VWVortex.com - Accelerator Position Sensor 1/2 (G79/G185) Implausible Signal Intermittent
    Results 1 to 3 of 3
    Thread: Accelerator Position Sensor 1/2 (G79/G185) Implausible Signal Intermittent
      Apr 6th, 2004
      Richfield WI
      03 Jetta TDI Wgn 5 spd, 04 A4 B6 Avant Quattro 3.0 Tip, 08 GC Overland 3.0 CRD
      10-26-2016 08:21 PM #1
      All, started receiving the above code earlier this year and it has become more frequent. Until today, the last time was October 17, 2016. Code is primarily triggered during or after a rainstorm and results in CEL, EPC and limp mode initiation. Can still get up to 45 mph in limp mode so my daughter has been able to drive the car home on back roads without much problem. Last time I disconnected the battery, pulled and cleaned the MAF sensor, pulled and cleaned the ECU connection, reconnected the battery, cleared codes, ran two TB adaptations with Vagcom and called it a day. Car ran great until today.
      Same story with heavy rains, CEL, EPC and limp mode initiated on my daughter's drive home from college. Ran a full autoscan, attached below:
      Wednesday,26,October,2016,11:47:30:20196
      VCDS -- Windows Based VAG/VAS Emulator Running on Windows 10 x64
      VCDS Version: 16.8.3.1 (x64)
      Data version: 20161010 DS267.0
      www.Ross-Tech.com
      VIN: WAUVT License Plate: 04 A4 3.O OCT 26 2016
      Mileage: 148700km-92397mi Repair Order:
      Chassis Type: 8E (8E - Audi A4/S4/RS4 B6/B7 (2001 > 2008))
      Scan: 01 02 03 08 09 0F 11 15 16 17 18 25 36 37 45 46 55 56 57 65
      67 69 75 76 77
      VIN: WAUVT Mileage: 148700km-92397miles
      Address 01: Engine Labels: 06C-909-559-ASN.lbl
      Part No SW: 8E0 909 559 D HW: 8E0 909 059
      Component: JHM* V3/9X G 0003
      Coding: 0016751
      Shop #: WSC 63251 000 00000
      VCID: 3669D6F7420999F256-515A
      2 Faults Found:
      18047 - Accelerator Position Sensor 1/2 (G79/G185)
      P1639 - 008 - Implausible Signal - Intermittent
      P1639 - 008 - Implausible Signal - Intermittent - MIL ON
      Readiness: 0000 0000
      Address 02: Auto Trans Labels: 01V-927-156.lbl
      Part No: 8E0 927 156 Q
      Component: JHM VS2 3.0l5V USA 1213
      Coding: 0001002
      VCID: 3C7DC4DF7C2543A2A0-515A
      No fault code found.
      Address 03: ABS Brakes Labels: 8E0-614-517.lbl
      Part No: 8E0 614 517 A
      Component: ABS/ESP allrad 3429
      Coding: 04497
      Shop #: WSC 01234
      VCID: 264906B7C2A9E972E6-513C
      2 Faults Found:
      01314 - Engine Control Module
      79-10 - Please Check Fault Codes - Intermittent
      01826 - Sensor for Steering Angle (G85); Supply Voltage Terminal 30
      35-10 - - - Intermittent
      Address 08: Auto HVAC Labels: 8E0-820-043.lbl
      Part No: 8E0 820 043 AD
      Component: A4 Klimaautomat 1219
      Coding: 00000
      Shop #: WSC 63251
      VCID: 63CF5FA3F11B5C5AC1-513C
      Address 09: Cent. Elect. Labels: 8E0-907-279-8E2.lbl
      Part No: 8E0 907 279 F
      Component: int. Lastmodul USA 0517
      Coding: 01013
      Shop #: WSC 63251
      VCID: 356BD1FB0F0F92EA5F-4B18
      1 Fault Found:
      02104 - Light Detection Sensor (G399)
      29-10 - Short to Ground - Intermittent
      Address 15: Airbags Labels: 8E0-959-655-84.lbl
      Part No: 8E0 959 655 C
      Component: Airbag 8.4EP 3001
      Coding: 0010607
      VCID: 3777DBF3450360FA4D-513C
      Address 16: Steering wheel Labels: 8E0-953-549.lbl
      Part No: 8E0 953 549 N
      Component: Lenks·ulenmodul 0308
      Coding: 02042
      Shop #: WSC 63251
      VCID: 3E79CED73A3951B28E-4B18
      Address 17: Instruments Labels: 8E0-920-9xx-8E2.lbl
      Part No: 8E0 920 950 L
      Component: KOMBI+WEGFAHRS. RB4 D36
      Coding: 03200
      Shop #: WSC 02609
      VCID: 3261EAE7FE6185D27A-513C
      WAUVT68E34A039937 AUZ6Z0C0188654
      Address 36: Seat Mem. Drvr Labels: 8E0-959-760.lbl
      Part No: 8E0 959 760
      Component: Sitzmemory R2 F 0305
      Coding: 00002
      Shop #: WSC 63251
      VCID: 71E325EB3BE7FECA43-4B00
      Address 46: Central Conv. Labels: 8E0-959-433-MAX.lbl
      Part No: 8E0 959 433 BB
      Component: Komfortger·t T7B 1411
      Coding: 12044
      Shop #: WSC 63251
      VCID: 72E12AE73EE1C5D2BA-4B00
      Subsystem 1 - Part No: 8E1959801
      Component: Tırsteuer.FS BRM 0003
      Subsystem 2 - Part No: 8E1959802E
      Component: Tırsteuer.BF BRM 0003
      Subsystem 3 - Part No: 8E0959801A
      Component: Tırsteuer.HL BRM 0003
      Subsystem 4 - Part No: 8E0959802A
      Component: Tırsteuer.HR BRM 0003
      8 Faults Found:
      00962 - Alarm via. Tilt Sensor
      35-00 - -
      01374 - Alarm triggered by Terminal 15
      35-00 - -
      01371 - Alarm triggered by Door Contact Switch; Driver's Side
      35-00 - -
      01574 - Alarm triggered by Door Contact Switch; Rear Right
      35-00 - -
      00955 - Key 1
      00956 - Key 2
      35-00 - -
      01561 - Rear left door
      59-10 - Can't Unlock - Intermittent
      01562 - Rear right door
      Address 56: Radio Labels: 8E0-035-1xx-56.lbl
      Part No: 8E0 035 195 H
      Component: symphony II NP2 0260
      Coding: 01005
      Shop #: WSC 68096
      VCID: 2C5DF49FDC45D32230-50AC
      2 Faults Found:
      00878 - Connection to Speaker Front Left
      36-10 - Open Circuit - Intermittent
      00879 - Connection to Speaker Front Right
      End-------------------------(Elapsed Time: 05:53)--------------------------
      Cleared codes, ran TBA, test drove and less than a block away the CEL, EPC and limp mode initiated.
      Ross-Tech suggests the accelerator pedal sensors rarely take a ****, however, the O2 sensors and their wiring may be a culprit. This car had JHM downpipes installed a couple years ago and I assume the installer reattached the O2 sensors correctly. I also sent the ECU and TCU to JHM a couple years ago for upgraded tunes.
      My thoughts are to inspect the O2 sensors next and pull the ECU again and inspect the connectors at the bottom of the ECU housing for moisture. I'd take a closer look at the throttle body sensors and wiring, however, I am not finding any information related to throttle body sensors and related wiring for a 3.0. Any help or suggestions that members can provide is appreciated.
      Thanks~Mark
      03 Jetta TDI Wagn 5 spd, RC5 tune, 17/22 Hybrid, PP 2.5" DP, PP IM, 11MM IP, Bosch .216 Inj, Euro SMI, AFE CAI, 3" MAF, 3 Bar Map, Nicktane FF, Magnaflow
      04 A4 B6 Avant Quattro 3.0 Tip, JHM tuned ECU and TCU, JHM catless DP's, Revmax TC, Magnaflow, AME Pro Dry AF
      08 GC Overland 3.0 CRD, GDE Hot Tune with DPF delete, AME Pro Dry AF
    2. n00b
      Jun 28th, 2010
      Vermont
      Audi A4Q B6, 6-spd
      10-27-2016 09:39 PM #2
      Hey Mark,
      Just curious. Is the plastic under-engine pan installed on this car? Sounds like you're getting water into a possibly cracked throttle position sensor connector?
      just a guess.
      Dan
      Quote Originally Posted by brew1 View Post
      www.Ross-Tech.com
      67 69 75 76 77
      Coding: 0016751
      2 Faults Found:
      Coding: 0001002
      Coding: 04497
      Shop #: WSC 01234
      2 Faults Found:
      Coding: 00000
      Shop #: WSC 63251
      Coding: 01013
      Shop #: WSC 63251
      1 Fault Found:
      Coding: 0010607
      Coding: 02042
      Shop #: WSC 63251
      Coding: 03200
      Shop #: WSC 02609
      Coding: 00002
      Shop #: WSC 63251
      Coding: 12044
      Shop #: WSC 63251
      8 Faults Found:
      35-00 - -
      35-00 - -
      35-00 - -
      35-00 - -
      00955 - Key 1
      00956 - Key 2
      35-00 - -
      Coding: 01005
      Shop #: WSC 68096
      2 Faults Found:
      Thanks~Mark
      Apr 6th, 2004
      Richfield WI
      10-27-2016 11:29 PM #3
      Good guess. I removed the plastic skid plate last year and never reinstalled it. I had intentions of purchasing a metal skid plate and never followed through. Good suggestion, thanks. I'm not sure road spray would get up to the top of the engine but it could certainly reach the O2 sensors which according to the Ross-Tech, could be one source for the Accelerator Position Sensor 1/2 (G79/G185) Implausible Signal Intermittent.
      Today I pulled both the ECM and TCM, sprayed each module's connector pins with MAF cleaner and swabbed them with q-tips soaked in alcohol. Inspected the wires and relays at the bottom of the ECM/TCM plenum and all appeared to be tight and undamaged. I did observe some moisture and a crack in the plastic plenum housing next to one of the torx screws that hold the plenum cover in place. Resolved that issue with silicone sealant and duct tape.
      Cleared codes and ran two throttle body adaptations. Code for the Accelerator Position Sensor remained cleared and a test drive was normal.
      I'll examine the O2 sensors this weekend and reinstall the plastic skid plate.
