VWVortex.com - MSD 6AL with 2.0 ABA distributor
    Results 1 to 6 of 6
    Thread: MSD 6AL with 2.0 ABA distributor
    1. Member MK1_F00L's Avatar
      Nov 12th, 2001
      TORONTO
      MK1 SCIROCCO
      10-27-2016 11:31 AM #1
      Just wondering if anyone has installed a MSD setup on a 2.0 ABA on carbs?
      My question is would I be able to still use the ABA distributor and ICM, and then mate that to the MSD 6AL and timing computer? Or will I still need to back date to the older style distributor.
      Pics for views
    2. Geriatric Member need_a_VR6's Avatar
      May 19th, 1999
      Oxford, PA
      15 Jetta 92 Corrado VR6
      10-27-2016 03:20 PM #2
      Aba only has one window in the dizzy and can't run a 4cyl by itself. Just use the older dizzy.
      -Paul
      1992 Corrado - ALL MOTOR Drag Project
      1995 GTI VR6 - Retired - 12.90@106 R32 power - 12.833@106 12v power
    3. Member MK1_F00L's Avatar
      Nov 12th, 2001
      TORONTO
      MK1 SCIROCCO
      10-27-2016 03:35 PM #3
      That's what I thought. I was hoping that using both the ABA dizzy and the ABA ICM, that it would have a usable output signal
    4. Geriatric Member need_a_VR6's Avatar
      May 19th, 1999
      Oxford, PA
      10-31-2016 02:01 PM #4
      Nope on an ABA the dizzy signal is only used to identify cyl1 compression stroke. The cranks sensor and ECU is used for the rest.
      Best off using an early dizzy.
      -Paul
    5. Member MK1_F00L's Avatar
      Nov 12th, 2001
      TORONTO
      MK1 SCIROCCO
      11-17-2016 12:12 PM #5
      Quote Originally Posted by need_a_VR6 View Post
      I'm already on my hunt through my bins to see what I can put together.
      Thanks for all the help
    6. Member rhussjr's Avatar
      Aug 7th, 2000
      Charlotte, NC
      1992 Jetta GLI 16V Project / 1981 Caddy 2.0 build
      01-08-2017 09:30 AM #6
      You need an Audi 80 2.0 dizzy or swap the reluctor over from a 1.8 Mk2 Digifant dizzy to the ABA dizzy.
      RIP Marshall Lightner - Staggered Mk4 - I will miss you my Friend and my Brother [12/15/2010] / RIP Yohannes Gebrekidan - Yohannes - YoYo, you will be missed my friend [03/06/16] / RIP Jeffrey Bynum - Jeffrey B - Jeff, I have no words that to say other than I love you [12/07/16]
      https://www.facebook.com/JRCMotorsportsVW
