VWVortex.com - B6 A4 1.8T has me stumped! DTC's galore
    Results 1 to 5 of 5
    Thread: B6 A4 1.8T has me stumped! DTC's galore
    1. Member 01wolfsburgj's Avatar
      May 3rd, 2011
      Honeoye Falls, NY
      2004 DBP .:R32
      01-21-2016 03:58 PM #1
      Alright, so this is my brothers car. 2002 B6 A4 1.8t Quattro Avant 5spd. its a non sunroof model, originally a Canadian car, imported to the US in 2003. it has 110k on it. all big maintenance bits are done and up to date.
      SOOOOOOOOOO
      Earlier this week he was out sliding around in parking lots in Upstate NY due to all of the lake effect snow we get. Spun out and the car began to idle erratically. turned it off, turned it back on and it had a real rough idle.
      brought it home, scanned the car and 7 DTC's showed up:
      P0245
      P0106
      P0445
      P0237
      P0343
      P0102
      P2127
      with these codes came the EPC light too.
      Boost leak test checked out, swapped mafs still running rough, refuses to start with the maf plugged in. runs perfectly normal when driving until around 3k rpm it starts to throttle cut and back fire. I currently live in Akron Ohio so i dont have the car in front of me to tinker with AND i brought VAGCOM to school with me but im kind of running out of ideas for him.
      Any idea helps, i need a fresh ides/view on this
      Thanks,
      -Connor
      -Connor
      DBP .:R32
      I SURVIVED THE GREAT HALDEX DEBATE OF 2014
    2. Banned robin_bga's Avatar
      Jun 22nd, 2011
      Uganda, Kampala
      Audi A3, 8L AUQ, 1.8T, 2001, Manual Shift.
      01-21-2016 04:02 PM #2
      Hello Connor, I request that you go for a fuel pump pressure test then we can continue from that....
      Cheers
      Sent from my SM-G800H using Tapatalk
    3. Member 01wolfsburgj's Avatar
      May 3rd, 2011
      Honeoye Falls, NY
      2004 DBP .:R32
      01-21-2016 06:06 PM #3
      Quote Originally Posted by robin_bga View Post
      Cheers
      definitely a location in which i havent checked yet, will update if it does or doesnt check out.
      -Connor
      DBP .:R32
    4. 01-21-2016 11:11 PM #4
      Canadian Immo 2 and 3 defeat service, PM for more information.
      Vag-Com Scanning available in London area, Hex+Can.
    5. Member 01wolfsburgj's Avatar
      May 3rd, 2011
      Honeoye Falls, NY
      2004 DBP .:R32
      03-15-2016 11:36 AM #5
      Im going to update this incase anyone else has a similar problem.
      the part of the harness that runs to SAI, EVAP, N75, Maf, ect. got melted by a clogged cat. cut and resoldered, shes running like a top now.
      -Connor
      DBP .:R32
