VWVortex.com - how to make dash lights brighter?
    Page 1 of 2 12 LastLast
    Results 1 to 25 of 28
    Thread: how to make dash lights brighter?
    1. 04-29-2003 08:41 PM #1
      I realized that in my gauge cluster... my lights are way too dim for my liking... so what can I do to make them brighter... or even change the color.... can I put in some LED's??
    2. 04-30-2003 12:25 PM #2
      go to pepboys lighting section. they sell European bulbs that fit in the stock sockets .
      thsoe are rated at higher wattage than the stock ones.
    3. Member 8716vrocco's Avatar
      Feb 12th, 2001
      Chicagoland
      Scirocco 16v, MKVI GTI, 99 4Runner, Honda VTX1800F
      04-30-2003 12:43 PM #3
      Do they really sell bulbs that fit into our gauge clusters?? When i changed my light filter i remember the bulbs being very strange looking.
      Project 16v Lysholm
      "I hope you go commando, otherwise your panties would always be in a bunch"
    4. 04-30-2003 12:55 PM #4
      this is a really dumb answer but if people didnt know, did you try turning that little dial above the headlight switch?
    5. 04-30-2003 02:52 PM #5
      Quote, originally posted by Shislerocco »
      You know even when it is at the highest, it is still not bright enough. When I bought my MKIV GTI after my first scirocco. I was like damn, the lights were so bright compared to the scirocco. even with my old MKI gti I had.
      I would love to get again the look and colors of the MKIV dashboard lights.
    6. 04-30-2003 04:27 PM #6
      Mine are plenty bright, maybe you should clean your connections. Or perhaps you're going blind
      -Rob
    7. 04-30-2003 05:08 PM #7
      dealer sells 4watt bulbs (instead of 2watt bulbs) that fit our dash.. like 2$/each
    8. 04-30-2003 05:09 PM #8
      I seen a tech tip somewhere where a guy added an extra light, and just got the power by splitting the wire going to the other light. I'll try and find out where this is, it looks pretty straight forward.
      rankin
    9. Member Rocco_crossing's Avatar
      Dec 18th, 2002
      somewhere in Iowa
      78 F150, 3-A1's, A2 Joupe
      04-30-2003 05:33 PM #9
      WHat about that indeglo sheet stuff? Maybe someone could make some gauge faces from that? I would think that would be a good idea, I would be willing to work on that project but being that I don't know where to get the stuff I can't.
      Quote Originally Posted by Ice Karl
      And let consequences fall where they may. Roll dice and accept
      outcome...
    10. 04-30-2003 06:11 PM #10
      I was wondering if I could place some LED's in where the lights are above the gauge cluster. Use the light wires to give power to the LED's... you guys think that would work?
    11. Member Rocco_crossing's Avatar
      Dec 18th, 2002
      somewhere in Iowa
      04-30-2003 07:39 PM #11
      LED's would work but you need to install a resistor to lower the voltage to the required Volts.
      outcome...
    12. 04-30-2003 08:28 PM #12
      howwww?
    13. Member PA 16v's Avatar
      Nov 5th, 2001
      Saint-Jean-sur-Richelieu
      1987 Scirocco (2.1l 16v on carbs)
      04-30-2003 11:01 PM #13
      This guy did it in his Corrado, he is on the Vortex under the handle Oichan
      His site:
      http://www.oichan.org
    14. 04-30-2003 11:04 PM #14
      What kind of keyboard is this? is this vietnamese? chinese? Thai?
    15. 04-30-2003 11:25 PM #15
      laf laf... ok if I only knew how to wire up led's hahaha
    16. Member 16V_Scirocco_GTX's Avatar
      Jul 18th, 2001
      In the 94086 California
      98 Passat V6, 90 Corrado TDI, 84 Scirocco GTI
      04-30-2003 11:52 PM #16
      Quote, originally posted by E-MALE »
      Japanese
      Tobias
      98 Passat V6, 90 Corrado TDI, 84 Scirocco GTi
    17. Member Rocco_crossing's Avatar
      Dec 18th, 2002
      somewhere in Iowa
      05-01-2003 02:20 AM #17
      LED's only hooked up one way. The resistor is usually wired into the circuit before the LED (disputable but make things uniform). I believe it was figured out you needed something like a ~470 ohms resistor.
      The guy that did his corrado lights know his ****!! It is very clean and makes me want to get my $hit together and get my dash lights working again!
      outcome...
    18. 05-01-2003 05:12 AM #18
      definately worth a look.. they've got some pretty krazy japanese vdubs over there.. [IMG]http://*****************.com/smile/emthup.gif[/IMG]
    19. Member RoccinStrybs84's Avatar
      Jan 2nd, 2002
      Chicago, IL
      05-01-2003 11:37 PM #19
      Quote, originally posted by DaiKa »
      I agree. This guy is like a Japanese ATS. Great tech note write ups. Makes me want to get a Corrado to try some of this stuff out
    20. 05-02-2003 02:07 PM #20
      If you like the stock green color keep the colored plastic on top of the cluster. take out the lights /sockets, replace the bulbs with a clear LED, solder the ground electrode to the ground socket connection and use a resistor in between the (+) LEd connector and the socket contact. you can calculate the resistance, if the LEd operates at 3.6V and you have 12V the difference is 8.4V. Divide the 8.4v by the LEds operating amp and get a resistor of that size.
    21. 05-02-2003 05:05 PM #21
      I changed my rocc over to superbright LEDs. I have these LED kits for ricers that have 4 leds with little resistor packs in line. They run on 12 Volts and can be dimmed with the factory dimmer. I hooked them up to the factory dashlight wiring. As it turns out, the factory setup was brighter. I think maybe I don't have the led's in the right spot. They are poking into the shroud just like the factory bulbs. Maybe they should be mounted right where the green strip is like that guy did in his corrado. And I only used one on each side, maybe that's not enough.
      Just for the record I did the heater control bulb too. The color is the big benefit. I used white bulbs and it gives that expensive-car look. It's just the brightness issue. I think maybe it's because it's going through the dimmer. I didn't have time to measure the voltage but I bet it's shwag.
      Vince
    22. 05-03-2003 09:43 AM #22
      here is how im making my cluster brighter these guys are great and prices are very good check out the site the even send you a cluster on loan while yours is getting done if you email these guys tell them andre told you about them you may save a few bucks
      http://www.duostyling.com
      Modified by wolf rocco at 2:47 PM 5-3-2003
    23. Senior Member VWVan's Avatar
      Feb 17th, 2000
      Langley, B.C.
      2004 Jeep V8 WJ
      11-26-2003 12:32 PM #23
      Quote, originally posted by ATS »
      You don't happen to have a part number do you?
    24. Member Kameirocco's Avatar
      Dec 19th, 2002
      McMinnville, Oregon
      2005 Dodge stratus SXT Coupe - 1980 Scirocco 2.0l
      11-26-2003 05:02 PM #24
      did LEDs in my dash, made a HUGE difference, and people were inpressed too i hooked the wires onto a switch and to the battery, but i now know that wasn't a good idea but i'm doing them prolly tomorrow again, except i'm goin to try somethin a lillll different, i'm going to see insted of putting the lights where the stock lights are to making something small to go around the speedo and tach and put LEDs in there, wish me luck!!
      BTW an easy way to find out which wires are the positive and negitive, get a 9v battery and put one wire on each one, but dont hold it there to long! but if i remember correctly, the long wire is the postive one
      Noah~(Kameirocco)
      1980 Scirocco
      ABA Swap - HKK intake - AEM filter - GIAC chip - MK4 Exhaust manifold - TT Race downpipe - 2.25" TT exhaust - Bilstein shocks - H&R sport springs
      Build Thread
    25. Member Beowulf-X's Avatar
      Jan 3rd, 2003
      Oregon
      MK7 Gti S
      11-26-2003 05:41 PM #25
      Yes the long "wire" is the postive. if you hook it upo to a 9v you might dramaticly decrease the life of the led, or burn it out. I personally used short cold cathodes for my guage cluster. nice and bright, and blue. and, they operate on 12v, so I dodn't have to do anything but wire them up. looks great. I shoulda used black lights tho. I think it would light up the guage face really nice.
