    Results 1 to 9 of 9
    Thread: My daily driver- Big turbo MKV GTI
    1. Member GTX.16V's Avatar
      Sep 15th, 2013
      NJ
      Turbo Hatch
      10-24-2014 02:08 PM #1
      I don't recall making a thread about this car in the Forced Induction forum. I've owned this car since 2011, and it has had the GTX35R setup on it since May of 2013; about 20k miles and counting. It has 159k on it, and I drive it anywhere between 200 and 400 miles a week. It made 384whp/316wtq @ 19.5 psi of boost.
      Turbo components were supplied by www.atpturbo.com.
      Fabrication of the manifolds, charge pipes, down pipe, etc. was done by Ed @ www.fferacing.com. Also bought the clutch, LSD, and Tial housing for the turbo through FFE.
      Current setup:
      2006 GTI 2.0T
      Turbo Kit:
      GTX3582R w/ Tial .63 a/r V-Band turbine housing
      FFE Tubular bottom mount exhaust manifold
      FFE custom intake manifold utilizing a back plate that I designed and machined with integrated velocity stacks
      FFE aluminum throttle body pipe, charge pipes, downpipe and dump tube
      FFE 4" diameter intake
      Tial MVS 38mm wastegate
      Tial Q BOV
      Garrett 600hp intercooler
      Hallman MBC
      GHL 3" exhaust
      Engine:
      Stock, at the moment
      VF engine mounts
      HPA subframe insert
      Fueling:
      Autotech HPFP internals
      RS4 injectors
      Custom stainless steel protective cover for the N276 valve, designed and made by me.
      The car is currently running a .doTuning tune.
      Clutch/Transmission:
      Clutchmasters FX725 twin disk
      Peloquin LSD
      Dieselgeek Sigma 6 shifter
      TWM Performance weighted shift knob
      Suspension/Wheels/Brakes/Tires:
      18" BBS CH
      225/40/18 Hankook S1 Noble tires
      H&R Ultra-low coilovers
      Brembo slotted and coated rotors, front and rear
      Hawk HPS pads, front and rear
      Some pictures
      20140622_121157 by ALRDESIGN, on Flickr
      Untitled by ALRDESIGN, on Flickr
      | ATP Turbo | FFE Racing | My GTI |
      384whp/316wtq @ 19 psi
      : Garrett GTX3582R/FFE Racing turbo kit & Intake Manifold/Stock engine
      Aug 11th, 2010
      NEOhio
      MK3 Jetta VRT
      10-24-2014 02:43 PM #2
      very clean GTI
      hows it like dailying the FX725 ?
    3. Member GTX.16V's Avatar
      Sep 15th, 2013
      NJ
      Turbo Hatch
      10-24-2014 02:59 PM #3
      Quote Originally Posted by 12V_VR View Post
      very clean GTI
      Thank you!
      Dailying the FX725 is not that bad, now that I am used to it. (This is my first twin disc clutch) It does get a little frustrating in traffic and on large hills when there is stop and go traffic, but other than that, I enjoy it.
    4. Member broko's Avatar
      Mar 18th, 2005
      SOCAL
      1990 VR6 jetta 2dr. 1990 2.0 jetta 2dr.
      12-12-2014 12:18 AM #4
      very nice! are you using an off the shelf tune ?
      edit: nevermind I just noticed the dotuning reference.
    5. 12-12-2014 02:15 AM #5
      Good stuff.. I love me some proper mkvs
      Sent from my iPhone 5 3/4 using Tapatalk
      Quote Originally Posted by theprf View Post
      There is no such thing as an inexpensive Corrado....
    6. Member GTX.16V's Avatar
      Sep 15th, 2013
      NJ
      Turbo Hatch
      12-15-2014 09:46 PM #6
      Thanks guys!
    7. Member 24vGTiVR6's Avatar
      Sep 13th, 2010
      the track
      24v VRT
      12-18-2014 07:56 PM #7
      why did you go with a twin disk?
      Aug 8th, 2004
      Rockaway,NJ
      94 golf
      12-18-2014 11:47 PM #8
      Most likely because he was sick of dealing with clutch bull****.
    9. Member 24vGTiVR6's Avatar
      Sep 13th, 2010
      the track
      24v VRT
      12-19-2014 09:34 AM #9
      What kind of issues? the 725 is good for like 650ft-lb tq (or more) isn't it? It's a nice clean build, I'm not knocking it - just asking a question.
