VWVortex.com - Passat B6 VR6 4motion Wagon Hitch or Tow Mount
    Results 1 to 23 of 23
    Thread: Passat B6 VR6 4motion Wagon Hitch or Tow Mount
    1. Junior Member
      Aug 13th, 2011
      Arizona
      2008 Passat VR6 4mo Wagon White/Nav
      10-21-2015 12:14 PM #1
      I have seen this question — and asked it myself several years ago — so just in case the answer has changed:
      Has anyone ever found a hitch mount that works on the '07-'08 Passat Wagons with the VR6 engines (and in this case, 4motion)? I recall it had something to do with the dual exhaust or ...
      I think I found one made in Amsterdam that cost a small fortune, but I can't even find record of that now.
    2. Member jddaigle's Avatar
      May 30th, 2003
      Denver, CO
      2008 Passat Wagon VR6 4motion, 2013 FIAT 500 Sport
      10-21-2015 10:17 PM #2
      - Jeff
      B6 Passat 3.6 & 4motion Resource Thread
      Now: 2008 VW Passat 3.6 4motion Wagon, 2013 Fiat 500 Sport
      Then: 1987 Volvo 745GLE, 1989 Volvo 740GL, 1994 Volvo 940T, 1995 Infiniti G20, 2000 VW Passat 1.8T, 2001 VW Jetta Wolfsburg Ed (x2), 2004 VW Golf TDI, 2006 Jetta TDI
    3. Member bonestockgtx's Avatar
      Apr 20th, 2000
      Vancouver, BC
      2008 Passat Wagon, 3.6 4mo
      10-23-2015 02:09 AM #3
      I have the factory Euro VW hitch. Unfortunately I cannot remember if it's made by Bosal, Westfalia or another brand, but it looks very similar to the one from jddaigle's link. I have also retrofit all the factory Euro wiring and it works awesome. It told me I had a bulb out on my trailer, turns off the motors for the powered hatch, turns off the PDC and puts the rear view camera into "trailer mode" so you can back the car up and line the ball up with the trailer "tongue". I made an adapter wiring harness that converts the Euro 13 pin electrical to 7 pin north american spade-plug. This summer I borrowed a utility trailer to remove a bunch of bricks from my yard. I didn't realize how heavy they were but when I got to the dump they were over 1500 kg (3300 pounds)!!! The manual that comes with the towbar said 2200kg, so I was under the limit, but I really wouldn't tow that much that often, and I really wouldn't want to go over 1500kg. Towing 1500-2000 pound loads it is fantastic though.
      Any way, very long winded way to say if you can, get the Westfalia one, just be aware it's only a ball, not a normal 1 1/4" or 2" hitch that you can install a normal bike rack on. Of course there are euro options for the bike rack too (they are so much cooler than what you can get in north america):
    4. Junior Member
      Aug 13th, 2011
      Arizona
      10-31-2015 03:42 PM #4
      Wow! That is an impressive rig! I only want it for carrying a bike. I have a Dutch bike that is nearly 50lbs and I am thinking about adding a motor, so it is only going to get heavier. Thule has added a hitch mount bike rack for heavy bikes (like e-bikes), but it requires a hitch. Any European options you can share? I imported my bike from the Netherlands, why not bring over an uber-cool rack?
      Quote Originally Posted by bonestockgtx View Post
    5. Junior Member
      Aug 13th, 2011
      Arizona
      10-31-2015 04:27 PM #5
      Thank you for saving my sanity and sharing this link.
    6. Member bonestockgtx's Avatar
      Apr 20th, 2000
      Vancouver, BC
      10-31-2015 10:57 PM #6
      Hey SUVAGEN, have a look on eBay.co.uk for Thule "towbar bike racks" like this one:
      http://www.ebay.co.uk/itm/Thule-916-...AAAOSwZkJURjYS
      If you go to Thule's website for the UK you can see all of their offerings:
      http://www.thule.com/en/gb/products/...-bike-carriers
      I would specifically look into the 916 as it has a 60kg total capacity:
      http://www.thule.com/en/gb/products/...r-916-_-916000
      That may be overkill if you are just carrying one bike (even if it's a heavy bike), so maybe have a look at their other racks too. The great thing about these racks is that they pivots down while the bikes are loaded so you can still get into the hatch!
      In terms of the actual towbar itself have a look here:
      http://www.ebay.co.uk/itm/Westfalia-...MAAOSwHjNV8VVf
      I hope that helps!! I absolutely love my set up.
    7. 04-03-2016 07:54 PM #7
      I have a 2007 Passat Wagon, 3.6, 4Motion, with parking sensors, rearview camera and RNS-510 navigation. I got a trailer hitch from SRG Attache Remorque in Canada and installed the Tow Ready 118530 harness. It's a simple plug and play harness that doesn't require programming on the car computer. I think it's all you need if you want to tow light trailers without brakes.
    8. Junior Member
      Aug 13th, 2011
      Arizona
      04-03-2016 08:26 PM #8
      Quote Originally Posted by carangeljr View Post
      I have a 2007 Passat Wagon, 3.6, 4Motion, with parking sensors, rearview camera and RNS-510 navigation. I got a trailer hitch from SRG in Canada and installed the Tow Ready 118530 harness. It's a simples plug and play harness that doesn't require programming on the car computer. I think it's all you need if you want to tow light trailers without brakes.
      What is SRG in Canada? I am in the U.S. and don't know what that stands for. I don't want to do any towing; I just want to use a hitch mount bike rack.
      Update: I found their website, but when I enter VW->Passat-> and either '4motion' or 'wagon', the years end with 2005. So, I don't find a tow bar for a 2007 or 2008 4motion wagon. What did you install?
    9. 04-03-2016 10:21 PM #9
      Here is the tow hitch model from SRG in Canada. Model 15048MT
      http://www.srgattacheremorque.com/?p...roduits&type=1
      Here is the wire harness from Tow Ready, part number 118530
      http://www.towready.com/products/ele...IqKI1N%7CGobE=
    10. Junior Member
      Aug 13th, 2011
      Arizona
      04-04-2016 08:53 AM #10
      http://www.srgattacheremorque.com/tr...-2010,177,2139
      Thank you! How did you figure out that a hitch labeled for the 2010 Passat would work on the 2007-8 V6 4motion wagon?
    11. 04-04-2016 09:16 AM #11
      2006 to 2010 are the same. They have the same part number. You can check on SRG website.
    12. Member Eric24v's Avatar
      Jun 20th, 2002
      Seattle, WA
      '08 Passat Wagon 4-mo VR6, '91 GTI 16v, and a whole lot of mtn bikes
      02-23-2017 04:59 PM #12
      Any pics of this installed?
    13. 03-29-2017 03:06 PM #13
      Just got an email from SRG - they will not ship to US. Any other suggestions?
    14. Member
      May 15th, 2012
      LA
      01 FrankenGTI, 12 Tiglean (wife) 08 r36'ish ;-)
      04-17-2017 03:00 PM #14
      I don't speak German but I "think" this is what I am looking for.
      Any comments on a yeah or neh?
      https://www.amazon.de/dp/B06XT6RTWG/...oding=UTF8&me=
    15. 04-20-2017 03:06 PM #15
      Nien, link does not vork.
      I'm interested as well. Keeping my eyes peeled.
      Sent from my SM-G935W8 using Tapatalk
    16. Member
      May 15th, 2012
      LA
      04-21-2017 01:27 PM #16
      Quote Originally Posted by Tomster View Post
      Yeah, looks like it timed out... For the price I think I am going to bite the bullet and get it.
      Shipping to the US was listed as 39 Euro... So very reasonable.
      I've owned this car a little over a year and have put 35K miles on it. And I love it more every day. I will post again here when I get the hitch and if it works.
    17. 04-21-2017 03:33 PM #17
      Is it the westfalia (sp?) unit? I'm very curious how it works out for you. I've just read on Passat world that the hitch mount size may be odd, and you may need a spacer. Did you read that as well?
    18. Member
      May 15th, 2012
      LA
      04-21-2017 03:55 PM #18
      The one in the link fit the r36 estate and saloon... It was not a Westfalia.
    19. 04-21-2017 04:05 PM #19
      I found it by typing in the product code. I see its one of those European style units that has a set ball size. I don't think a bike rack or crate carrier can be mounted on that. I'm following up with SRG as I'm in Canada (ON). Will post when I get their reply.
    20. Member
      May 15th, 2012
      LA
      04-21-2017 04:08 PM #20
      I hadn't decided whether I was going to leave that on for the true euro aspect or have it cut off and a square tube welded on for swapable items..
    21. Member
      May 15th, 2012
      LA
      05-05-2017 03:38 PM #21
      I tried to order the trailer hitch from Amazon.de (German amazon) but the seller wrote me and said he didn't ship to the USA.
      So I just ordered it and I am having it shipped to a friend in Germany who will forward it on to me.
      Fingers crossed!!!!
    22. 05-05-2017 04:47 PM #22
      Thats awsome. Glad you had that option. I'll be pursuing that Quebec company in the next month or so. Will post how I get on.
    23. Member
      May 15th, 2012
      LA
      05-10-2017 09:48 AM #23
      Hitch delivered in Germany and my friend shipped via USPS priority and insured for $300. The USPS shipping was $85... I gave him $150 so the difference will be good beer money...
