VWVortex.com - trunk not opening with new spoiler
    Results 1 to 23 of 23
    Thread: trunk not opening with new spoiler
      May 16th, 2013
      Los Angeles
      2016 Passat 1.8 SEL Premuim
      10-03-2016 04:51 PM #1
      The dealer installed a new OEM trunk lid spoiler and I'm finding the trunk will not open completely . It opens about 2 ins then need a slight push to swing fully open. I'm assuming the weight of the spoiler has upset the balance . Is there anyway to adjust the strut?
      Apr 12th, 2014
      Temescal Valley, CA
      2013 passat tdi sel; 2013 gli autobahn
      10-03-2016 05:18 PM #2
      There's 3 settings that the springs under the trunk liner can be adjusted to. Move hem to an open position further away to create more tension. This will pull the trunk up all the way with the new weight that was added.
      May 28th, 2009
      Ft. Worth, TX
      2009 JSW TDI; 2014 Passat TDI SEL;2014 Toyota Avalon Hybrid; 2013 Ford Cmax Hybrid; 2015 Nissan Leaf
      10-03-2016 05:42 PM #3
      I wonder if the additional spring tension could cause problems with the spot-welds of the mechanism? There have been more than a few reports of the welds breaking, for whatever reason.
      Might want to look closely at them, as well.
      2009 JSW TDI (returned 12/15/16)
      2014 Passat TDI-SEL (returned 12/14/16)
      2013 Ford Cmax Hybrid (replacing 2009 JSW)
      2014 Toyota Avalon Hybrid (replacing 2014 Passat)
      2015 Nissan Leaf (for in-town use)
    4. Member snobrdrdan's Avatar
      Sep 9th, 2008
      Southeast Michigan
      2017 VW
      10-04-2016 06:25 AM #4
      Quote Originally Posted by NAK's B7 View Post
      It weighs nothing
      My 3 B7 Passats have all had the spoiler from the factory and it's never been an issue
      2017 Passat VR6
      2017 Passat R-Line
      May 28th, 2009
      Ft. Worth, TX
      10-04-2016 08:45 AM #5
      Quote Originally Posted by snobrdrdan View Post
      It weighs nothing
      snobrdrdan: Where in the 3 notches is the spring-assist setting on your 3 NMS Passats?
      OP: Are you certain that your trunk opened fully, unassisted, prior to the install of the spoiler?
    6. 10-04-2016 12:28 PM #6
      OEM spoiler is so light, I saw no difference after I installed ours. Same with our 2014. May want to check your spring settings as others have noted.
      May 16th, 2013
      Los Angeles
      10-04-2016 11:40 PM #7
      Quote Originally Posted by tdiatlast View Post
      Trunk opened fully with zero issues before the spoiler install. Tech suggested some silicone spray to lube it. He also commented as others have that it's too light to affect the action. What is more frustrating is that it's intermittent and doesn't seem to make a difference which of the 4 options I use to open including the leg swipe.
      Apr 12th, 2014
      Temescal Valley, CA
      10-05-2016 12:22 AM #8
      I suggested adjusting the springs because I also own a GLI and the trunk opened just fine from day one of new ownership.
      Then out of nowhere it wouldn't stay completely open or wouldn't open all the way, similarly to what you described.
      It dropped down on me once and that's when I found that I could adjust the springs. I did it that day, no tools required other than to remove the trunk liner. It's never been a problem since. FWIW it came from the factory with the spoiler.
      Give it a try...you can always put them back to the original position if you're not satisfied.
      Good luck
      May 28th, 2009
      Ft. Worth, TX
      10-05-2016 09:07 AM #9
      Intermittent also might mean poor lubrication at friction points, wherever they are. I know it's a new car, but...
    10. Member g-man_ae's Avatar
      Jun 20th, 2001
      Twickenham AL · USA
      2015 VW Passat V6 (mine), 2012 VW Beetle 2.5 (wife's)
      04-21-2017 03:15 PM #10
      It weighs nothing
      You must be lucky, because I have the same issue as the OP. I had a wimpy trunk to begin with...
      http://forums.vwvortex.com/showthrea...trut)-in-trunk
      ... and like others experienced, the dealer response was to lube the weather stripping. This helped only a little. Now that I've since added the factory spoiler, my trunk lid won't spring open at all.
      30k svc. is coming up, time to point the dealership to this thread and get the springs adjusted.
      "Upgrade with OEM Parts" -- Roger Moore and SVTWEB, you are missed
      Quote Originally Posted by Cigar Aficionado
      You can measure the power of a car, but you cannot measure the smile it puts on your face.
      May 16th, 2013
      Los Angeles
      04-22-2017 02:00 AM #11
      Update; problem seems to have self cured. normal operation 98% of the time.
      Apr 12th, 2014
      Temescal Valley, CA
      04-22-2017 02:10 AM #12
      Quote Originally Posted by g-man_ae View Post
      Seriously dude just move the springs...I thought you did this weeks ago. Don't wait for the dealer. It's beyond easy. 3 t20 plastic torx screws/fasteners. Pull carpet down to expose springs. Unhook spring and relocate to desired position. Put carpet and then screws back in place. Enjoy normal trunk operation
      Josh
    13. Member snobrdrdan's Avatar
      Sep 9th, 2008
      Southeast Michigan
      2017 VW
      04-22-2017 06:30 AM #13
      2017 Passat VR6
      2017 Passat R-Line
    14. Member g-man_ae's Avatar
      Jun 20th, 2001
      Twickenham AL · USA
      04-22-2017 12:45 PM #14
      Quote Originally Posted by VeeDubFamily View Post
      Josh
      Slow down turbo. I haven't gotten around to this yet. The car will be in for its 30k service soon, so why not let the dealership spend VW's time and $ on this?
      I was supporting the OP in his assessment. The "weightless" spoiler has just enough mass to weigh down the trunk lid, enough to overpower the factory position of the trunklid springs. An assessment with which some of you disagree.
    15. Member
      Jan 13th, 2015
      Toronto
      04-22-2017 03:45 PM #15
      Ordered a stainless steel license plate frame the other day. Hope that added weight won't cause this kind of problem.
    16. Member g-man_ae's Avatar
      Jun 20th, 2001
      Twickenham AL · USA
      04-22-2017 04:13 PM #16
      Quote Originally Posted by Paroxetine View Post
      Come to think of it, I do have a steel BU alumni frame for my rear license plate
    17. Member Yogibearal's Avatar
      Apr 17th, 2014
      PNW
      2017 Passat SEL Prem, 2014 VW Beetle TDI-DSG, 2008 Honda Odyssey, 2000 Honda VFR800
      04-22-2017 05:35 PM #17
      Get a power liftgate system and no more issues. LOL
    18. Member miamipassat's Avatar
      Jan 19th, 2012
      Miami, FL
      2015/VW/Passat Limited 1.8TSi.
      04-22-2017 07:30 PM #18
      Reading this thread reminded me that my trunk did not "pop" open after my spoiler install last October. I do however have the larger fiberglass one that is heavier than the OEM one. Took me 5 minutes tops. All good now.
    19. 04-23-2017 08:02 AM #19
      I have an OEM spoiler from DAP. The installation instructions state: "When mounting the rear spoiler, the springs must be replaced with 561.827.665.A as per the Volkswagen Repair Guide"
    20. Member g-man_ae's Avatar
      Jun 20th, 2001
      Twickenham AL · USA
      04-23-2017 11:36 AM #20
      Quote Originally Posted by ArtK65 View Post
      That's the only spring the dealership shows (for my car anyway)
      http://www.keffervwparts.com/p/Volks...61827665A.html
    21. Member
      Nov 4th, 2013
      Albany Ny
      2012 Passat 2.5S
      04-23-2017 04:15 PM #21
      Hilarious
      NY | FortySixFilms | C A N O N B O Y Z
    22. Junior Member MNJetta2013's Avatar
      Sep 19th, 2014
      Richfield, MN
      2016 Passat SEL Premium, 1972 Westfalia Campmobile, and fiance's 2016 GTI S
      04-24-2017 01:38 PM #22
      Didn't you know that the OEM spoiler has much down force that it keeps the trunk lid down even when the car is stopped?
      Brad Spear
      Richfield, MN
      2016 Passat 1.8 SEL Premium
      Wife's 2016GTI S
    23. Member ThePhoenix's Avatar
      Aug 29th, 2012
      Rancho Santa Margarita, California
      2014 Titanium Silver Passat TSI SE w/SR
      04-24-2017 04:15 PM #23
      Chaz
      The British Leyland Rule: It's better to go fast in a slow car, than slow in a fast car.
