18
      Bruh.
      Quote Originally Posted by burritowagen View Post
      In this case originality isn't a good thing.
      Flickr Instagram:@mk3_shtbox
    19. Member boradie sucht's Avatar
      Aug 12th, 2012
      ¯\ (º_o) /¯
      mk4/mk5
      10-23-2014 06:32 PM #19
      jettaaddiction/bbsrs
    20. Member passattimmy's Avatar
      Oct 13th, 2011
      NJ 08833
      04 1.8T GTI-R.I.P. 05 1.8T JTI-Money Pit
      10-23-2014 06:51 PM #20
      How did I not see this yesterday?!?!?!?! Guess I've been slacking
      Now
      Yeah fck that He still has a lot of stuff to write down other than the AWD swap
      Quote Originally Posted by jobothehobo View Post
      passattimmy.... you're a boss
      WHAT THE ****! I think I might go home sick from work and skip the wedding I am best man in tomorrow.
      Plug and play harness for lit Jetta vents|PM ME ABOUT THE SEIDL GRILLE GROUP BUY!|My OEM+ JTi
    21. Member WolfsburgNate's Avatar
      Jun 6th, 2006
      Milwaukee
      10-23-2014 07:15 PM #21
      Quote Originally Posted by passattimmy View Post
      Now
      If someone steals my friend's beamer and drives it into Lake Michigan this build will progress a lot faster, just sayin'
    22. Member REVoKED DuB's Avatar
      Jul 16th, 2008
      pot hole township nj
      R32 CandyWagon
      10-23-2014 07:15 PM #22
      this will prolly be a 100 pages before my car runs also
    23. Junior Member
      Jun 1st, 2011
      Wisconsin, US
      10-23-2014 07:35 PM #23
      i can bring beer.
      This
    24. Member passattimmy's Avatar
      Oct 13th, 2011
      NJ 08833
      10-23-2014 09:00 PM #24
      Pay for my plane ticket
    25. Member Einkaufswagen's Avatar
      Oct 25th, 2009
      Rhode Island
      10-24-2014 03:22 PM #25
      Il bring the gasoline and we can just push it out of the shop and torch it
    26. Member WolfsburgNate's Avatar
      Jun 6th, 2006
      Milwaukee
      10-24-2014 03:30 PM #26
      The idea is that he has to have no idea that I had anything to do with it, that won't work haha
    27. Member Einkaufswagen's Avatar
      Oct 25th, 2009
      Rhode Island
      10-24-2014 03:32 PM #27
      Well try the more logical thing and tell him to go fix his own turd
    28. Member WolfsburgNate's Avatar
      Jun 6th, 2006
      Milwaukee
      10-24-2014 03:44 PM #28
      Whoops, double post
    29. Moderator 03_uni-B's Avatar
      Sep 6th, 2005
      WV & KY
      10-24-2014 04:12 PM #29
      Quote Originally Posted by REVoKED DuB View Post
    30. 10-24-2014 05:30 PM #30
      Quote Originally Posted by SoIAteABlueWaffleToday View Post
      Air ride because I'm a paid ass ***** and I'll do as I please. Do I need to wear 6gold chains no but I do it for hoes
    31. Member Charles Devine's Avatar
      Aug 21st, 2007
      Florida
      10-24-2014 05:58 PM #31
      We are off to the races here already I see.
      -Charles
    32. Member Vettes, Volvos and VWs's Avatar
      Mar 5th, 2006
      Sudbury, ON
      01 Passat Wagon 4motion, 02 Jetta 1.8T, 10 CC 3.6 4motion
      10-24-2014 07:16 PM #32
      Ermahgerd build thread
      Quote Originally Posted by Baconator14 View Post
      vettes, volvos, and vws for president
      Quote Originally Posted by UAlvarez View Post
      you're a boss. your sig is appropriate
      My Weak Shiz l Milk █Bg█ Mafia GLI Aluminum trim for Sale Click here and PM me for Speed-Tech Hood Extensions!
    33. Member ZG86's Avatar
      Sep 17th, 2006
      OHIO
      05 GTI, 01.5 Audi S4 avant
      10-24-2014 07:31 PM #33
      OOOOHHH
      Ohio State
      .::Stout Kraut::.
    34. Member WolfsburgNate's Avatar
      Jun 6th, 2006
      Milwaukee
      11-04-2014 11:50 PM #34
      Finally got that stupid beamer out of the way so I could get to work.
      Got this ********** out today....
      The floorpan in all it's glory...
      Just have to cram it in here, can't be too much work right?
      Not bad for only a few hours on the first day I could actually work on the car. Aside from fabricating the pan in there it doesn't seem like it's going to be too much work at all, and I've got a guy to help me now who's a skilled welder/fabricator. Just have to take the fuel tank, seats, carpet and some wiring out and its cutting time.
      I'll also be thoroughly enjoying the fuel savings in the TDI in the mean time
    35. Member passattimmy's Avatar
      Oct 13th, 2011
      NJ 08833
      11-05-2014 01:29 AM #35
      Now come do mine
