    Results 1 to 9 of 9
    Thread: MK4 12v big turbo Firewall & Rain tray clearance
    1. Member DMehalko(DM)'s Avatar
      Nov 1st, 2004
      Colorado
      All sorts of VW's
      07-31-2015 10:37 AM #1
      Hello guys, looking to re-live my VR6 turbo glory days from about 10 years ago, just snagged a 2001 12v with 79k miles on it for a dedicated turbo project. I am in parts gathering mode and am leaning towards the ATP manifold, I have my mind set on a T4 6262 and am worried about rain tray clearance.
      Any mk4 guys top mounting turbos with the atp mani? seems the mk3's have better clearance, or should i grab a kinetic manifold.
      Engine bay on my old gti mk4 ~2008 ish time frame, little t3/t4 on a kinetic mani
      2014 Jetta SE 1.8TSI Daily, Platinum Grey
      2001 Silver Arrow Jetta VR6 Turbo Project car
    2. Member V-dubbulyuh's Avatar
      Nov 13th, 2005
      Mk3 VRT, Mk4 VRT, Mk4 VRT, A3 VR, B5 1.8BT
      08-03-2015 09:53 AM #2
      The ATP manifold & 6262 even with S-cover will clear the rain tray.
      "OP sounds like a MKIV guy"
      Feb 18th, 2014
      Michigan
      2003 Passat Gls 1.8t, 2000 VW GTI 12v VRT
      08-03-2015 02:35 PM #3
      ATP manifold and 6266 and didn't fit on my mk4 VRT, but it came pretty close so I don't see why the 6262 wouldn't fit.
    4. Member DMehalko(DM)'s Avatar
      Nov 1st, 2004
      Colorado
      All sorts of VW's
      08-03-2015 02:59 PM #4
      Quote Originally Posted by Dhandley01 View Post
      What compressor housing did you have? I am looking at the SP cover, and where you top mounted with the compressor on the pax side?
    5. Member R32Smoker's Avatar
      Oct 21st, 2010
      Dahlonega, Ga
      01 Jetta VRT
      08-04-2015 01:45 AM #5
      I'm running a 6265 t3 .81 with an atp manifold on my mk4 and it fits fine. You should be good.
    6. Member DMehalko(DM)'s Avatar
      Nov 1st, 2004
      Colorado
      All sorts of VW's
      08-04-2015 12:30 PM #6
      Thanks guys!
    7. Member V-dubbulyuh's Avatar
      Nov 13th, 2005
      08-05-2015 07:46 AM #7
      My clearance has been fine, compressor mounted driver's side.
    8. Member tmoura's Avatar
      Jun 26th, 2006
      Ashburn, VA
      BMP R
      08-19-2015 11:07 PM #8
      You start running into clearance issues when it looks like this. The cold side compressor has about a mm of clearance from the top left of the rain tray. I'm just going to cut it out so that it can have some room if it moves a little.
      With the SRI painted up.
      Project: Nemesis 700+ HP Turbo build | Built not Bought
      Feb 18th, 2014
      Michigan
      08-25-2015 03:14 PM #9
      Quote Originally Posted by DMehalko(DM) View Post
      meant s366 lol and comp housing on drivers side
