    Results 1 to 8 of 8
    Thread: Starts then dies
    1. Junior Member
      Sep 24th, 2012
      Denver
      08-03-2015 06:31 PM #1
      I have a mk3 2.0 ABA that I just swapped the engine and tranny from another vehicle.
      On start I get crank and start, but it quickly dies. Seems it's unable to idle.
      Timing was good when the engine was removed, i didn't touch the belt so it should be fine. firing order is correct. plugs, wires, rotator, cap, coil are all fairly new.
      I've read a bad immobilizer cam cause this. How do I ensure it's the immobilizer?
      As usual, when plugging in the battery negative after the positive is already set, the alarm goes off. I can turn the alarm of from the doors but not from the ignition, when i crank the key in the ignition nothing happens. Is this indicative of a bad immobilizer?
      How do I bypass the immobilizer?
      https://drive.google.com/file/d/0B6J...ew?usp=sharing
      If you think it's caused by something else please chim in!
      Thanks!
    2. Junior Member
      Sep 24th, 2012
      Denver
      08-03-2015 07:13 PM #2
      Damnit, the timing didnt' stick as I assumed it would
      *EDIT* timing did stick... anyways..
      Oh yeah, I found a way to bypass the immobilizer
      Jumped T6/5 to T10/6 on other terminal. This allows me to disconnect/connect the battery terminals without the car alarm ever sounding.
    3. Junior Member
      Sep 24th, 2012
      Denver
      08-03-2015 09:03 PM #3
      timed it, still dies with same results
      rotator is on, the notch is shadowed
      video of start, same results as previous video
      http://vid1174.photobucket.com/album...psftdjd8pj.mp4
      outside the cabin
      http://vid1174.photobucket.com/album...psviaq8zjm.mp4
      i'm stumped... suggestions?
    4. Member
      Mar 23rd, 2008
      N/A
      N/A
      08-03-2015 10:34 PM #4
      What makes you think that the timing was off?
      With the pulley pointed at TDC, and the distributor rotor pointing 180 degrees opposite the timing mark, the could have been at TDC after completing the exhaust stroke.
    5. Junior Member
      Sep 24th, 2012
      Denver
      08-03-2015 11:10 PM #5
      you're totally right
      oh well, i got a new tensioner on there when i set it
      any suggestions as to what's keeping the engine back?
    6. Junior Member
      Sep 24th, 2012
      Denver
      08-04-2015 09:13 AM #6
      To disable the immobilizer I've also tried placing jumpers at T6/5 and T6/6, as described on Dan's Alarm page.
      http://faculty.ccp.edu/faculty/dreed...alarmhelp2.htm
      Dan says to leave the alarm module disconnected?
      Q - Do I leave the alarm box unhooked?
      A - YES - Do not plug it back in!
      Starts, cranks, runs, then dies
    7. Junior Member
      Sep 24th, 2012
      Denver
      08-04-2015 10:28 AM #7
      On a whim I tried unplugged the MAF, it actually ran for a bit
      I swapped the MAF from the junker that the engine was pulled from(which ran before the engine was pulled)
      Starts and runs, but is very rough and eventually dies, but it's an improvement.
      I've also tried swapping the throttle body from the junker. Tried the "chicken dance TBA" - disconnect battery, release charge, hook battery, put key in ignition till engine light illuminates, chicken dance while TB hums.
      -no luck
      Hopefully a Vortexer who haves a VAGCOM will visit me to pull the codes and run a TBA... if you're in my area, you have a HEX+CAN vagcom, and you're willing to stop by my place(denver/lakewood) to pull the codes please message me!
      Also, any other ideas? Thanks!
    8. Junior Member
      Sep 24th, 2012
      Denver
      08-04-2015 12:34 PM #8
      Figured it out!
      Got virtual XP running from Win10 and I was able to get the codes and run TBA with my ebay cable.
      Cleared the codes after running TBA, starts and runs, no codes. Time to drive!
