VWVortex.com - suprise suprise, car won't start... HELP :(
    Page 1 of 3 123 LastLast
    Results 1 to 25 of 75
    Thread: suprise suprise, car won't start... HELP :(
    1. Senior Member kitty's Avatar
      Feb 10th, 2002
      2013 The Beetle, 2009 Genuine Stella 2T
      05-06-2003 12:32 PM #1
      shocking, a VW refusing to start!
      alright, here's the story. i turn the key, it sounds like it's starting, turns over and everything, basically starts up... but i let go of the key and it shakes and dies.
      i checked to make sure all the wires were snug, it's got a quarter tank of gas, no fluids leaking, everything seems to check out. so i tried pumping the gas a little, but it won't rev or anything. slew of new parts in the past couple weeks, starter, plugs, wires, cap, rotor.
      it HAS been raining on and off all morning... but it's been raining a lot lately and i haven't had any problems starting it, just the typical sputtering and hiccuping he's been doing for a little while. my fox used to give me trouble in the rain, but i could always START it, and it wouldn't stall unless i hit the gas... the golf just won't hold an idle.
      any insight? right now the only thing i can do is wait a while and hope he just needs to dry out
      -kitty
      I my crazy dachshund
    2. 05-06-2003 12:34 PM #2
      Kitty, sorry to hear. I have had an issue with wet weather for almost a year and a half now, sounds exactly like what you are describing. My universal fix-all has always been just to wait it out and let the thing dry out a bit. I used to just keep trying to start it over and over again, but after replacing the starter 3 times in two years, I learned my lesson.
      P.S. It might be the shoes!
      Modified by SalemNHGreenGolf at 12:36 PM 5-6-2003
    3. Modnerdator MattySXE's Avatar
      May 9th, 2002
      Reading
      Mk3 Golf, B6 A4
      05-06-2003 12:37 PM #3
      I hope it's nothing serious
      BurnAllTheMk3s
      My Surf Green project
      Straightedge XXX
    4. 05-06-2003 12:37 PM #4
      it could be your ignition switch.. but i dunno.. sometimes my car does that.. but its just cause when i let go of the key it goes to far and shuts off..
      later..
    5. Senior Member kitty's Avatar
      Feb 10th, 2002
      05-06-2003 12:38 PM #5
      haha, it's not the shoes... i wear my saucony jazz's to work
      i'm wary about blaming the wet weather. it's been raining a lot lately (usually much worse than the sprinkles we got this morning) and he hasn't given me problems starting up.
    6. Banned
      May 10th, 2001
      05-06-2003 12:39 PM #6
      probably a stupid question, but did you double check to make sure you got your wires in the right order on the new dist?
    7. Senior Member kitty's Avatar
      Feb 10th, 2002
      05-06-2003 12:41 PM #7
      i HOPE it's not the ignition switch... that's new too
      i really doubt it is, since the car will repeatedly START basically, just won't hold the idle as soon as i let go of the key.
      could it be the coilpack? it just seems like it's not sparking right, it's either ignition or fuel...
    8. 05-06-2003 12:41 PM #8
      check mass airflow sensor-- could be loose
    9. Senior Member kitty's Avatar
      Feb 10th, 2002
      05-06-2003 12:42 PM #9
      Quote, originally posted by Slapshotnerd »
      yes, we replaced one at a time so they're definately in the right order... and that was about 700 miles ago, i assume it would have done this sooner if that was the problem.
    10. 05-06-2003 12:42 PM #10
      Have you looked into the ignition coil? I recently had a problem with it sputtering and shaking and not taking the gas. Dealer had recently cleaned trottle body and changed vacuum hoses before the problem occured. Well after almost two weeks of not fixing the problem they finally fixed it when the changed my ECU. They put a new throttle valve and even a new coolant sensor. But the car has been starting fine ever since they put in the new ECU. All free of charge thank God.
    11. Senior Member kitty's Avatar
      Feb 10th, 2002
      05-06-2003 12:43 PM #11
      Quote, originally posted by MicrobiologyNerd »
      *idiot question ahead*
      is that the sensor right after the airbox? if so, i checked that... if not, well i checked whatever that is, haha.
    12. Senior Member kitty's Avatar
      Feb 10th, 2002
      05-06-2003 12:48 PM #12
      Quote, originally posted by fastjettagt »
      i think that's what i'm going to have to try.
      i wish the car had decided to do this HERE and not at work luckily work is only a couple minutes away though.
    13. Member DRVRFWND's Avatar
      Mar 9th, 2003
      Tim Horton's Toronto Canda
      2002 Audi S8 (daily), 1994 GTI VR6 (Unicorn), 1976 Golf 1.8T, 1992 Jetta GTX VR6
      05-06-2003 12:56 PM #13
      btw check out all the relays i had this problem with my rabbit.. turns out it was the fuel relay. so just make sure the relays are ok and no fuse problems .. def sounds electrical.
    14. Member DUBSPORT138's Avatar
      Jan 15th, 2001
      milwaukee,sux
      MKV16v&MKIIIgolfvr6
      05-06-2003 01:03 PM #14
      i had the same problem yesterday. except i stalled in an intersection and had to push it across
      it is most-def. the coilpack(or whatever the 2.0 has by the firewall, that the 5th wire goes to)
      get some silicone gel and put it around the plug. it normally lasts me a year. just forgot to put some more on this year
      with where that part sits, it tends to collect water.
      mine started again after about 15 min
    15. Member EpicVW's Avatar
      Feb 10th, 2000
      Bay Area, CA
      05-06-2003 01:04 PM #15
      Sounds just like when my 2.0 slipped a tooth on the timing belt. I would bet that's what happened to you too...
    16. Senior Member kitty's Avatar
      Feb 10th, 2002
      05-06-2003 01:11 PM #16
      brand new timing belt, so i hope that's not it!! like i said, tons of new parts, so i'm getting extremely frustrated that every time i replace something, something else goes... but hey, that's expected of a VW. my dad came to pick me up in his chrysler, as we pulled away he goes, "you know, it may be ugly... but it hasn't given me one damn problem in five years. i get in, it starts... i back in, it starts..." gotta rub it in i guess.
      i guess i'm going to go back over there and try again, hope that it just needed some time to dry out.
      if not... anyone know the best place to pick up an ignition coil?
    17. Member EpicVW's Avatar
      Feb 10th, 2000
      Bay Area, CA
      05-06-2003 01:14 PM #17
      Just because your timing belt is new, doesn't mean it couldn't happen. It actually would make me more suspicious. The person who put it on could have improperly tightened the tensioner, etc. I would check that out first before buying new stuff like ignition coils. My coil went out too, and it didn't fire at all so I don't think that's the case.
    18. Senior Member kitty's Avatar
      Feb 10th, 2002
      05-06-2003 01:19 PM #18
      well... i had the timing belt and waterpump done in february... it was running fine for at least a few weeks, then started giving me the sputtering crap again.
      does that sound like the timing belt could be at fault? could it have caused sputtering then finally make the car not start right?
    19. Member EpicVW's Avatar
      Feb 10th, 2000
      Bay Area, CA
      05-06-2003 01:23 PM #19
      Absolutely. I had my belt done at 60k miles, and at 88k it slipped a tooth. Loosed it up, put the cam back in the right place, and bam! No problem again, and i'm at 118k now, due for another belt. It just happens sometimes...Old belt, new belt...Just one of those things..
    20. Senior Member kitty's Avatar
      Feb 10th, 2002
      05-06-2003 01:26 PM #20
      damn
      i JUST ziptied my lip on yesterday and now i gotta cut them to get the damn thing on a towtruck
      well... one last try i guess. gonna go hope it starts, if not... to the shop it goes
    21. Senior Member kitty's Avatar
      Feb 10th, 2002
      05-06-2003 03:23 PM #21
      no luck, of course...
      calling my uncle to see if he can do anything about it. if not, it gets towed to my cousin's shop. i really need this money for other thing
    22. Member Mr. Rabboto's Avatar
      Oct 6th, 1999
      Las Vegas
      94 Carrera 2 - '14 Rubicon JKU
      05-06-2003 03:30 PM #22
      Not sure about this, but what about fuel filter?
    23. Senior Member kitty's Avatar
      Feb 10th, 2002
      05-06-2003 03:32 PM #23
      someone just said fuel filter a few days ago... said he was having similar sputtering problems.
      but would that cause it to not even idle?
      i'm sure there's a gazillion more things i need to replace, but right now i want to focus on what will make it just plain RUN
    24. Member Mr. Rabboto's Avatar
      Oct 6th, 1999
      Las Vegas
      05-06-2003 03:36 PM #24
      Quote, originally posted by ninetyseven »
      It won't idle if the fuel flow is restricted, i.e. clogged filter. I think this would be especially true on cold starts...
    25. 05-06-2003 03:40 PM #25
      I would have to agree with passatrcr and say the timing chain, but then again it could be the coil, the dealer has the coils there about a $100 buck. good luck.
      Modified by 98silverGTIVR6 at 3:40 PM 5-6-2003
