VWVortex.com - What is HP of 1600 1641 1776 etc...engines..
    Page 2 of 2 FirstFirst 12
    Results 26 to 29 of 29
    Thread: What is HP of 1600 1641 1776 etc...engines..
    1. Member Darren_1303's Avatar
      Jul 10th, 2002
      Lake Oswego, Oregon
      2005 VW Jetta GLI
      04-07-2003 11:27 AM #26
      I had some time before class.
      AK - 48 @ 4000 (DIN) or 46 @ 4000 (SAE net) and 72 TQ @ 2000.
      That seems a little low on the hp side, I can get the car up to 90... THe only way to really know, I guess, is to have it dynoed.
      hmm..
      Thanks! Great thread.
      I have a website | http://darren1303.com
    2. 01-03-2017 04:00 AM #27
      years ago when i used to play around with fuel and air mixtures on stock 1600DP or 1500SP i use to change the main jet and air correction jets and buy a 009 dizzy set it at 10 degrees btc and would get alot more performance out of stock motors i could actually get the wheels spinning
    3. Junior Member
      Mar 16th, 2015
      Nor-Cal
      01-07-2017 03:32 PM #28
      Its hard to get actual numbers without knowing every single detail of an engine. You can have two engines with the exact same parts, but two different hp ratings. It all comes down to how it was built, compression ratio, quality of parts used, proper break-in procedure, and if it's tuned properly. For example, everyone seems to gravitate to a 009 distributor, but if you do a little research, you'll find that it's the worst distributor you could possibly use. The timing isn't consistent, it causes overheating, and it can cause serious detonation issues, there's a reason it's cheap. Your best bet distributor wise is a cast iron Bosch distributor like an 010 or 019. There's a lot to consider even when building a stock engine.
    4. Member Jade Wombat's Avatar
      Oct 20th, 2004
      Houston, TX
      '66 Bus, '12 Colorado 3.7
      01-19-2017 08:42 PM #29
      And to think there's another world of tuneability out there if you switch to aftermarket fuel injection and crank-trigger spark.
