    Results 1 to 4 of 4
    Thread: Help. Clutch replaced, cluster not working properly.
    1. 03-09-2015 03:35 PM #1
      Hello,
      So recently I replaced my clutch, and all went well. I had an abs light on before I installed the clutch, which I know is a bad rear sensor. Regardless, my odometer works, but my speedo does not, my gas gauge is all over the place, and I have a Cel as well. I have read on some other similar problems where nothing works at all (not even the odometer... but mine works), that it was the speed sensor... so, I guess I'll start off by fixing the abs sensor, but does anyone have any idea where I would go from there?
      thanks, Wyatt
    2. 03-09-2015 03:36 PM #2
      I guess I left out some info. Vehicle is an 03 passat 1.8t awm.
    3. Senior Member 87vr6's Avatar
      Jan 17th, 2002
      West coast, of Okinawa (^^)
      THE IY AWD BT 20TH and 2004 Lupo GTI
      03-09-2015 08:42 PM #3
      Are you sure you plugged the vehicle speed sensor in? Check for large grounds around the transmission
      AWD BT 20th Anni build, check it out...
      flickr
      Contact me for JDM wheels and Newer model VW parts
      IG: @87vr6
    4. 03-11-2015 06:20 PM #4
      Idk if this helps, but it was working the night I got it back together, but the next morning, it stoppped working. The code i have is p0501. Yes, the sensor is plugged in. I guess I'll start off by replacing the sensor.
