VWVortex.com - Replaced heater core, now fresh air blower not working.. I'm stumped
    Results 1 to 5 of 5
    Thread: Replaced heater core, now fresh air blower not working.. I'm stumped
    1. Member t_wrek's Avatar
      Apr 12th, 2012
      Seattle WA
      1994 Alpine White Golf
      01-19-2016 05:02 PM #1
      It seemed too easy..
      The fan is not working on any setting. Also the control knobs are not illuminatd.
      I am fairly confident that I connected everything properly. I never even disconnected the blower switch.
      I replaced fuse #6 just to be sure. Is there something I'm missing here? I really don't want to remove the dash again.
      Any help would be appreciated.
      Just here to share knowledge and be inspired.. and buy parts.
    2. Member RoseBud68's Avatar
      Dec 13th, 2012
      PSL,FL
      97 GLX, AAA
      01-19-2016 06:01 PM #2
      Sound like you will be going back in...
      Quote Originally Posted by oscar563 View Post
      VW's are like hot models...high maintenance but I just don't care
      Quote Originally Posted by jearp View Post
      zach is troll master
    3. Member taurus's Avatar
      Dec 13th, 2002
      Sacramento, ca
      '97 Golf VR6, '97 & '96 Jetta Treks
      01-19-2016 07:23 PM #3
      It shouldn't take you more than 5 minutes to remove the HVAC control panel and check connections and the bulb.
      '97 Golf VR6 · '97 Jetta Trek · '96 Jetta Trek
    4. Member t_wrek's Avatar
      Apr 12th, 2012
      Seattle WA
      01-19-2016 10:38 PM #4
      I before posting this I checked the back of HVAC controls, and the fan switch is plugged in (I never removed it is n the first place).
      There is one 6 or 7 pin connector behind the fan speed switch and a 2 pin connector behind the temperature knob which I assume controls the illumination. How can it be that this all worked last week and now it does not? Just trying to rule out some things to make absolutly sure it is necessary to remove the dash and look for stray wires.
    5. Member t_wrek's Avatar
      Apr 12th, 2012
      Seattle WA
      01-22-2016 12:49 AM #5
      [IMG][/IMG]
      I was missing this ground wire, thank you Bently! Anyone out there listening, it plugs into the back of the rebar on the passenger side, near Lower A pillar. It is invisible once the rebar is installed so it's a bit tricky.
