Results 36 to 70 of 101
Thread: Aluminum Radiator Elbow................I know, I know, I hate polls too....BACK FROM THE DEAD!
  1. 04-11-2003 12:43 AM #36
  2. Moderator SLC4EVER's Avatar
    Oct 7th, 1999
    San Diego
    '93SLC '94SLC
    04-12-2003 06:20 PM #37
    Dak
    I drive waaay too fast to worry about my cholesterol.
  3. Banned
    Oct 15th, 2001
    04-12-2003 07:20 PM #38
    quote:
    i would hope that this custom feature you're talking about has something to do with the drain plug *snip* in order to make way for an easier/cleaner way of draining the coolant system via the crack pipe
    You hit the nail square on the head. We all know what a freakin' mess it is changing the coolant.
    Seriously! That stupid plastic drain plug got stripped the second I tried to unscrew it. What EXACTLY is the special feature?...if you can disclose that.
    [Modified by VeeDubBBoy, 12:20 AM 4-13-2003]
  4. Moderator SLC4EVER's Avatar
    Oct 7th, 1999
    San Diego
    '93SLC '94SLC
    04-12-2003 08:26 PM #39
    It will completely eliminate the mess associated with the drain plug, while still utilizing it.
    Dak
  5. Moderator SLC4EVER's Avatar
    Oct 7th, 1999
    San Diego
    '93SLC '94SLC
    04-16-2003 11:50 AM #40
    Three more to make it a good even 50...good quoting numbers.
    Dak
  6. 04-16-2003 11:57 AM #41
    Depending on the cost, I would seriously consider ordering 2. I know aluminum should be a lifetime part, but you never know, and I'd rather have a backup since I plan on keeping the C for life.
  7. 04-16-2003 12:13 PM #42
    Would probably be in if it was for a G60
  8. Moderator SLC4EVER's Avatar
    Oct 7th, 1999
    San Diego
    '93SLC '94SLC
    04-16-2003 12:29 PM #43
    Select "No..." I will consider doing a G60 elbow if there is enough interest.
    Dak
  9. Member cdncrdoguy's Avatar
    Jul 22nd, 2002
    Toronto
    90 Diamond Silver Corrado/99 Subaru 2.5RS
    04-16-2003 01:47 PM #44
    I just had mine break on my first run out after winter storage. What a PITA I stripped the bolt that goes into the radiator housing and then I broke the housing while trying to get the stripped bolt out.
    If you make these for the G60, i will definitely be in.
  10. Moderator SLC4EVER's Avatar
    Oct 7th, 1999
    San Diego
    '93SLC '94SLC
    04-16-2003 02:30 PM #45
    Check "No.." in the poll...thanks!
    Dak
  11. Moderator yellowslc's Avatar
    Aug 29th, 2000
    Houston
    04-18-2003 02:53 PM #46
    Dak.. you know the boosteddubs guys are down for a box of em.. let's get rolling on this..
    R
  12. Moderator SLC4EVER's Avatar
    Oct 7th, 1999
    San Diego
    '93SLC '94SLC
    04-18-2003 03:52 PM #47
    Dak
  13. 04-19-2003 01:19 PM #48
    "I just had mine break on my first run out after winter storage. What a PITA I stripped the bolt that goes into the radiator housing and then I broke the housing while trying to get the stripped bolt out.
    If you make these for the G60, i will definitely be in."
    Yeah, I know exactly what you are talking about. This happened on my VR6 rado too when I was trying to replace the cracked elbow. Ended having to get a new rad (which wasn't a bad thing becasue I'm running much cooler now) Replaced everything else plastic at the time. The plastic really sucks. Also on another note how dissapointing that the PWR radiator just doesn't have the elbow cast into their rad or something. I'd be pissed if I had to put that plastic piece of ____ on top of that expensive rad. That bites.
  14. Member kevwithoutacorrado's Avatar
    Jun 9th, 2000
    OREGON
    93 SLC, 07 Legacy GT, 93 YJ
    04-19-2003 10:31 PM #49
  15. 04-29-2003 09:59 AM #50
    definitely want. that is all.
  16. Senior Member 6cylVWguy's Avatar
    Jun 14th, 2000
    PA
    Blog Entries
    4
    '12 GT; '94 SLC
    04-29-2003 01:25 PM #51
    Depending on the price, count me in as well.
    Just an idea, if you really want to boost the numbers post some info in the MKIII and VR6 forums. There are bound to be some other people who would like this as well.
  17. Member
    Apr 29th, 2003
    Bainbridge Island, WA
    2000 VW Golf 1.8T 5-speed, 1997 Lotus Elise, 2008 smart fortwo
    04-29-2003 01:47 PM #52
    Count me in as well.
    alan
  18. Moderator SLC4EVER's Avatar
    Oct 7th, 1999
    San Diego
    '93SLC '94SLC
    08-15-2005 11:37 PM #53
    Check it.
    (See first post)
    Dak
  19. Moderator Krazee's Avatar
    Jan 25th, 2003
    En Why Sea
    Blog Entries
    9
    Corrado
    08-16-2005 12:38 AM #54
    I have dinero waiting.
    Project Corrado RS: Keep Up
    MSD 12v VR6 coilpack setup/components For Sale: Here
    Other items for sale: Sparco, VR6 HVAC box, VR6 radiators, Mocal Oil Cooler: Here
  20. Member vdubfrk's Avatar
    Sep 5th, 2004
    atlanta
    1992 corrado SLC,1990 corrado G60
    08-17-2005 01:15 AM #55
    COUNT ME IN!
  21. Member HisMajesty's Avatar
    Sep 4th, 2000
    Reno, NV
    '93 Corrado SLC / '03 Toyota Tacoma / '07 GSXR 600
    08-17-2005 05:34 AM #56
    That looks good! Can't wait...
  22. Member pdcm's Avatar
    Mar 29th, 2000
    DC Area
    81 Pickup, 93 Corrado, 05 Golf
    08-17-2005 06:51 AM #57
    Wow, 4.28.2003 to 5.18.2005... either way, count me in with cash in hand!
  23. Member Wayne92SLC's Avatar
    Mar 1st, 2001
    Minneapolis, MN
    1992 Corrado SLC; 2001 Audi S4 Avant
    08-17-2005 08:29 AM #58
    Hey Dak! I'm in if you make this thing a reality.
    Also, what kind of mods did you have to do to the PWR radiator to get everything to fit? Is it just trimming the fan shroud for fan swtich clearance or was there more to it? I've been considering upgrading since I have a 3.0L long block from Schimmel on the way. I'm sure I'll be making even more heat now...
    -Wayne
  24. Member sdezego's Avatar
    Apr 23rd, 2004
    Hurricane Central FL
    '90 Corrado | '62 Harley Panhead
    08-17-2005 10:11 AM #59
    Quote, originally posted by SLC4EVER »
    ~edit: BTW, if the G60 guys are really that interested as well, I would consider helping you guys out as well. But currently at 4 total "No...", it would be quite expensive.
    I don't really understand what you are saying here. Is the G60 different from the SLC (Looks the same from the pic)? You have 4 total interested or only 4 G60 owners interested?
    I have a G60 and would be interested.
    Shawn
    Build: Project sc2020
    My G60 now on MS3 | 4Cyl Torque Plate Rental | 02M Mounts
  25. Moderator Krazee's Avatar
    Jan 25th, 2003
    En Why Sea
    Blog Entries
    9
    Corrado
    08-17-2005 10:59 AM #60
    Quote, originally posted by Wayne92SLC »
    -Wayne
    IIRC, from when I friend installed one....inaddition to the shroud trimming, you also need to shorten the 2 L brackets that keep the rad inline...the brackets that bolt at the top of the rad-support.
  26. Member pdcm's Avatar
    Mar 29th, 2000
    DC Area
    09-11-2005 06:55 PM #61
    bump
  27. 10-04-2005 07:27 AM #62
    Mine just cracked and blew coolant all over my engine bay bump......
    we need this!
  28. 10-04-2005 08:23 AM #63
    yup inerested
  29. 10-04-2005 10:21 AM #64
    interested as well
  30. Member a_grl_n_her_rado's Avatar
    Aug 2nd, 2003
    Baltimore, MD
    2008 Audi A3
    10-04-2005 10:35 AM #65
  31. 10-04-2005 11:31 AM #66
    seems like we will have a water powered corrado before this gets off the ground...
  32. Member
    Nov 19th, 2001
    Calgary, Alberta, Canada
    90 Corrado VR6 (build in progress), 2008 E90 M3, 2009 E88 135i
    10-04-2005 11:41 AM #67
    just bought a new rad from the dealership and it has the plastic elbow already attached. would diffenatley like to replace that with a aluminum one. also interested in the t-stat housing and crack pipe.
    just for information the stock vr6 rads just went up in price. i ordered mine last week and paid around 120cnd. now they are 220.
  33. 10-04-2005 11:45 AM #68
    2 year bump
  34. Member limeyscot's Avatar
    Oct 26th, 2002
    Central Pa.
    10-04-2005 12:08 PM #69
    I'm game if you can ever get the patents from those Leprechans and Jackalopes!
  35. 10-04-2005 02:08 PM #70
