VWVortex.com - Check engine light comes on in the rain
    Results 1 to 7 of 7
    Thread: Check engine light comes on in the rain
    1. 02-16-2003 07:43 PM #1
      The check engine light comes on in the rain or snow. The light will go out after a few days. I guess after the car has completely dried put. The car runs fine otherwise. Anyone have any ideas?
    2. Member XXX008XXX's Avatar
      Mar 25th, 2002
      2000 GTI 1.8t, 72 Standard Beetle, 95 Eagle Talon TSI Auto, 2002 Chevy Tahoe
      02-16-2003 08:00 PM #2
      car stuttering at all?? what is it doing?
      10.30@145 .68 35R
      10.08@141 / 148
      Force Fed Engineering
      Lugtronic
      Boost Factory
    3. Banned
      May 6th, 2002
      02-16-2003 09:54 PM #3
      Sounds like misfiring, coilpack is probably related.
    4. Member Daemon42's Avatar
      Feb 9th, 2001
      colorado
      04 R32T, 95/98 4runner
      02-16-2003 10:13 PM #4
      10 to 1, it's the coil pack.
      Go out in the dark.. open the hood, start the car, spray
      a light mist of water around the coil pack. If you see sparks,
      you got your culprit. (could be the sparkplug wires too, so
      spray over them as well).
      Here's what to do then.
      http://www.gti-vr6.net/library/engin...iled_pack.html
      ian
      May 15th, 2002
      PSU
      mk3 VR6, mk5 GLI
      02-16-2003 11:12 PM #5
      yup the infamous coilpack
    6. 02-16-2003 11:13 PM #6
      most likely coil pack or maybe your o2 wires are xposed.
      Jul 20th, 2000
      NJ
      2013 GTI 4-Door
      02-17-2003 10:12 AM #7
      Could also be the relay pack located below and to the front of the bettery tray. Do you have all of your splash shields in place?
