    Results 1 to 2 of 2
    Thread: Need help
    1. 08-19-2015 06:29 PM #1
      I have a mk2gtivr6 Question to change my bolt pattern from 5x100 to 4x100 how would i do that just get a different hub?
    2. Member Eric D's Avatar
      Feb 16th, 1999
      Tragic Kingdom, CA
      1943 Flugkreisel, 1945 VRIL-7
      08-19-2015 09:01 PM #2
      Rear just requires disc swap.
      The front you have to identify how the swap was done.
      Did they take a short cut and swap the hubs (Eurospec kit or drilled them, or hub adapters), or did they swap in the Plus Suspension from the donor car?
      Plus suspension includes the following parts.
      Control arms, ball joints, steering rack, axles, steering knuckles with brake calipers, brake hoses, rotors, VR6 strut mounts, sway bar.
      On the VR6 steering rack, the u-joint at the steering column was also swapped.
      Why do you want to go back to 4x100?
      Looks like you'll be buying a lot of parts.
      The original Dub and Dubber.
      Manche VWs sind einfach schneller als andere.
