    Results 1 to 13 of 13
    Thread: 2012 vw cc Rline led license plate and headlight issues
    1. n00b
      Jul 2nd, 2015
      2012 vw cc Rline 2.0t
      07-02-2015 01:08 AM #1
      This is my first post on vwvortex all though I have searched the forum for answers for months. 1st issue I've had since day one of installing led license plate lights is that the license plate out dash light came on. At first I figured it was just the bulbs my local shop installed even though they said they were canbus. Next I ordered bulbs from ijdm toy the dash light still came on even though I tried installing the bulbs both ways. I tried getting my local shop to vagcom the cold diagnostics off for the license plate but they couldn't figure it out.. Then today I received the led plug and play housings from ecs tuning,installed them and bam same issue bulb out light on and gauge cluster reads license plate bulb out.. I even changed the plug into the housing both ways. The bulbs work great and put off a ridiculous amount of light. Question is am I stuck with the bulb out light if I want led's?
    2. n00b
      Jul 2nd, 2015
      07-02-2015 01:21 AM #2
      Second part of my on going issue with lighting is my low beams which at first I had aftermarket h7 hid's installed.. Had a flickering issue so my local shop put in led h7's well in the last 4 months the full sets have been replaced 4 times including the bulbs,ballests and resistors due to flickering progressively getting worse.. Each set lasted a month before starting to flicker/strobe.
      Next I scoured this site looking for answers. Came up with I needed to vagcom my dtrl's off which I had my local vw tuner do for me I also read there was a code to turn off halogen and turn on hid's which they could not figure out/find.. With the dtrl's off I def like being able to fully turn off the headlights during the day and whenever I need to. Today I turned the headlights on a they started flickering on the driver's side intermediatly.. This is getting very frustrating for me and I'm sure the shop owner who has pulled my bumper off 4 times now to replace the installed lighting system... Anyone have any idea's?
    3. Member teknodogg's Avatar
      Nov 18th, 2013
      Dallas, TX
      2010 VW CC Sports
      07-02-2015 10:00 AM #3
      1st - if you already replaced the bulbs just vagcom/vcds to erase the bulb out code if it's actually working
      2nd - flickering issue can also be fixed via vagcom/vcds - or get a relay installed
    4. n00b
      Jul 2nd, 2015
      07-02-2015 10:20 AM #4
      I'm just confused on the license plate why the dash light is on in the first place. I replaced the whole housings with what is supposedly a error free setup shouldn't the car turn the bulb out reading off itself? And for the headlights the only thing he said he saw when in vagcom on my car with a option was turn dtrl's off or on.. He did admit the guy that was doing it wasn't as good at coding as hi s former employee but if there is a option in vagcom to fix the headlights what would it be?
    5. n00b
      Mar 27th, 2015
      St. Albans, NY
      2012 VW CC Sport
      07-03-2015 02:10 AM #5
      I had the same problems with my '12 Sport. I ended up swapping my license plate bulbs for a set from deAutoKey, and my HID guy swapped the ballasts and error eliminator modules for a set of ballasts with the error eliminator built in. It's been approx. 3 months since those changes, and I've been error-free.
      FWIW, I don't think the 2012+ models have that option to switch from halogen to HID in Vag-com (diff CECM). Neither my local VW tuner nor myself could find it anywhere in the software.
    6. n00b
      Jul 2nd, 2015
      07-03-2015 03:52 AM #6
      I'm just going to deal with the bulb out light for the license plate lights I don't want to pull out the 50 dollar hoising s that I just put in.. My headlights have never thrown a bulb out code my issue is after a month or so either one side or both will start flickering/strobing and it starts out every once in a while then gets progressively worse... I don't think it's the bulb because they don't ever go out.. I'm thinking the ballests are over stressed from the car which I thought was from the dtrl's but those are vagcomed off.. I'm not sure the brand of led's they are but the shop who installed them sells lots of them and I think my car is the only one having reoccurring issues... Any input would be appreciated
    7. 07-03-2015 08:12 AM #7
      정통바카라하는법·ぺ rcbc104.com ··ぺ정통바카라하는법·ぺ rcbc104.com ··ぺ정통바카라하는법·ぺ rcbc104.com ··ぺ정통바카라하는법·ぺ정통바카라하는법·ぺ정통바카라하는법·ぺ정통바카라하는법·ぺ정통바카라하는 법·ぺ정통바카라하는법·ぺ정통바카라하는법·ぺ정통바카라하는법·ぺ정통바카라하는법·ぺ정통바카라하는 법·ぺ정통바카라하는법·ぺ정통바카라하는법·ぺ정통바카라하는법·ぺ정통바카라하는법·ぺ정통바카라하는 법·ぺ정통바카라하는법·ぺ정통바카라하는법·ぺ정통바카라하는법·ぺ정통바카라하는법·ぺ정통바카라하는 법·ぺ정통바카라하는법·ぺ정통바카라하는법·ぺ정통바카라하는법·ぺ정통바카라하는법·ぺ정통바카라하는 법·ぺ정통바카라하는법·ぺ정통바카라하는법·ぺ정통바카라하는법·ぺ정통바카라하는법·ぺ정통바카라하는 법·ぺ정통바카라하는법·ぺ정통바카라하는법·ぺ정통바카라하는법·ぺ정통바카라하는법·ぺ정통바카라하는 법·ぺ정통바카라하는법·ぺ정통바카라하는법·ぺ정통바카라하는법·ぺ정통바카라하는법·ぺ정통바카라하는 법·ぺ정통바카라하는법·ぺ정통바카라하는법·ぺ정통바카라하는법·ぺ정통바카라하는법·ぺ정통바카라하는 법·ぺ정통바카라하는법·ぺ정통바카라하는법·ぺ정통바카라하는법·ぺ정통바카라하는법·ぺ정통바카라하는 법·ぺ정통바카라하는법·ぺ정통바카라하는법·ぺ정통바카라하는법·ぺ정통바카라하는법·ぺ정통바카라하는 법·ぺ정통바카라하는법·ぺ정통바카라하는법·ぺ정통바카라하는법·ぺ정통바카라하는법·ぺ정통바카라하는 법·ぺ정통바카라하는법·ぺ정통바카라하는법·ぺ정통바카라하는법·ぺ정통바카라하는법·ぺ정통바카라하는 법·ぺ정통바카라하는법·ぺ정통바카라하는법·ぺ정통바카라하는법·ぺ정통바카라하는법·ぺ정통바카라하는 법·ぺ정통바카라하는법·ぺ정통바카라하는법·ぺ정통바카라하는법·ぺ정통바카라하는법·ぺ정통바카라하는 법·ぺ정통바카라하는법·ぺ정통바카라하는법·ぺ정통바카라하는법·ぺ정통바카라하는법·ぺ정통바카라하는 법·ぺ정통바카라하는법·ぺ정통바카라하는법·ぺ정통바카라하는법·ぺ정통바카라하는법·ぺ정통바카라하는 법·ぺ정통바카라하는법·ぺ정통바카라하는법·ぺ정통바카라하는법·ぺ정통바카라하는법·ぺ정통바카라하는 법·ぺ정통바카라하는법·ぺ정통바카라하는법·ぺ정통바카라하는법·ぺ정통바카라하는법·ぺ정통바카라하는 법·ぺ정통바카라하는법·ぺ정통바카라하는법·ぺ정통바카라하는법·ぺ정통바카라하는법·ぺ정통바카라하는 법·ぺ정통바카라하는법·ぺ정통바카라하는법·ぺ정통바카라하는법·ぺ정통바카라하는법·ぺ정통바카라하는 법·ぺ정통바카라하는법·ぺ정통바카라하는법·ぺ정통바카라하는법·ぺ정통바카라하는법·ぺ정통바카라하는 법·ぺ정통바카라하는법·ぺ정통바카라하는법·ぺ정통바카라하는법·ぺ정통바카라하는법·ぺ정통바카라하는 법·ぺ정통바카라하는법·ぺ정통바카라하는법·ぺ정통바카라하는법·ぺ정통바카라하는법·ぺ정통바카라하는 법·ぺ정통바카라하는법·ぺ정통바카라하는법·ぺ정통바카라하는법·ぺ정통바카라하는법·ぺ정통바카라하는 법·ぺ정통바카라하는법·ぺ정통바카라하는법·ぺ정통바카라하는법·ぺ정통바카라하는법·ぺ정통바카라하는 법·ぺ정통바카라하는법·ぺ정통바카라하는법·ぺ정통바카라하는법·ぺ정통바카라하는법·ぺ정통바카라하는 법·ぺ정통바카라하는법·ぺ정통바카라하는법·ぺ정통바카라하는법·ぺ정통바카라하는법·ぺ정통바카라하는 법·ぺ정통바카라하는법·ぺ정통바카라하는법·ぺ정통바카라하는법·ぺ정통바카라하는법·ぺ정통바카라하는 법·ぺ정통바카라하는법·ぺ정통바카라하는법·ぺ정통바카라하는법·ぺ정통바카라하는법·ぺ정통바카라하는 법·ぺ정통바카라하는법·ぺ정통바카라하는법·ぺ정통바카라하는법·ぺ정통바카라하는법·ぺ정통바카라하는 법·ぺ정통바카라하는법·ぺ정통바카라하는법·ぺ정통바카라하는법·ぺ정통바카라하는법·ぺ정통바카라하는 법·ぺ정통바카라하는법·ぺ정통바카라하는법·ぺ정통바카라하는법·ぺ정통바카라하는법·ぺ정통바카라하는 법·ぺ정통바카라하는법·ぺ정통바카라하는법·ぺ정통바카라하는법·ぺ정통바카라하는법·ぺ정통바카라하는 법·ぺ정통바카라하는법·ぺ정통바카라하는법·ぺ정통바카라하는법·ぺ정통바카라하는법·ぺ정통바카라하는 법·ぺ정통바카라하는법·ぺ정통바카라하는법·ぺ정통바카라하는법·ぺ정통바카라하는법·ぺ정통바카라하는 법·ぺ정통바카라하는법·ぺ정통바카라하는법·ぺ정통바카라하는법·ぺ정통바카라하는법·ぺ정통바카라하는 법·ぺ정통바카라하는법·ぺ정통바카라하는법·ぺ정통바카라하는법·ぺ정통바카라하는법·ぺ정통바카라하는 법·ぺ정통바카라하는법·ぺ정통바카라하는법·ぺ정통바카라하는법·ぺ정통바카라하는법·ぺ정통바카라하는 법·ぺ정통바카라하는법·ぺ정통바카라하는법·ぺ정통바카라하는법·ぺ정통바카라하는법·ぺ정통바카라하는 법·ぺ정통바카라하는법·ぺ정통바카라하는법·ぺ정통바카라하는법·ぺ정통바카라하는법·ぺ정통바카라하는 법·ぺ정통바카라하는법·ぺ정통바카라하는법·ぺ정통바카라하는법·ぺ정통바카라하는법·ぺ정통바카라하는 법·ぺ정통바카라하는법·ぺ정통바카라하는법·ぺ정통바카라하는법·ぺ정통바카라하는법·ぺ정통바카라하는 법·ぺ정통바카라하는법·ぺ정통바카라하는법·ぺ정통바카라하는법·ぺ정통바카라하는법·ぺ정통바카라하는 법·ぺ정통바카라하는법·ぺ정통바카라하는법·ぺ정통바카라하는법·ぺ정통바카라하는법·ぺ정통바카라하는 법·ぺ정통바카라하는법·ぺ정통바카라하는법·ぺ정통바카라하는법·ぺ정통바카라하는법·ぺ정통바카라하는 법·ぺ정통바카라하는법·ぺ정통바카라하는법·ぺ정통바카라하는법·ぺ정통바카라하는법·ぺ정통바카라하는 법·ぺ정통바카라하는법·ぺ정통바카라하는법·ぺ정통바카라하는법·ぺ정통바카라하는법·ぺ정통바카라하는 법·ぺ정통바카라하는법·ぺ정통바카라하는법·ぺ정통바카라하는법·ぺ정통바카라하는법·ぺ정통바카라하는 법·ぺ정통바카라하는법·ぺ정통바카라하는법·ぺ정통바카라하는법·ぺ정통바카라하는법·ぺ정통바카라하는 법·ぺ정통바카라하는법·ぺ정통바카라하는법·ぺ정통바카라하는법·ぺ정통바카라하는법·ぺ정통바카라하는 법·ぺ정통바카라하는법·ぺ정통바카라하는법·ぺ정통바카라하는법·ぺ정통바카라하는법·ぺ정통바카라하는 법·ぺ정통바카라하는법·ぺ정통바카라하는법·ぺ정통바카라하는법·ぺ정통바카라하는법·ぺ정통바카라하는 법·ぺ정통바카라하는법·ぺ정통바카라하는법·ぺ정통바카라하는법·ぺ정통바카라하는법·ぺ정통바카라하는 법·ぺ정통바카라하는법·ぺ정통바카라하는법·ぺ정통바카라하는법·ぺ정통바카라하는법·ぺ정통바카라하는 법·ぺ정통바카라하는법·ぺ정통바카라하는법·ぺ정통바카라하는법·ぺ정통바카라하는법·ぺ정통바카라하는 법·ぺ정통바카라하는법·ぺ정통바카라하는법·ぺ정통바카라하는법·ぺ정통바카라하는법·ぺ
    8. 07-03-2015 08:14 AM #8
      막탄공항카지노◇ゐ rcbc104.com ◇◇ゐ막탄공항카지노◇ゐ rcbc104.com ◇◇ゐ막탄공항카지노◇ゐ rcbc104.com ◇◇ゐ막탄공항카지노◇ゐ막탄공항카지노◇ゐ막탄공항카지노◇ゐ막탄공항카지노◇ゐ막탄공항카지노◇ゐ막탄 공항카지노◇ゐ막탄공항카지노◇ゐ막탄공항카지노◇ゐ막탄공항카지노◇ゐ막탄공항카지노◇ゐ막탄공항카지노 ◇ゐ막탄공항카지노◇ゐ막탄공항카지노◇ゐ막탄공항카지노◇ゐ막탄공항카지노◇ゐ막탄공항카지노◇ゐ막탄공 항카지노◇ゐ막탄공항카지노◇ゐ막탄공항카지노◇ゐ막탄공항카지노◇ゐ막탄공항카지노◇ゐ막탄공항카지노◇ ゐ막탄공항카지노◇ゐ막탄공항카지노◇ゐ막탄공항카지노◇ゐ막탄공항카지노◇ゐ막탄공항카지노◇ゐ막탄공항 카지노◇ゐ막탄공항카지노◇ゐ막탄공항카지노◇ゐ막탄공항카지노◇ゐ막탄공항카지노◇ゐ막탄공항카지노◇ゐ 막탄공항카지노◇ゐ막탄공항카지노◇ゐ막탄공항카지노◇ゐ막탄공항카지노◇ゐ막탄공항카지노◇ゐ막탄공항카 지노◇ゐ막탄공항카지노◇ゐ막탄공항카지노◇ゐ막탄공항카지노◇ゐ막탄공항카지노◇ゐ막탄공항카지노◇ゐ막 탄공항카지노◇ゐ막탄공항카지노◇ゐ막탄공항카지노◇ゐ막탄공항카지노◇ゐ막탄공항카지노◇ゐ막탄공항카지 노◇ゐ막탄공항카지노◇ゐ막탄공항카지노◇ゐ막탄공항카지노◇ゐ막탄공항카지노◇ゐ막탄공항카지노◇ゐ막탄 공항카지노◇ゐ막탄공항카지노◇ゐ막탄공항카지노◇ゐ막탄공항카지노◇ゐ막탄공항카지노◇ゐ막탄공항카지노 ◇ゐ막탄공항카지노◇ゐ막탄공항카지노◇ゐ막탄공항카지노◇ゐ막탄공항카지노◇ゐ막탄공항카지노◇ゐ막탄공 항카지노◇ゐ막탄공항카지노◇ゐ막탄공항카지노◇ゐ막탄공항카지노◇ゐ막탄공항카지노◇ゐ막탄공항카지노◇ ゐ막탄공항카지노◇ゐ막탄공항카지노◇ゐ막탄공항카지노◇ゐ막탄공항카지노◇ゐ막탄공항카지노◇ゐ막탄공항 카지노◇ゐ막탄공항카지노◇ゐ막탄공항카지노◇ゐ막탄공항카지노◇ゐ막탄공항카지노◇ゐ막탄공항카지노◇ゐ 막탄공항카지노◇ゐ막탄공항카지노◇ゐ막탄공항카지노◇ゐ막탄공항카지노◇ゐ막탄공항카지노◇ゐ막탄공항카 지노◇ゐ막탄공항카지노◇ゐ막탄공항카지노◇ゐ막탄공항카지노◇ゐ막탄공항카지노◇ゐ막탄공항카지노◇ゐ막 탄공항카지노◇ゐ막탄공항카지노◇ゐ막탄공항카지노◇ゐ막탄공항카지노◇ゐ막탄공항카지노◇ゐ막탄공항카지 노◇ゐ막탄공항카지노◇ゐ막탄공항카지노◇ゐ막탄공항카지노◇ゐ막탄공항카지노◇ゐ막탄공항카지노◇ゐ막탄 공항카지노◇ゐ막탄공항카지노◇ゐ막탄공항카지노◇ゐ막탄공항카지노◇ゐ막탄공항카지노◇ゐ막탄공항카지노 ◇ゐ막탄공항카지노◇ゐ막탄공항카지노◇ゐ막탄공항카지노◇ゐ막탄공항카지노◇ゐ막탄공항카지노◇ゐ막탄공 항카지노◇ゐ막탄공항카지노◇ゐ막탄공항카지노◇ゐ막탄공항카지노◇ゐ막탄공항카지노◇ゐ막탄공항카지노◇ ゐ막탄공항카지노◇ゐ막탄공항카지노◇ゐ막탄공항카지노◇ゐ막탄공항카지노◇ゐ막탄공항카지노◇ゐ막탄공항 카지노◇ゐ막탄공항카지노◇ゐ막탄공항카지노◇ゐ막탄공항카지노◇ゐ막탄공항카지노◇ゐ막탄공항카지노◇ゐ 막탄공항카지노◇ゐ막탄공항카지노◇ゐ막탄공항카지노◇ゐ막탄공항카지노◇ゐ막탄공항카지노◇ゐ막탄공항카 지노◇ゐ막탄공항카지노◇ゐ막탄공항카지노◇ゐ막탄공항카지노◇ゐ막탄공항카지노◇ゐ막탄공항카지노◇ゐ막 탄공항카지노◇ゐ막탄공항카지노◇ゐ막탄공항카지노◇ゐ막탄공항카지노◇ゐ막탄공항카지노◇ゐ막탄공항카지 노◇ゐ막탄공항카지노◇ゐ막탄공항카지노◇ゐ막탄공항카지노◇ゐ막탄공항카지노◇ゐ막탄공항카지노◇ゐ막탄 공항카지노◇ゐ막탄공항카지노◇ゐ막탄공항카지노◇ゐ막탄공항카지노◇ゐ막탄공항카지노◇ゐ막탄공항카지노 ◇ゐ막탄공항카지노◇ゐ막탄공항카지노◇ゐ막탄공항카지노◇ゐ막탄공항카지노◇ゐ막탄공항카지노◇ゐ막탄공 항카지노◇ゐ막탄공항카지노◇ゐ막탄공항카지노◇ゐ막탄공항카지노◇ゐ막탄공항카지노◇ゐ막탄공항카지노◇ ゐ막탄공항카지노◇ゐ막탄공항카지노◇ゐ막탄공항카지노◇ゐ막탄공항카지노◇ゐ막탄공항카지노◇ゐ막탄공항 카지노◇ゐ막탄공항카지노◇ゐ막탄공항카지노◇ゐ막탄공항카지노◇ゐ막탄공항카지노◇ゐ막탄공항카지노◇ゐ 막탄공항카지노◇ゐ막탄공항카지노◇ゐ막탄공항카지노◇ゐ막탄공항카지노◇ゐ막탄공항카지노◇ゐ막탄공항카 지노◇ゐ막탄공항카지노◇ゐ막탄공항카지노◇ゐ막탄공항카지노◇ゐ막탄공항카지노◇ゐ막탄공항카지노◇ゐ막 탄공항카지노◇ゐ막탄공항카지노◇ゐ막탄공항카지노◇ゐ막탄공항카지노◇ゐ막탄공항카지노◇ゐ막탄공항카지 노◇ゐ막탄공항카지노◇ゐ막탄공항카지노◇ゐ막탄공항카지노◇ゐ막탄공항카지노◇ゐ막탄공항카지노◇ゐ막탄 공항카지노◇ゐ막탄공항카지노◇ゐ막탄공항카지노◇ゐ막탄공항카지노◇ゐ막탄공항카지노◇ゐ막탄공항카지노 ◇ゐ막탄공항카지노◇ゐ막탄공항카지노◇ゐ막탄공항카지노◇ゐ막탄공항카지노◇ゐ막탄공항카지노◇ゐ막탄공 항카지노◇ゐ막탄공항카지노◇ゐ막탄공항카지노◇ゐ막탄공항카지노◇ゐ막탄공항카지노◇ゐ막탄공항카지노◇ ゐ막탄공항카지노◇ゐ막탄공항카지노◇ゐ막탄공항카지노◇ゐ막탄공항카지노◇ゐ막탄공항카지노◇ゐ막탄공항 카지노◇ゐ막탄공항카지노◇ゐ막탄공항카지노◇ゐ막탄공항카지노◇ゐ막탄공항카지노◇ゐ막탄공항카지노◇ゐ 막탄공항카지노◇ゐ막탄공항카지노◇ゐ막탄공항카지노◇ゐ막탄공항카지노◇ゐ막탄공항카지노◇ゐ막탄공항카 지노◇ゐ막탄공항카지노◇ゐ막탄공항카지노◇ゐ막탄공항카지노◇ゐ막탄공항카지노◇ゐ막탄공항카지노◇ゐ막 탄공항카지노◇ゐ막탄공항카지노◇ゐ막탄공항카지노◇ゐ막탄공항카지노◇ゐ막탄공항카지노◇ゐ막탄공항카지 노◇ゐ막탄공항카지노◇ゐ막탄공항카지노◇ゐ막탄공항카지노◇ゐ막탄공항카지노◇ゐ막탄공항카지노◇ゐ막탄 공항카지노◇ゐ막탄공항카지노◇ゐ막탄공항카지노◇ゐ막탄공항카지노◇ゐ막탄공항카지노◇ゐ막탄공항카지노 ◇ゐ막탄공항카지노◇ゐ막탄공항카지노◇ゐ막탄공항카지노◇ゐ막탄공항카지노◇ゐ막탄공항카지노◇ゐ막탄공 항카지노◇ゐ막탄공항카지노◇ゐ막탄공항카지노◇ゐ막탄공항카지노◇ゐ막탄공항카지노◇ゐ막탄공항카지노◇ ゐ막탄공항카지노◇ゐ막탄공항카지노◇ゐ막탄공항카지노◇ゐ막탄공항카지노◇ゐ막탄공항카지노◇ゐ막탄공항 카지노◇ゐ막탄공항카지노◇ゐ막탄공항카지노◇ゐ막탄공항카지노◇ゐ막탄공항카지노◇ゐ막탄공항카지노◇ゐ 막탄공항카지노◇ゐ
    9. Junior Member
      Nov 13th, 2012
      Orlando, FL
      2012 VW CC
      07-03-2015 04:29 PM #9
      I've had same problem myself. On 2012 model there is no such option as "xenon lights without shutter". However, there is an option in byte19 "headlight dimming(life time extension)" which is on by default. So to make HIDs work, in VCDS you need to disable DRL and make headlight dimming inactive.
      For the license plate leds, there is also an option that needs to be unchecked in vcds, called "license plate cold diagnostic". After that you won't see any errors.
    10. Member echristie's Avatar
      Oct 30th, 2013
      Richmond, Texas
      2012 CC Lux +, 2005 Tahoe, 2007 M109, 1993 Pontiac Formula, 1970 Chevelle, 1965 El Camino
      07-03-2015 08:56 PM #10
      Quote Originally Posted by timoshina View Post
      What section is that under? I have a set of HIDs I was planning to install this weekend. Will need to VCDS since mine is a 2012 as well.
      2012 VW CC Lux Plus
      2005 Chevrolet Tahoe (original owner) - 5.3L, 20" wheels, tune, air bags
      1993 Pontiac Formula (original owner) - 355 LT1, many, many mods - 13.8 @ 102 mph
      1970 Chevelle SS - 496 big block (8.1L) 550 hp, 640 lb ft - 12.2 @ 112 mph
      FS: RNS-510, back up camera, BT module
    11. Junior Member
      Nov 13th, 2012
      Orlando, FL
      2012 VW CC
      07-04-2015 12:13 AM #11
      Quote Originally Posted by echristie View Post
      same thing, you go 09-central electronics->long code helper
    12. n00b
      Jul 2nd, 2015
      07-04-2015 05:10 PM #12
      Ok I will try that hopefully my local guy with vagcom will be able to figure it out.. What section is license plate cold diagnostics in?
    13. Member
      Jul 29th, 2012
      Jetta MK6 1.4TSI 122HP
      07-04-2015 06:17 PM #13
      Quote Originally Posted by Sungrown1982 View Post
      This.
