VWVortex.com - Short Ram / Cold Air Intake
    Page 3 of 3 FirstFirst 123
    Results 51 to 71 of 71
    Thread: Short Ram / Cold Air Intake
    1. Member Cherb32's Avatar
      Jun 17th, 2006
      San Jose, CA
      16 Jetta S, 08 Rabbit, 06 Touareg
      04-18-2017 11:13 PM #51
      Quote Originally Posted by Zombified 5000 View Post
      soooooo just ordered filters, 45 degree coupler and 90 degree coupler and im gonna attempt to fill in the rest with pvc. keep it on the cheap side with some paint or hopefully get some black pvc 3" its cheap at lowes for like 6 bucks for 10 ft. i paid 37 bucks for both couplers (2.5" to 3" 45 degree and a 3" 90 degree) as well as the 3" inlet air filter and a little breather filter. ill keep you guys updated with some pics when they arrive and how i route and mount everything. hoping to build an air box as well we will see what wonders i can find at lowes or home depot on the cheap
      Sounds like a plan. Keep us posted. I still havnt made a shield yet....Im being lazy about it..smh
      Sent from my VS990 using Tapatalk
      Quote Originally Posted by bryangb View Post
      I'm usually too busy reaching for another beer to pay attention to other cars on the road
    2. Member Cherb32's Avatar
      Jun 17th, 2006
      San Jose, CA
      05-06-2017 09:07 PM #52
      Bump for update
    3. Member Cherb32's Avatar
      Jun 17th, 2006
      San Jose, CA
      05-07-2017 04:00 PM #53
      Finally made a shield out of plexiglass. Not done yet though..
    4. 05-10-2017 10:11 PM #54
      ok so i ordered the pieces i needed and the 45 degree off the inlet seemed to be better accompanied by a 90 degree fitting. no problem i made it work since shipping took way too long. got the air filter and breather filter and everything on the cheap. so WIN ... so i thought.. went to puty everything together and realized tubing i had was 3" ID instead of OD which didnt work out so long story short i used the 45 degree 2.5 inch to 3" and went to autozone and got that black retractable hose stuff and used that for my piping and just used that all to the air filter lol. i waited weeks to just get let down but oh well. it works with no problems and i dreadfully have just ziptied the filter to the air inlet on the backside of the grille. like i said ill update with pics tomorrow. definitely more sound from the engine and obvious recalculation/blow off noise. and to be honest with all the plastic stuff on these engines the tubing i used doesn't look all that terrible for what it is.
    5. 05-12-2017 10:52 AM #55
      Finally got around to getting all the parts ordered to make one. I think i may do mine differently though. Also ordered some black heat wrap cause i like the way yours looks. Cost of parts was $70.
      Sent from my SM-G935V using Tapatalk
    6. Member Cherb32's Avatar
      Jun 17th, 2006
      San Jose, CA
      05-12-2017 11:02 AM #56
      Sounds good..post some pics when you're finished!
    7. Member Cherb32's Avatar
      Jun 17th, 2006
      San Jose, CA
      05-12-2017 09:17 PM #57
      So i just checked the space in between the body and the headlight and a 3" pipe can fit. Based on my measurements, I need a 16" strsight and a 45 degree bend and I should be good. I thing the body and heatlight should be good enough to hold it (so I dont have to worry about mounting). Last step would be where to draw the cold air from. I was thinking of installing a low-profile scoop under the car to direct flow. Gotta do some more brainstorming.
    8. 05-15-2017 09:51 AM #58
      All my parts come im today... except the filter 😑
    9. Member Cherb32's Avatar
      Jun 17th, 2006
      San Jose, CA
      05-15-2017 10:29 AM #59
      Quote Originally Posted by LickThePenny View Post
      Lol it happens. Can always run to the local auto parts store and grab one 👍
    10. 05-19-2017 07:56 PM #60
      Its no beauty but it works fine
    11. Member Cherb32's Avatar
      Jun 17th, 2006
      San Jose, CA
      05-19-2017 08:22 PM #61
      Quote Originally Posted by zombified6000 View Post
      Meh..function over form man. Thats all that matters....it works.
    12. 05-20-2017 01:18 PM #62
      Sounds good. Need to change the reducing coupling to a reducing 45° so i can get it to sit a little lower.i wanted to turn it to the left where the factory box mounts but i didnt want to do that much work.
    13. 06-01-2017 10:41 AM #63
      Has anyone had a cel afterinstalling an intake? I got a code p3030 or missfire cylinder 3..
    14. 06-09-2017 12:35 PM #64
      Anyone?? But heres another pic
    15. Member Cherb32's Avatar
      Jun 17th, 2006
      San Jose, CA
      06-09-2017 01:03 PM #65
      Nope. Had mine for about 10k miles ..so far no issues.
    16. 06-10-2017 09:25 AM #66
      I bet its thst cheap ass filter I ordered off ebay.. might have been oiled.
    17. Member Cherb32's Avatar
      Jun 17th, 2006
      San Jose, CA
      06-10-2017 12:57 PM #67
      Possibly. I typically stick with dry high flow filters that can be washed. Maybe the oil on the filter is too thin to stay on the filter itself.
    18. Member Cherb32's Avatar
      Jun 17th, 2006
      San Jose, CA
      06-10-2017 01:05 PM #68
      Planning on extending my intake to make it a true CAI. Probably going to need a 3"x36" pipe and another 45 degree elbow. Trickiest part is where to channel the air flow. Was thinking of maybe a low profile scoop from the bottom of the bumper or something. Either way it will require some cutting.
    19. Member bigbumpmike's Avatar
      Aug 26th, 2003
      lemoore ca
      Mk6 golf tdi
      06-23-2017 12:49 AM #69
      I was looking at drilling the bumper black filler panel where the fog lights would go is the base model had them. Kind of like my mk5 gti had for the dsg oil cooler
      Miss my mk5 gti,e28 535is, mk3 jetta, mk2 jetta coupe, mk1 rabbit gti:, 67 type one bug,will always be on the look out for another e28 or fb or fc rx7.
      xboxlive: rattymk5mike
    20. Member Cherb32's Avatar
      Jun 17th, 2006
      San Jose, CA
      06-23-2017 01:11 AM #70
      Quote Originally Posted by bigbumpmike View Post
      Yeah I was thinking the same thing as an option as well. I just may buy a spare and drill out the honeycomb...maybe add some black mesh behind it.
    21. Member Cherb32's Avatar
      Jun 17th, 2006
      San Jose, CA
      06-23-2017 12:26 PM #71
      Post some pics once you get yours going!
