    Results 1 to 11 of 11
    Thread: Do I need to get a wheel alignment? Here's what my dealer said...
    1. Member PaulQ's Avatar
      Sep 10th, 2007
      Phoenix, AZ
      2010 VW CC Luxury
      01-24-2015 01:39 AM #1
      I'm on the verge of new tires and have been going through all the tire threads. My dealer said I needed new tires and reported the following about the ones I have:
      2010 CC, Original Conti tires
      • FRONT TIRES... Abnormally worn and cupped
      • REAR TIRES... Balding on side and chopped
      Do you think I need to get a wheel alignment after I get new tires? It seems like the tire shops just stick the tires on the car without doing any sort of alignment.
      The whole tire shopping experience is proving far more complicated than it needs to be. Too many choices.
      Any advice on the alignment situation?
      (also, when I searched this topic, someone mentioned there might be a known alignment issue with the CC??)
      Thanks!
      PaulQ
      2010 Volkswagen CC Luxury, DSG Transmission, Technology & Appearance Packages
      ...formerly 2008 Touareg 2
    2. Member sfccryder's Avatar
      Nov 24th, 2009
      Castro Valley, CA
      2010 VW CC Sport 2.0T 6M
      01-24-2015 03:07 AM #2
      Yes, yu shud get an alignment once a year, and especially when yu get new tires
      Or suspension mod.
      Island Gray Metallic 2010 CC Sport 2.0T 6M, APR Stage1, R-Line Sport Pedals, HTTRS-256-MA:M
      235/35/19 Hankook Ventus V12 K110's, Borla CBE, Koni ss coilover kit, Adams slotted/drilled rotors, with Stop Tech pads.
    3. Member PaulQ's Avatar
      Sep 10th, 2007
      Phoenix, AZ
      2010 VW CC Luxury
      01-24-2015 03:11 AM #3
      Sorry if this is a stupid question but ....... What should I expect to pay for it? Just a regular alignment for new tires, everything else stock.
      Thanks!!!
      PaulQ
    4. Member sfccryder's Avatar
      Nov 24th, 2009
      Castro Valley, CA
      01-24-2015 03:15 AM #4
      Quote Originally Posted by PaulQ View Post
      Thanks!!!
      It varies.. Anywhereg from 75-100 bucks
    5. Member RadoCC's Avatar
      Apr 7th, 2003
      Indian Trail, NC
      My baby: 1995 Corrado 2.9 VR (OBD2), My daily: 2014 CC R-Line, Wife's ride: 2010 Tiguan S 4Motion
      01-24-2015 06:03 AM #5
      These cars are notorious for needing alignments frequently. I was told by the service advisors to rotate the tires every 5k. The CC comes with a slight "race" camber.
      Corrado Autobiography
      Past German cars owned: 1970 BMW 2002, 1987 VW Fox sedan, 2004 VW Touareg V10 TDI, 2003 VW Passat wagon, 2013 VW CC Sport
      Past non-German cars owned: 1990 Toyota Corolla, 1998 Honda Civic EX, 2002 Subaru Outback
    6. Member
      Jan 27th, 2013
      Austin, TX
      2010 CC 6Speed MT
      01-24-2015 10:44 AM #6
      ^ exactly what they all said.
      You need to get alignment at least once a year.
      I bought lifetime alignment from firestone, paid $150 for it. I get my alignment set at least once a year.
      If you plan on keeping this car then I think lifetime alignment is a good deal
    7. Member kbad's Avatar
      May 26th, 2007
      southlake, TX
      2010 CC 2.0T DSG Sport - Previous VWs: 2006 Passat 2.0T, 1995 GLI, 1987 Jetta 2-Dr, 1980 MkI 2-Dr
      01-24-2015 11:07 AM #7
      Hey Paul .. I had the same issue with my stock contis!!! although, my rears were fine ... Ditto having regular alignments and rotation, ~ $100 for four wheel alignment is fair and gives you a baseline .. My solution, replace with $100 tires, compensate alignment where needed (will have to do it at an Indy because it will be out of VW spec) and let it ride while you monitor ... So far, with the new alignment I've driven over 5k and all four new tires still look and drive like new .. I'm due for a rotation - got me a floor jack so I can do it whenever, myself! .. Good luck!
    8. Member Nethers's Avatar
      Dec 1st, 2013
      Orlando, FL
      2009 VW CC 2.0T Sport
      01-24-2015 12:52 PM #8
      Most shops here wanted $90+. I looked over a bunch and found that most local, non-chain shops had coupons on their site. Browse enough local shops until you find a coupon - I got mine earlier this month for $59.99 with coupon (regularly 89.99).
      There is this awesome place that does it for $40 no coupon, but they're booked solid each day WITHOUT appointments. Unless you can take a day off, you wont get in. He does all the lowered cars around here. I found that by asking around the local JDM / Honda / Integra peoples (they work on old cars as cheaply as possible ). I know that tidbit might not help, but may get you looking in the right direction.
    9. n00b
      Dec 28th, 2013
      Central, MN
      2008 Touareg VR6, 2010 CC VR6 4motion
      01-24-2015 06:25 PM #9
      Yes yes yes! Align once a year. I was an idiot and burned a set of Hankook Ventus V12 because I didn't align my VR6 4motion. This chassis is notorious for needing alignment. Obviously I learned the hard way. What new tires are you looking into? I've got the Conti ExtremeContact DWS and still very pleased after 20k miles on 19" Sagitta wheels.
    10. Member PaulQ's Avatar
      Sep 10th, 2007
      Phoenix, AZ
      2010 VW CC Luxury
      01-25-2015 01:29 AM #10
      WOW! Thanks guys!
      I don't think I ever did an alignment and this is what I get for it. FYI - Dealer in Phoenix charges $149 for alignment. Looks like I need to shop around.
      Getting tires at Discount Tire because they do free rotations.
      Again, thanks!!
      PaulQ
    11. Member kbad's Avatar
      May 26th, 2007
      southlake, TX
      01-25-2015 02:10 AM #11
      hey Paul .. the dealer/vw send out mailers with specials and discounts .. i just had alignment done on special at 89.99 .. check the dealers website for service specials .. later.
