    Results 1 to 4 of 4
    Thread: p1297 / over boost/ dv flutter sound
      Dec 20th, 2009
      2000 vw jetta 1.8t
      11-24-2014 10:31 PM #1
      so i will start off by saying i have a 2000 jetta 1.8t. it has about 140k miles on it. the car runs and drives good until i build up boost. I will accelerate and my boost will go up to 10psi (which is strange because my car used to max at 7psi) then will drop to 5psi entering limp mode. After hitting 10psi my check engine light will not light up but if i scan my car it says p1297. i have searched and tried many different things to fix this problem. I have a 034 Motorsports pvc system and an upgraded 710n dv i bought from ecs. I hooked up a smoke machine from the brake booster line that leads to the intake manifold. No smoke was found. I looked at my intercooler and it is covered in oil not to the point where it will leave oil spots in the drive way. i replaced all the vacuum hoses from intake manifold to fuel pressure regulator. i have also sprayed every vacuum line with carb cleaner. then next thing i will do is take a better look at my intercooler. i was just trying to see if any one else has experienced these problems before? also i saw on wiki ross maybe its the n249 might be bad just trying to get some help before i throw anymore parts at this car thanks very much.
      Dec 20th, 2009
      2000 vw jetta 1.8t
      11-25-2014 11:33 PM #2
      help!
    3. Member suffocatemymind's Avatar
      Dec 10th, 2007
      Boston/Providence
      2003 Jetta Wolfsburg 20vT, 1994 Dusty Mauve Jetta 8v (sold)
      11-26-2014 09:03 AM #3
      Have you tried doing a pressure test (see FAQ)? You probably have a leak somewhere and that's how you'll find it. A bad N249 will throw a different code FYI
      GL
      -Derek
      APR 93 | ITG | MMEvoDV | 034 Silicone + Catch Can | EuroSport 2.5" DP | BFI Stg 1 | BKR7EIX | NewSouth | VCDS | Bentley
      Stock(ish) been there, done that.
    4. Member
      Dec 20th, 2009
      2000 vw jetta 1.8t
      12-01-2014 12:24 AM #4
      yeah i have not tried that i am going to do that next cause this is driving me nuts haha
