    Results 1 to 20 of 20
    Thread: Short-barreled shotguns
    1. 05-07-2015 11:23 AM #1
      Post 'em if you got 'em.
      I just ordered a 14" 12-gauge single for backpacking grouse duty:
      Also have my eye on one of these:
    2. Member Power5's Avatar
      Jun 19th, 2001
      Cincy, Ohio
      '14 Chevy Volt- ALL black ---- '99 XJ 6"-Aussied d44-35" TSL-XRC8
      05-08-2015 01:39 PM #2
      Please put all those attachments on the 2nd one if you get it. Would love a picture with you holding it with all those things stuck on it.
    3. 05-08-2015 02:37 PM #3
      But that would reveal my secret identity, sacrilege to the code of the mall ninja.
    4. Senior Member VWVan's Avatar
      Feb 17th, 2000
      Langley, B.C.
      2007 Ford Fusion SUX, school bus turning radius edition
      05-08-2015 02:59 PM #4
      SAP 6? $700.
      What about the Dominion Arms 12.5"? half the price, but you can't stick on so many things
    5. 05-08-2015 03:20 PM #5
      The mag-fed Dominion Arms Grizzly apparently has jamming issues whereas the SAP-6 seems pretty trouble-free.
      The tube-fed 8.5" Grizzly, on the other hand, looks like a hoot.
    6. Senior Member NoDubJustYet's Avatar
      Mar 25th, 2002
      WNoVA
      MkV GTI
      05-08-2015 07:28 PM #6
      Can someone tell me the difference between AOW and SBS? Obviously the $5 AOW Stamp is a little easier to stomach... What's the deal?
      كافر
      Save the Nürburgring!
      Gotta keep right on the 'Ring. German road rules apply.
      I think you and I have mentioned this one a few times over the years.
      Might as well just make it our signatures at this point.
    7. Senior Member VWVan's Avatar
      Feb 17th, 2000
      Langley, B.C.
      05-08-2015 11:23 PM #7
      Not sure you're using 'murican terms to a couple of canucks. In canadaland its cash and carry for those non restricted above. Just show license and you're good to go.
      Feb 16th, 2005
      ABQ
      '08 WRX, '97 Jetta, '91 Yamaha
      05-10-2015 07:35 AM #8
      Short Bbl Shotgun is cut down below 18" from a full gun. Something like the Super Shorty, my understanding is that Serbu sources virgin receivers that have never been built into anything with a butstock or over the specified OAL and are built to the AOW definition.
    9. Member SlowMotion's Avatar
      Jun 9th, 2002
      NNJ, NYC
      05-16-2015 09:15 PM #9
      Look up black ace tactical new 8" barrel shotgun, foldable sig brace and completely legal. No sbs or aow stamps needed.
    10. Administrator LangsamKafer's Avatar
      Jul 17th, 2001
      2015 Equinox
      05-17-2015 09:31 AM #10
      Quote Originally Posted by SlowMotion View Post
      http://www.blackacestactical.com/#!p...es-tactical-dt
      I know I'm reading it on their website, but that makes absolutely no sense at all.
      https://www.atf.gov/files/firearms/g...rreled-shotgun
      Quote Originally Posted by BATFE
      Classification
      Short Barreled Shotgun
      Distinctive Characteristics
      Shotgun having a barrel or barrels of less than 18 inches in length.
    11. 05-17-2015 01:56 PM #11
      For an interesting read on the effectiveness of short-barelled shotguns, take a look at this:
      http://www.smallarmsreview.com/displ...idarticles=111
    12. Member 00boraslow's Avatar
      May 22nd, 2004
      Lower Burrell, PA
      2008 VW GTI
      05-23-2015 08:46 AM #12
      I own 3 SBS's and they are all a hoot to shoot.
      PSN: Glock23man
    13. Member
      May 8th, 2002
      Plano, TX
      2012 Fiat 500, 1984 VW Vanagon, 2007 Kia Rondo
      05-23-2015 12:29 PM #13
      Quote Originally Posted by LangsamKafer View Post
      I was wondering about that since I used to work for ATF (I left over 10 years ago). In general, a shotgun has to have at least an 18" barrel and be no less than 26" in length overall. Unless something has changed or some of these things are NFA registered, some of you guys look to have some illegal shorties Not that I care, I don't work for them anymore
      Posts may not reflect the views of others, get over it.
    14. Senior Member NoDubJustYet's Avatar
      Mar 25th, 2002
      WNoVA
      MkV GTI
      05-23-2015 02:06 PM #14
      Does it even matter? They'd just make the rules up as the go anyway.
      I hope the rumors of the FBI taking over ATF go through... A regulatory agency that tried to become an enforcement agency is never good.
      كافر
    15. Administrator LangsamKafer's Avatar
      Jul 17th, 2001
      2015 Equinox
      05-25-2015 10:59 PM #15
      Quote Originally Posted by MeineFolks'wagen View Post
      I've done some more reading on this, it appears that since the Sig Brace is not a stock, it is basically "pistol grip only" firearm and not a shotgun*. ie:Not ever designed and intended to be fired from the shoulder. Therefore, since it is not a shotgun, it can not be a short-barreled shotgun and falls under the definition of "firearm" and not any NFA controlled device. Additionally, I believe that since the OAL is over 26" when the brace is open, it does not meet the ATF's definition of 'concealable' which would make it an AOW. On top of that, the foregrip is angled, which has also avoided an AOW ruling from the NFA, unlike the vertical foregrip.
      Quote Originally Posted by Shotgun definition
      The term “shotgun” means a weapon designed or redesigned, made or remade, and intended to be fired from the shoulder and designed or redesigned and made or remade to use the energy of the explosive in a fixed shotgun shell to fire through a smooth bore either a number of projectiles (ball shot) or a single projectile for each pull of the trigger, and shall include any such weapon which may be readily restored to fire a fixed shotgun shell.
      Quote Originally Posted by AOW definition
      The term “any other weapon” means any weapon or device capable of being concealed on the person from which a shot can be discharged through the energy of an explosive, a pistol or revolver having a barrel with a smooth bore designed or redesigned to fire a fixed shotgun shell, weapons with combination shotgun and rifle barrels 12 inches or more, less than 18 inches in length, from which only a single discharge can be made from either barrel without manual reloading, and shall include any such weapon which may be readily restored to fire. Such term shall not include a pistol or a revolver having a rifled bore, or rifled bores, or weapons designed, made, or intended to be fired from the shoulder and not capable of firing fixed ammunition.
      Ref: https://www.law.cornell.edu/uscode/text/26/5845
    16. Member KubotaPowered's Avatar
      Jan 27th, 2005
      Tucson, AZ
      2013 PG GLI
      05-26-2015 01:19 PM #16
      Make sure you check the state laws that you are hunting in. I know that in Montana and North Dakota, you cannot hunt with a shotgun that has a barrel shorter than 20 inches.
      Quote Originally Posted by ..Derek.. View Post
      Clearly you aren't familiar with the "Golden Corrado". It's so clinically clean that in the event that you must urinate it must be done at least one zip code away in fear that it may catch a staph infection.
    17. Member Rbothell1's Avatar
      Nov 7th, 2005
      Northern New Jersey
      2015 Subaru WRX Limited 2010 Subaru Legacy GT Limited
      06-06-2015 05:40 PM #17
      Quote Originally Posted by Old school View Post
      Ok! What is this!!! Details please!
    18. 07-04-2015 12:07 AM #19
      Another shorty I'd love to own, Fabarm stf-12:
    19. 07-04-2015 08:46 AM #20
      I always liked Haley's shorty Saiga Shotgun.
