VWVortex.com - HELP! Almost gave up, Electrical problems
    Results 1 to 4 of 4
    Thread: HELP! Almost gave up, Electrical problems
    1. n00b
      Aug 12th, 2015
      Some place on Earth
      2007 VW Mk5 R32
      03-29-2016 08:48 AM #1
      Hello everybody. So i'm having this problem with my car. After reassembling the engine bay (engine and gear box were taken off) i started encountering lot's of fault codes, mostly MAF and TB (Throttle valve control). I was suggested to get a new MAF and a new TB, but it was better to check it out first, so i took them from an other R32 that was getting a "paint job", so the guy didn't really need them much. But, nothing changed, i was still getting those faults and now i don't really know what to do. Maybe smbd bumped into this problem before. My thoughts are that its neither some mistakes in the assemble (connection problems) nor i got moist (water) in my ECM. Anyway this is a list of what i got last week, they appear randomly and all go with the "01314 – Engine Control Module 013 – Check DTC Memory" fault:
      000545- Angle Sensor 2 for Throttle (G188)
      P0221 – 008 Implausible Signal;
      P0221 – 008 Implausible Signal – Intermittent;
      000289 – Throttle Position Sensor (G69)
      P0121 – 008 Implausible Signal;
      000406 – Engine Oil Temp. Sensor (G8)
      P0196 – 004 – Implausible Signal;
      P0196 – 004 – Implausible Signal – Intermittent;
      000258 – Mass Air Flow Sensor (G70)
      P0102 – 002 Signal too Low – Intermittent;
      P0102 – 002 Signal too Low;
      001287 – Idle Control System RPM
      P0507 – 001 – Higher than Expected;
      005445 – Throttle Valve Controller
      P1545 – 001 – Malfunction – Intermittent;
      P1545 – 002 – Malfunction – Intermittent;
      P1545 – 008 – Malfunction;
      P1545 – 008 – Malfunction – Intermittent;
      004416 – Oxygen (Lambda) Sensor: B2 S2
      P1140 – 008 – Internal Resistance too High — Intermittent;
      000064 – Oxygen (Lambda) Sensor Signals Swapped
      P0040 – 008 – B1-S1 / B2-S1 – MIL ON;
      000768 – Random/Multiple Cylinder Misfire Detected
      P0300 – 001 — — Intermittent;
      000779 – Cylinder 5
      P0305 – 001 – Misfire Detected — Intermittent;
      008583 – Bank 1; System too Lean at Idle
      P2187 – 001 –;
      008585 – Bank 2; System too Lean at Idle
      P2189 – 001 –;
      Would be greatfull for any clues.
    2. n00b
      Aug 12th, 2015
      Some place on Earth
      2007 VW Mk5 R32
      03-30-2016 05:52 AM #2
      Well i quess i've found the problem of the 5th cylinder misfire, not quite sure, but i believe the reason is the broken lock on the connector of the spark plug wire . Got it ordered. Will receive on Friday.
      Apr 30th, 2007
      Quebec, Canada
      Jetta TDI 03, Corrado 24v 90.
      03-31-2016 08:08 PM #3
      Are you sure all grounds and hooked up clean and solid. I would check for loose ground first. Also check that you have no loose power cables.
      1990 Corrado 3.2L VR6 24v, O2m w/ wavetrac diff. DSS 2.9 Axles, TT downpipes, 42 DD cat, Koni Coilovers.
    4. n00b
      Aug 12th, 2015
      Some place on Earth
      2007 VW Mk5 R32
      04-07-2016 10:24 AM #4
      This is the first thing i am planning to do, thanks! Hopefully will have time tomorrow, so i'll tell what happened with my car on the weekend
